has anyone with a T3/1100D purchased one of these and do they work or do they not work due to the SD card being in the same compartment as the battery (causing the camera to power off when battery cover is opened)?
Jan 10, 2012 21:39 | #1 has anyone with a T3/1100D purchased one of these and do they work or do they not work due to the SD card being in the same compartment as the battery (causing the camera to power off when battery cover is opened)? 6D | T3/1100D | EF 85mm f1.8 USM | EF 50mm f1.8 mkII | EF-S 10-18mm IS STM | EF-S 18-55mm IS II | 600EX-RT | YN-E3-RT | PCB B800 |
CanonCameraFan Goldmember 1,694 posts Likes: 142 Joined Sep 2011 Location: Annapolis Maryland More info | Jan 18, 2012 16:31 | #2 I bought my daughter a T3, and noticed the Battery Grip we considered, uses an external cord to get power from it to the input on the camera. Nothing goes inside the camera itself. She decided to not get a grip, so I guess I may not have really answered your question. EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
J0eybb Member 154 posts Joined Nov 2011 Location: Las Vegas More info | Jan 18, 2012 16:33 | #3 I have this and it works just fine. T3i Kit | EF-S 18-55mm f/3.5-5.6 IS | EF 75-300mm f/4-5.6 III | EF-S 55-250mm f/4-5.6 IS | n00b
Jan 18, 2012 19:03 | #4 J0eybb wrote in post #13727600 I have this and it works just fine. http://www.amazon.com …ef=oh_o01_s00_i01_details I see that you have the T3i. As I have the T3/1100D not the T3i/600D will the grip you have work on a T3/1100D? 6D | T3/1100D | EF 85mm f1.8 USM | EF 50mm f1.8 mkII | EF-S 10-18mm IS STM | EF-S 18-55mm IS II | 600EX-RT | YN-E3-RT | PCB B800 |
J0eybb Member 154 posts Joined Nov 2011 Location: Las Vegas More info | Jan 19, 2012 18:50 | #5 Gumby1220 wrote in post #13728487 I see that you have the T3i. As I have the T3/1100D not the T3i/600D will the grip you have work on a T3/1100D? The one I have is a replacement for the Canon BG-E8. I think you'll need Canon BG-E3 T3i Kit | EF-S 18-55mm f/3.5-5.6 IS | EF 75-300mm f/4-5.6 III | EF-S 55-250mm f/4-5.6 IS | n00b
Jan 19, 2012 21:34 | #6 J0eybb wrote in post #13734503 The one I have is a replacement for the Canon BG-E8. I think you'll need Canon BG-E3 that is for the xt and xti which have completely different battery packs then the T3 6D | T3/1100D | EF 85mm f1.8 USM | EF 50mm f1.8 mkII | EF-S 10-18mm IS STM | EF-S 18-55mm IS II | 600EX-RT | YN-E3-RT | PCB B800 |
RTPVid Goldmember 3,365 posts Likes: 3 Joined Aug 2010 Location: MN More info | Jan 20, 2012 16:16 | #7 I can't see where Canon sells a battery grip for the T3. It is not listed as an accessory on their web site, anyway. If an external power cable is required, that would be a strong hint that Canon did not intend for the T3 to have a battery grip. Tom
Jan 20, 2012 16:18 | #8 yes I understand this and is why I am asking about a specific third party aftermarket battery grip. If anyone has input dealing with the grip in the original post please share any input on it. 6D | T3/1100D | EF 85mm f1.8 USM | EF 50mm f1.8 mkII | EF-S 10-18mm IS STM | EF-S 18-55mm IS II | 600EX-RT | YN-E3-RT | PCB B800 |
| Latest registered member is Niagara Wedding Photographer 883 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
