Thread started 12 Jan 2012 (Thursday) 13:41
question on indoor photography
khilborn
Joined Jan 2012
Jan 12, 2012 13:41 |  #1
Hi, I was asked by a friend to take pictures at a wedding anniversary party (indoors of course) and I am NOT that confident about indoor photography (I have experience with outdoor/outdoor sports photography ). I have a Canon T1i with a 18-55mm lens... that's it. Part of me just wants to put in on Auto because I'm not confident on indoor shots, but I'm sure I can get better shots if I use the AV or M mode I think. Does anyone have suggestions on what settings I should use. The highest f/stop is 4.0 and I just want to take good pictures for my friend to capture this night.
JeffreyG
Gallery: 42 photos
Jan 12, 2012 13:55 |  #2
Without buying anything, your best bet will be to drag the shutter. Here is the simplest way to do this for an inexperienced photographer.
AV mode and set exposure compensation to negative one stop. Set the lens wide open and choose an ISO so that f/5.6 gives you 1/20 to 1/30 shutter speeds. Pop up the flash.
The ambient exposure will preserve the background while the flash will pop and freeze the subjects.
A CTO gel taped to the flash would also help if you can get one in time. Set WB to 3500 or so if you do this.
khilborn
Joined Jan 2012
Jan 12, 2012 13:56 as a reply to  @ JeffreyG's post |  #3
thank you so much!... I will practice what you said in my house for the next couple of days.
nathancarter
Gallery: 32 photos
Jan 12, 2012 13:58 |  #4
Bounce flash can save you in a situation like this - by bouncing the flash off the ceiling and/or walls, you get photos that are properly exposed without a lot of high-ISO sensor noise or that lousy direct-flash look that the pop-up flash makes.
If you don't have a hotshoe flash, something like this might save the day - it allows you to bounce the pop-up flash off the ceiling or walls:
http://www.amazon.com …ags-on-product/B0017LNHY2 (external link)
If you can't spend any extra, then you might consider using Tv mode and a shutter speed of 1/80-1/160 (depending on your subjects' speed). Av mode will probably let the shutter speed drop so low that moving/dancing people will be smeared with motion blur. hopefully the camera will be able to increase the ISO enough to get a good exposure. You'll have some sensor noise, but noise is better than motion blur.
You can also do a mix of a slow shutter speed (for ambient light) and direct pop-up flash (to light/freeze the subjects) but you'll want to start practicing this technique in advance.
[edit] That's dragging the shutter, as described by JeffreyG.
gonzogolf
dumb remark memorialized
Gallery: 28 photos
Jan 12, 2012 13:58 |  #5
Try what jeffrey said, unless the lights are fluorescent then use a light green gel instead. Chances are you cant shoot with that lens in that place without flash. Do you have access to a flash, borrow or rental perhaps? Bouncing a flash makes all the difference in the world for these things.
khilborn
Joined Jan 2012
Jan 12, 2012 14:03 |  #6
I only have the camera's pop up flash, but perhaps I'll go out and purchase one I an attach... are you talking about the kind of flash that attaches but can be moved up or down? any suggestions that aren't too expensive ?
gonzogolf
Gallery: 28 photos
Jan 12, 2012 14:09 |  #7
Yes, an external flash. The popup flashes are horrible. The cheapest canon option is the 430exII, the YN company makes one that is around $100 that would be good for you. http://www.amazon.com …TF8&qid=1326398​942&sr=8-2 (external link)
khilborn
Joined Jan 2012
Jan 12, 2012 14:10 as a reply to  @ gonzogolf's post |  #8
thank you that helps
gonzogolf
Gallery: 28 photos
Jan 12, 2012 14:13 |  #9
If you get it, let us know, there are some easy tips and one DIY toy that can really help.
khilborn
Joined Jan 2012
Jan 12, 2012 15:13 |  #10
will do
JeffreyG
Gallery: 42 photos
Jan 12, 2012 15:14 |  #11
If you buy a flash, you can bounce. The you can decide if you need to drag the shutter or not based on how big the room is. If 1/200 and low ISO (In M mode) result in black backgrounds (because the room is large) the drag the shutter as I suggested to blend in some ambient.
PhotosGuy
Moderator
Joined Feb 2004
Jan 13, 2012 10:15 |  #12
This might help: Tips for Xmas Ball Please
khilborn
Joined Jan 2012
Jan 13, 2012 14:36 as a reply to  @ JeffreyG's post |  #13
I've been practicing with the Av mode inside the house with lights on and other indoor situations... I am so used to shooting in Tv mode because of all of the sports I photograph... that it seems when I'm shooting in Av mode, some of the pics are just not as clear as I think they should be, but maybe because I'm used to Tv mode outdoors... would it be possible to shoot inside with the Tv mode?
Plus I was not able to buy an external flash at this time... I borrowed one from a friend and tried it, but it was for her Olympus.. it fit, but I couldn't figure too much out about it except that it took FOREVER to charge up ... so I won't be using it.
gonzogolf
Gallery: 28 photos
Jan 13, 2012 14:38 |  #14
khilborn wrote in post #13699331 (external link)
You are missing the point, Using AV mode you are dropping below safe handheld speeds. If you shifted to TV mode your speed would be okay, but your aperture would be insufficient so you would be underexposed. The problem is not enough light, the mode is almost irrelevant.
gonzogolf
Gallery: 28 photos
Jan 13, 2012 14:47 |  #15
khilborn wrote in post #13699375 (external link)
so in your opinion for my situation, just stay with the Av mode in f/4.0?
No, get a flash.... Rent, buy, beg, borrow, or steal a flash.
2,536 views & 0 likes for this thread
Latest registered member is pius
1852 guests, 223 members online
