Thread started 17 Jan 2012 (Tuesday) 07:59
Cybersync + Alienbee + 580EX II?
dawnkyung
Jan 17, 2012 07:59 |  #1
Dumb question...
I've recently purchased a set of cybersyncs - 1 trigger and 1 receiver. I have a 580EX II and an alienbee B800 on the way - can I trigger both at once with the cybersyncs if I pick up another receiver?
Thanks!
-Dawn
dawn | 29 | gear
patman530
Jan 17, 2012 08:29 |  #2
I assume you're asking about using the 580EX II off camera and manual (no ETTL). Answer is yes, you'll plug the 2nd receiver to the 580EX II via PC sync cord, set them all the same frequency.
EOS 5D Mark II | EOS 40D | EF 17-40 f/4L | EF 24-70 f/2.8L | EF 85 f/1.2L II | EF 70-200 f/2.8L IS | EF 50 f/1.8 II
SylvesterPotter
Joined Jan 2012
Jan 17, 2012 08:34 |  #3
why not just slave the 580?.....I use two speedlight this way....works great... and I have the cyber commander for the rest of the Alien bees.
www.SylvesterPotter.co​m (external link)
dedsen
Jan 17, 2012 08:39 |  #4
How do you slave your 580? The details might help the OP.
MT ­ Stringer
Jan 17, 2012 08:49 |  #5
dawnkyung wrote in post #13718585 (external link)
Dumb question...
Thanks!
-Dawn
The answer to your question is yes. The Cybersync's are simple triggers and they will fire your strobe and speedlight at the same time. I have done it in the past. Everything is a manual operation so you simply adjust your strobe/spedlight power and trigger it with your camera on manual.
Note: I use them in high school gyms, so the slave option on the 580 EX II doesn't come into play with me. I can't take the chance of someone else's flash triggering mine.
Hope this helps.
Mike
Examples - same gym, same event - both triggered at the same time.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i226.photobucke​t.com …sh%20Setup/MTH_​3726r1.jpg (external link)
http://i226.photobucke​t.com …lash%20Setup/MT​H_4966.jpg (external link)
MaxPreps Profile (external link)
My Gear List
dawnkyung
Jan 17, 2012 08:57 as a reply to  @ MT Stringer's post |  #6
Thank you guys! This was exactly what I wanted to know. :)
dawn | 29 | gear
Curtis ­ N
Master Flasher
Jan 17, 2012 09:07 |  #7
Two options:
1) Connect the CSRB to the 580EX II via PC cord (external link). Let the Alienbee fire on its own, with its built-in optical slave.
2) Purchase another Cybersync receiver (AC-powered version recommended) to plug into the Alienbee. Put both receivers on the same channel.
Option 1 will work for most indoor setups. Option 2 may be required for very large spaces or when other people are using flash in the vicinity.
3,676 views & 0 likes for this thread
Latest registered member is Paul Gnandt
895 guests, 265 members online
