Thread started 15 Jan 2012 (Sunday) 23:29
Lens Recommendations for Lunar Pics
omarsultan
Joined Dec 2011
Jan 15, 2012 23:29 |  #1
So, thanks to all the great info (and pics) in this forums, I am looking to try my hand at astrophotography. I am looking at two areas: lunar and wide field. I'll tackle wide field in another post, for now I have a couple of basic question about lenses for lunar shots. My current gear is listing in my signature, so I won't repeat it here.
I guess I need a little more reach than my 70-200mm + 1.4C TC can offer, so I was looking at some other options:
  • Canon EF 300mm f/4L IS USM
  • Canon EF 70-300mm f/4-5.6L IS USM UD
  • Canon EF 100-400mm f/4.5-5.6L IS USM
Of the three, I was looking at the last one, since it would compliment what I already have and be useful in other scenarios. Alternatively, can I get away with something like the Canon EF 70-300mm f/4-5.6 IS USM lens for this particular purpose.
Thanks for any pointers,
Omar
Omar Sultan
Canon EOS 7D | EF-S 17-55mm f/2.8 | EF 70-200mm f/4L | EF 100mm f/2.8L | EF 1.4X III TC | Celestron EdgeHD 800
ohata0
Jan 16, 2012 02:52 |  #2
I probably would get the last one (100-400) since you already have the 70-200. Your 70-200 + TC gets you 280mm, so you wouldn't be getting a real increase in focal length w/ the 70-300 (only 20mm). Also, the 70-300 is a bit on the softer side @ the long end.
Which TC do you have? The canon one? If so, I don't think the 70-300 will work w/ that TC. If you have a different brand, then maybe. So that's another reason to get the 100-400--it will work w/ the TC (plus you'll get 560mm max).
Another option, if you plan on using it only for lunar shots, is to go the ebay route. Seriously. I bought an old vivitar manual focus 400mm f/6.3 (T-mount I think, but it came w/ a nikon adapter, which I then adapted to EOS mount) for around $100 or something. I've taken some nice shots w/ it...and although I initially only bought it for moon shots, I've used it on the mountains too when it's rainy/cloudy. Got some nice shots w/ that. But I never take it anywhere though...just stays at home.
You can even buy a telescope like this C90 @ amazon (external link) for less than the price of any of those lenses. Again, probably only really useful for lunar stuff, and maybe birding on a bright day. Because of the lens design, you'll probably get that odd dount bokeh.
If you're planning on only using the lens for lunar, consider the telescope. It'll get you a LOT of detail, and you probably wouldn't have to crop very much out of your pics. You do have to get adapters to hook up your DSLR to the telescope though, so look into that, if that's what you want. I don't think you'll spend more than $50 in adapters though, but just look into it and add it to the total price before deciding.
If you want to get another lens to complement the ones you have, then I'd say go for the 100-400. It's a pretty nice telephoto and covers a lot of range. You may want to try it first since it's a pump action zoom though.
Either way, I think 400mm is fine for lunar shots (to get started anyway). If you're not that satisfied w/ 300mm, you probably wouldn't be much more satisfied unless you make a larger leap focal length-wise.
also, welcome to the forum!
hollis_f
Jan 16, 2012 07:43 |  #3
The Moon is very, very small in the sky. If you want to fill the frame then you need around 1500mm on your 7D. This is an uncropped image taken at 840mm.
IMAGE: http://www.frankhollis.com/temp/Moon%20840mm.jpg
So the suggestion of a telescope is definitely worth checking out if you're going to be wanting to get some detailed 'close-ups'.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
omarsultan
Joined Dec 2011
Jan 16, 2012 12:55 as a reply to  @ hollis_f's post |  #4
Thanks folks for the advice--I got locked into the whole lens thing and did not even think about other options--I'll check our the C90 and I think my wife has a Meade telescope gathering dust somewhere. The good news is I can take the saved money and add it to my tracking mount fund. :)
Omar Sultan
paulccsi
Jan 19, 2012 21:04 |  #5
Just a thought. If you don't have a lot of cash to throw around and only want to use the lens primarily for the Moon, you may want to look to ebay and see if you may be able to pick up a 500 or 600mm mirror lens. You may also need to get a EF adapter to fit your canon camera. They are usually F/8 manual focus lenses, but should be fine for the moon or for stationary bird pictures.
Canon 7D, Canon 40D, Canon 350D, Canon 100-400L IS, Canon 17-85mm IS, Sigma 600mm, Canon 70-300mm IS, Canon 50mm f1.8, Tamron 90mm Macro, Vivitar 135mm f2.3 MF, Ring Flash, Digital 952AF Flash.
omarsultan
Joined Dec 2011
Jan 19, 2012 23:04 as a reply to  @ paulccsi's post |  #6
Thx--I'll go check eBay this evening....
Omar
Omar Sultan
2,244 views & 0 likes for this thread, 4 members have posted to it.
1399 guests, 170 members online
