Thread started 16 Jan 2012 (Monday) 21:11
Clone Stamp Issue
Bendel
Jan 16, 2012 21:11 |  #1
I just got a copy of CS5 and have run into a problem. When I use clone stamp, I choose my sample and then try to paint on the image. Once I click to paint, the image disappears. Once I let go of the brush, the image comes back. It does the cloning but it's extremely difficult to clone out a decent sized area when your work disappears.
Any ideas what's wrong?
Brandon
Canon 5D, 24-105 F4L, 70-200 F4L, 85 F1.8, 430EX II
CameraMan
Gallery: 26 photos
Jan 16, 2012 21:14 |  #2
Sounds like a Video RAM issue. Maybe you don't have enough?
Photographer (external link) | The Toys! | Facebook (external link) | Video (external link) | Flickr (external link)
Shampoo sounds like an unfortunate name for a hair product.
You're a ghost driving a meat-coated skeleton made from stardust, riding a rock, hurtling through space. Fear Nothing!
Bendel
Jan 16, 2012 21:17 |  #3
2GB AMD 6950. Any other ideas?
Brandon
Bendel
Jan 16, 2012 21:22 |  #4
Hmm. I tried going into the graphics properties and changed it from Normal to Advanced. Photoshop gave me an error when I tried to use the clone stamp. I then changed it back to normal and photoshop failed completely. I opened it back up and now it works.
Thanks.
Brandon
CameraMan
Gallery: 26 photos
Jan 16, 2012 21:33 |  #5
Sounds like a video problem. You have 2 GB of video or system RAM?
Bendel
Jan 16, 2012 21:36 |  #6
2GB video, 8gb system
Brandon
CameraMan
Gallery: 26 photos
Jan 16, 2012 21:46 |  #7
Maybe the card is going bad. Still sounds like a video issue to me. If it's working fine now then maybe there was an address conflict somewhere or something and when Photoshop quit then that may have fixed it. If it happens again then I would guess it's some type of memory problem.
Bendel
Jan 16, 2012 21:49 |  #8
My computer components are all less than two weeks old. I'd be extremely unhappy if it was a hardware problem. I haven't run into any issues with Skyrim which should be more graphic intensive than photoshop...I'll just pray for the address conflict which you talked about.
Brandon
solara
Jan 17, 2012 00:38 |  #9
What mode is the clone brush in? Haven't tried all the modes to try to duplicate your problem, but make sure it's in 'Normal' mode?
Edit: wait, are you saying the ENTIRE image disappears when you click to paint? As in the entire screen, or just the area you're painting disappears?
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Jan 17, 2012 13:24 |  #10
I think this sometimes occurs when you are painting on an adjustment layer, and not a pixel bearing layer. Flatten your file and see if it still occurs.
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
Bendel
Jan 17, 2012 14:02 |  #11
solara wrote in post #13717564 (external link)
Just the actual image file. The gray window which the image sits in and all of the toolbars are still there. It should be in normal mode, it was a new installation and I hadn't changed anything but I'll double check.
Bearmann wrote in post #13720145 (external link)
I can't say for sure whether or not I was on an adjustment layer. I only experienced it with one image before my photoshop crashed and it worked afterwards.
Brandon
René ­ Damkot
Jan 18, 2012 07:28 |  #12
In the prefs > GPU, set it to "basic" (or whatever it's called; simpler then "Normal" or "advanced"). See if that helps. It solved some graphic problems on a 27" iMac I was using with PSCS5.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Quad-Response
Jan 19, 2012 08:17 |  #13
Have you updated your graphics card driver at all or are you using the one from the disc that came with it?
Had similar issues and updating the driver fixed it for me
Chris
Canon EOS 1D Mark II for Sale - £450.00 ONO - PM For Details or see the Members Market
Bendel
Jan 19, 2012 12:26 |  #14
I didn't use the CD for drivers, I went to the AMD website for drivers. I could try updating them again, but they are only a couple weeks old.
Every time I've used photoshop since, I haven't had clone stamp problems so it seems that this problem has figured itself out.
Brandon
Higgs ­ Boson
Jan 19, 2012 12:30 |  #15
Wait, you put the drivers in a couple weeks ago and it fixed it but your thread is two days old?
A9 | 25 | 55 | 85 | 90 | 135
2,052 views & 0 likes for this thread
Clone Stamp Issue
Latest registered member is Guashumerda
813 guests, 195 members online
