Thread started 16 Jan 2012 (Monday) 18:13
Phottix Aion Mini Review
JeffreyG
Gallery: 42 photos
Jan 16, 2012 18:13 |  #1
My $35 Adorama knockoff RF shutter remote bit the dust after about a year of use. I'm not going to pay the ridiculous asking price of the Canon RF remote, so I started looking around for a new alternative.
The Phottix Aion is relatively new, I think it was released in December 2011. I picked one up online for $89.95 from Amazon (through Ace Digital Camera). It arrived pretty quick.
The remote has pretty decent build quality, feels good in the hand. The remote itself is a little bit on the large size, it will be noticed when you slip it in a jeans pocket.
Functionality is really very high for such an affordable remote. It can function as:
1) A basic remote shutter release
2) A burst type shutter release (seems to work at about 5 fps). I have not figured out a way to get a faster camera to run at maximum burst speed with the remote.
3) Bulb release. You can press once to open the shutter and then the LCD will display how long the shutter has been open. A second press will close the shutter.
3) Timed release (2 seconds)
4) Timer and intervalometer.
It's this last area that adds a lot of functionality over most remote releases. The Aion will allow you to take a long timed release of a pre-programmed duration. it will also allow you to program a series of photos at user defined intervals. This program can be set to end anywhere between 2 shots and 199....or is can be set to keep shooting indefinately.
One other nice feature is that the remote has a button to lock it out. This way if you start a bulb exposure (for example) you can lock the buttons and slip the Aion into a pocket without fear that you will end the exposure by accident.
I've got a few more things to play with. For now I've confirmed the remote works pretty much anywhere in my house but I don't know how good the range really is.
I also have not really played with the intervalometer. I have some questions in mind (like, can the remote wake the camera up?) but I will have to check this out in the future.
Let me know if you can think of any other questions, and I'll see what I can discover.
So far, it's a very handy remote for $90.
NickSim87
Sir Chimp-a-lot
Jan 16, 2012 23:26 |  #2
Perfect timing, as I was just looking into this remote...
Some questions for you, I currently have the Hahnel Giga T Pro II
http://www.hahnel.ie …tion/productSea​rch/pid/80 (external link)
http://www.youtube.com​/watch?v=fL4VJAEDdo8 (external link)
Does the Aion have all of the functions of the Giga? For example, I could set a 2 second delay, then a 5 second exposure, at 60 second intervals, for 50 exposures.
Hit play and it will delay 2 seconds, take the exposure, wait a minute, take another one, wait a minute, take another, etc...
One apparent advantage of the Giga is that it's extremely small, however the disadvantage is that you loose the convenience of AAA batteries (Uses CR2).
The reason I'm curious about the Aion is the auto bracketing, can you go do all of the features of the Giga + auto bracketing?
Also, how does it trigger the camera... it looks like the normal shutter release plug, so auto bracketing must be controlled by the Aion as if it was in 'bulb' mode? With that being said, is there any limit to the shutter speed? (eg 1/250, 1/500, 1/1000, 1/2000, 1/4000 bracketing)
I also wonder how it works with the Odin, could they somehow be used together?
Gear List | Feedback
EmaginePixel
Jan 17, 2012 10:29 |  #3
Thanks for the product intro and review. I have a Phottix Plato and have been looking for an intervalometer and this should fit perfectly.
"Yesterday is history. Tomorrow is a mystery. Today is a gift. That’s why its called the present” - Kung Fu Panda
EmaginePixel.com website (external link) ----- SportsShooter profile (external link) ----- Facebook page (external link)
JeffreyG
Gallery: 42 photos
Jan 17, 2012 16:23 |  #4
NickSimcheck wrote in post #13717294 (external link)
Yes, it will do this. The timer allows for delay, duration of exposure (in bulb on the camera), interval time and number of exposures all to be set, and you can set them all to run together.
The Aion uses AAA.
Yes and no. It will do all that stuff (delay, interval, number of shots) and it will also do bracketing (in blub mode). The only problem I see here is that the bracketing (in bulb mode) starts with a shutter speed no faster than 1/10th and then progresses in full stops from whatever starting point you gave it.
However, you can set the camera into single shot mode (not in bulb) and enable the cameras own bracketing feature set and then the Aion intervalometer will walk it through taking several shots in a row.
So to get flexible bracketing, you have to shoot in a non-bulb mode and let the camera make the exposure adjustments.
Just like I wrote....the release works through the normal shutter release plug, but it will trigger the camera in any mode, not just bulb. So you can let the camera meter the shot or use the camera internal bracketing feature.
