FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 10 Jan 2012 (Tuesday) 19:20
Best memory card for rebel T3i
bonnie27clyde
Jan 10, 2012 19:20 |  #1
I just upgraded from Rebel xTi to T3i. What is the best memory card for photo and video?
LucasxOB
Jan 10, 2012 19:37 |  #2
In my T3i, I have the 16GB SanDisk Extreme. Class 10.
Make sure any memory card you get is class 10. Makes for smooth videos.
RTPVid
Jan 11, 2012 07:04 |  #3
Your camera's manual specifies at least class 6 for HD video. The bit stream for your camera's video recording is at 5.5MB/s. Class 6 (6 MB/s) is sufficient. Class 10 gives you a bit of performance margin, but won't actually work any better than a properly operating Class 6 card in recording video.
Also, your camera will either record "smooth" video or it will stop recording. It won't record "jumpy" video to a card that is too slow; it will merely stop recording.
If you play back the video on your computer directly from the card, the speed of the card can affect how smoothly the video plays back (but this is read speed, which the Class-rating system does not specify; however, read speed is typically the equal to or faster than the write speed). The video files your camera records can have playback problems on PCs. Search the forum for suggestions on video player applications that work best with the Canon video files and a Windows PC (if that is what you have).
Tom
UKseagull
Gallery: 201 photos
Joined Jan 2012
Jan 11, 2012 13:01 |  #4
LucasxOB wrote in post #13682543 (external link)
That sounds like the same card that I've just got, it works a treat in my 600D
SanDisk Secure Digital High Capacity Card Extreme Video HD 16GB
http://www.aveyardphot​ography.co.uk/ (external link)
https://twitter.com/Th​eAndyA (external link)
shinksma
Joined Jul 2011
Jan 11, 2012 15:00 |  #5
RTPVid wrote in post #13684643 (external link)
Bold my emphasis.
And that's the rub: some "class 6" cards are not quite up to snuff, and sometimes reliable and repeatable test results are hard to find on the interwebz, so moving up to a Class 10 generally assures you that the card is going to be fast enough, even if not a Sandisk.
IMHO, YMMV,
shinksma
5DII | T3i | EF 17-40 L | EF 24-105 L | EF 24 1.4 L II | EF 28 1.8 | EF 85 1.8 | EF 70-200 2.8 L IS II | EF 100-400 L | EF-S 15-85 IS USM | EF-S 17-55 2.8 IS USM | EF-S 10-22 USM | EF 100 2.8 Macro USM | EF-S 18-55 IS | EF 35-80 III | EF-S 55-250 IS | Rokinon 8mm FE | EF 75-300 non-USM III | SMC Takumar 50mm f/1.4 | Tamron 70-210 | 430EX II | Kenko 2x MC4 and 1.4x Pro300DGX TC
RTPVid
Jan 11, 2012 15:37 |  #6
shinksma wrote in post #13687120 (external link)
Bold my emphasis.
IMHO, YMMV,
shinksma
Good point, and at present prices, going with Class 10 is not that much of a price hit (and in fact, can be none at all). HOWEVER, Class 10 Sandisk are among the "problem children" of the counterfeiters, so caveat emptor (know your merchant).
But, I was responding to the comment: "Make sure any memory card you get is class 10. Makes for smooth videos." You don't need to make sure it is class 10, but you do need to make sure the brand is reputable (Kingston, Lexar, Sandisk) and is at least a Class 6. And, card speed as nothing to do with "smooth video" being recorded. As I said, the camera will just stop recording as soon as the buffer fills with a card that is too slow.
Tom
JPLaval
Joined Jan 2012
Jan 11, 2012 20:20 |  #7
The same card im using..
30MB/s great card!
-JP-
"Photography is a way of feeling, of touching, of loving. What you have caught on film is captured forever... It remembers little things, long after you have forgotten everything". ~ Aaron Siskind
liegelr
Joined Jun 2011
Jan 12, 2012 12:33 |  #8
I've got both 8GB and 16GB Transcend Class 10 cards off Amazon for my T3i. Quite affordable and I've had no problems to date.
Don't go overboard pre-emptively buying way more than you need; in 6 months you'll probably be able to buy 50% more space for the same price if you need it then. Prices just keep dropping and dropping on memory. Weird to think that 10 years ago, I was thrilled to get a 128MB CF card for "only $210".
Canon T3i w/ Canon 17-55 f/2.8 - Canon 18-55 - Canon 55-250 - Canon 50mm f/1.8
bonnie27clyde
Jan 12, 2012 14:18 |  #9
Is there anything to the "write speed?" I see 20X and 30X....is 30 really better?
RTPVid
Jan 12, 2012 14:41 |  #10
bonnie27clyde wrote in post #13693128 (external link)
Well, if it is labeled that way by a reputable manufacturer, 30X is 50% faster than 20X. ;)
The "X" method of stating speed is an older (and more complicated to understand) method than the "class" rating. The "X" rating is what you typically see on CF cards; not so much on SD cards.
"X" refers to "times faster than the original recordable CDs". 1X = 150KB/s.
Class 6 = 40X.
Class 10 = 66X.
So, you wouldn't want to buy either a 20X or a 30X card intending to record video with your T3i.
Tom
baj2k
Gallery: 6 photos
Joined Dec 2011
Jan 12, 2012 21:17 |  #11
I went with the cheap Transcend 8Gb's on Amazon. They work fine. I don't do lots of burst mode shooting so I never have an issue. You can get about 300 RAW images on 8Gb. I chose the 8Gb and bought 4 instead of one 32Gb. I don't want to put all my eggs in on basket. If one fails while I'm out the field I'm only going to lose up to 300 pics and maybe a days shooting where as losing 1200 & a day on a 32Gb would be worse. Also, 300 images download a lot faster than 1200.
absplastic
Gallery: 40 photos
Jan 12, 2012 21:56 |  #12
baj2k wrote in post #13695642 (external link)
Do this. The cards are flimsy and do eventually break. I broke another just today, it cracked apart at the corner near the contacts (prob due to the extreme cold here) and the camera won't recognize it now. If you have just one card, and it breaks, you can't shoot until you buy another.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
John ­ from ­ PA
Joined May 2003
Jan 15, 2012 22:27 |  #13
OfficeMax this week happens to have Lexar Platinum II SDHC cards at very attractice prices. I'm puzzled however because the 8 GB (Lexar #LSD8GBBSBNA100) is stated on the actual card as a Class 6. The price is $13 sale and $35 list. In contrast, the 16 GB card (Lexar #LSD16GBSBNA100) is stated on the actual card as a Class 10. The sale price is $22 vs. the list of $55.
znerolkram
Joined Nov 2011
Jan 17, 2012 09:17 |  #14
I also have a problem on 32 gb class 10 transcend cards. When I record an 1080p video on Canon t3i it stops automatically. it won't last a minute. I am planning to buy 8 gb or 16gb sandisk class 10.
spb
Feb 28, 2012 09:31 |  #15
do cameras have a limit on how big of a card they can accept? no reason a 32GB Sandisk SDHC would not work on a T3i?
60d | 50d | grip | 11-16 2.8 | 17-55 2.8 | 50 1.4 | 24-105 | 70-200 II | 60 macro | 580EXII x2
flickr (external link) | gear | feedback
76,824 views & 0 likes for this thread, 23 members have posted to it and it is followed by 2 members.
1507 guests, 130 members online
