A couple of things.
1) there are highlights that I would not consider specular that are completely blown and distracting (for example any area on the furniture in which the finish blows out - back of the chair, edges of the side table - as well as the crystal/glass on the right). Because you are using HDR, these areas should be captured and handled appropriately.
2) as is the case when you shoot directly into a bright light source, there is a large area of lens flare overlying the table leg and chair directly in front of the camera. Next time, you should consider shading the lens (even above and beyond what the lens shade might provide) to avoid this flare. Processing only makes it more visible.
3) if you are going for an HDR capture/rendering, you cannot have the chandelier lights and the glass surrounds and fixtures completely blown. Even if you take a single exposure just for them and blend that area back into a rendering like the one you posted, you need to pre sere these details. Otherwise, the light source is a distraction and it is likely an interesting part of the scene that is no longer viewable. Also, consider the aperture at which you shoot the scene, if the star patterns emanating from each lamp bulb are undesirable.
Shooting this during the day will help bring the luminance of the room closer to the level of the bulbs in the chandelier, so less overall compression will be necessary - however, then you will have to deal with the mixed lighting conditions (exterior daylight and tungsten interior lighting). Real estate photographers should carry a huge assortment of daylight balanced bulbs and replace the tungsten ones in each room with daylight ones for such shots
Just some thoughts.
kirk
