the paper is new, but can you see all those bubbles ... any ideas why?
thanks
ccc_javier Goldmember 1,378 posts Joined Aug 2008 Location: Miami More info | Jan 17, 2012 09:32 | #1 the paper is new, but can you see all those bubbles ... any ideas why? http://somephotosmiami.com
EOSBoy Goldmember 1,083 posts Joined Jan 2008 Location: Panama City, FL More info | Jan 17, 2012 09:36 | #2 Interesting... Is the area you're shooting at very humid? You may need to run a dehumidifier to see if that'll help. Also, the direction of your lighting can cause shadows since the surface is a bit uneven on the BG. This hasn't happened to me after using seamless paper. Maybe it's worth exchanging. http://patrickengman.com
Jan 17, 2012 09:38 | #3 i thought about humidity... it is the only explanation... will have to put it sunbathing for a while? or just buy a new one http://somephotosmiami.com
EOSBoy Goldmember 1,083 posts Joined Jan 2008 Location: Panama City, FL More info | Jan 17, 2012 10:07 | #4 ccc_javier wrote in post #13718991 i thought about humidity... it is the only explanation... will have to put it sunbathing for a while? or just buy a new one Hmm, unless you can place it in an area that's inside to firm back up, I wouldn't place it outside due to the difficulty of getting rid of dirt on it. Dirt tends to leave marks when swept off. http://patrickengman.com
SylvesterPotter Senior Member 673 posts Likes: 27 Joined Jan 2012 More info | Jan 17, 2012 10:09 | #5 |
Jan 17, 2012 12:59 | #6 EOSBoy wrote in post #13719100 Hmm, unless you can place it in an area that's inside to firm back up, I wouldn't place it outside due to the difficulty of getting rid of dirt on it. Dirt tends to leave marks when swept off. After months of use, I haven't had wrinkles like this. Actually, my studio had a little leak during a big storm and the bottom part of my backdrop got all lumpy due to humidity so I cut it off. Even when you leave the BG with some slack, it shouldn't look like that. You should probably have it returned. got it thx http://somephotosmiami.com
| Latest registered member is semonsters 1588 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