I just bought the Odin too. The two systems work completely apart, but of course you can use them at the same time so that the remote triggers the camera and the Odin triggers remote flashes.
davidalindsey
Joined Dec 2011
Jan 23, 2012 16:02 |  #5
Great review.
I see you have a Canon 5D which uses a N3 remote socket?
I have a T3i which uses a E3 connector..
Why are there no E3 style wireless shutter remotes?
Could I use a N3 to E3 adapter like this, CANON RS-80N3 TC-80N3 LC-5 jack to RS-60E3 plug Adapter (external link) and have all the functions work?
Canon Rebel EOS T3i/18-55/55-250II
Jon
Joined Jun 2004
Jan 23, 2012 20:24 |  #6
davidalindsey wrote in post #13755317 (external link)
Great review.
Yes, you could. But there are E3-compatible wireless remotes. For instance (link at the top of this and every page): http://www.procamerage​ar.com …info.php/produc​ts_id/1227 (external link)
Jon
Cocker Spaniels
davidalindsey
Joined Dec 2011
Jan 23, 2012 20:40 |  #7
Yes all the ones that I have seen for the E3 style are just a shutter release and look ugly, with huge attentas protruding out of them.
I want one that has timer and long exposure functions as well.
Jon
Joined Jun 2004
Jan 23, 2012 20:42 |  #8
http://www.bhphotovide​o.com …terBoss_Timer_R​emote.html (external link)
Jon
Cocker Spaniels
darosk
Jan 23, 2012 20:56 |  #9
I got this set a couple of weeks ago too. Really like it so far, very solid and functionality is great. Haven't put it through it's paces yet, but seems to be really good.
Had a set of Phottix Strato's too, for a year now. They work pretty much flawlessly for my OCF stuff. The brand has really grown on me, looking at the Odin's right now for increased functionality over my Strato's. Great products.
Tumblr (external link) | Facebook (external link) | Youtube (external link)
Gear
JeffreyG
Gallery: 42 photos
Jan 23, 2012 21:03 |  #10
darosk wrote in post #13757099 (external link)
I'm really liking the Odin's. Price is good and the ability to control everything from the camera with E-TTL is great.
darosk
Jan 23, 2012 22:15 |  #11
JeffreyG wrote in post #13757140 (external link)
Yup, from all I've heard and seen so far it sounds amazing. Will probably get a set pretty soon.
Gear
Subtas
Jan 31, 2012 16:58 as a reply to  @ darosk's post |  #12
Does the Phottix TR-90 have the same functions than this one? Except for the bracketing and the wireless system.
5DIII
16-35L - Canon 100 Macro - 35L - 50L - 85L - 135L
580EXII - 430EXII - Odin
http://500px.com/subta​s (external link)
alfredomora
Mar 03, 2012 23:29 |  #13
Just purchased the Aion. Thanks JeffreyG for the good review.
- Alfredo -
Sony a7RII | Voightlander 12 f5.6 | Sony 16-35 GM f2.8 | Zeiss Batis 18 f2.8 | Zeiss Loxia 21 f2.8 | FE 55 f1.8 | Zeiss Loxia 85 f2.4 | Sony 100-400 GM |
Portfolio (external link)
J.Doe
Joined Mar 2011
Mar 04, 2012 00:20 |  #14
AFAIK,the Aion's receiver has a 2,5mm TRS female jack (instead of being "hard-wired").
You could use such an adapter cable like you mentioned but for the sake of simplicity (and functionality "on the field") I suggest using an 2,5mm-2,5mm cable like this one:
http://www.ebay.com …motes&hash=item​3a6efe37bc (external link)
As you can see,they're a third of a price of that adapter you mentioned.
(for that matter,if you like,you can also find coiled cables too)
This way,you'll have only one cable between the Aion and camera body instead of two....less hassle and items to be potentially lost in a hurry.Besides,you'll have both C1 and C3 connectors handy (in case that you'll use the Aion on a C3 body).
HTH!
Regards,
60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
pjs2
Mar 11, 2012 07:02 |  #15
Just bought the Hahnel Giga T Pro II got it home and it's dead out of the box. So back to the shop we go . Typical isn't it.
Recap
Turned out it was my bad not the t pros. I was not pushing the connector plug far enough. You have to push it till it clicks.. I don't like forcing things into my cameras. But it works a treat now.
s3is,50D,Canon 18-55is,Canon 55-250is,Canon 100mm macro, Nifty Fifty f1.8ii,Sigma 70-200mm f2.8, Sigma 150-500mm f5-6.3, tripod, monopod, 4 didgeridoo's.
Two million years of evolution and I'm still a Homo ergaster
19,378 views & 0 likes for this thread, 13 members have posted to it.
1631 guests, 139 members online
