Thread started 18 Jan 2012 (Wednesday) 12:45
Studio - Continuous or Flash Light??
General_T
Joined Aug 2011
Jan 18, 2012 12:45 |  #1
Hi,
I am in the process of putting together a small home studio to use on my family as well as for photos of items (product shooting?).
Anyway, I have read a lot of the material on this forum and am a bit confused.
In my mind I was just planning on getting one of those octa box things with around a 250watt light and a reflector as a continuous light source - maybe an umbrella or 2?. I would then use my speedlite as a fill light.
But I see a lot of setups were they only appear to be using 2-3 speedlites and no continuous light source?
Can you tell me how to proceed - should I just get another speedlite or 2 or should I invest more in continuous lighting - or strobes - umbrellas - octa thingies?:lol::lol:
Canon 5D Mk III | 24-105 F4 L IS USM | 100 F2.8 L Macro IS USM | 70-200 MK II F2.8 L IS USM|580 EX II
mguffin
Gallery: 17 photos
Jan 18, 2012 12:58 |  #2
Continuous lighting gets hot.
Mike
Nikon D800 ~ Nikon D500
Sigma 35 f/1.4 DG ~ Nikkor 50 f/1.8G ~ Nikkor 85 f/1.8G ~ Nikkor 12-24 f/4 DX ~ Nikkor 17-55 f/2.8 DX ~ Nikkor 70-200 f/2.8 VR ~ Sigma 18-35 f/1.8 DC ~ Sigma 50-100 f/1.8 DC
EOSBoy
Jan 18, 2012 13:03 |  #3
General_T wrote in post #13726130 (external link)
Hi,
You may see that some photogs have strobes that have modeling lights which are continuous lights that help aid you visually in placing your light but they aren't necessarily used to actually light the subject.
You could buy some Vivitar 285HV speedlites on the cheap and use them for fill or BG lights. I'd shoot the backgrounds with 2 bare speedlites and have another speedlite set up with an umbrella for the key light. You can then use a reflector to lift the shadows.
http://patrickengman.c​om (external link)
Instagram: brotherly_dove
Rolleiflex 3.5F Planar
General_T
Joined Aug 2011
Jan 18, 2012 13:06 |  #4
EOSBoy wrote in post #13726237 (external link)
Hi,
Thanks.
So I could either buy more speedlites or a dedicated strobe light, without the need for continuous lighting?
EOSBoy
Jan 18, 2012 13:31 |  #5
General_T wrote in post #13726264 (external link)
Hi,
Thanks.
Correct. There are cons to having continuous lighting.
- They get HOT! I mean insanely hot if you need the power to light a scene that measures, say f/8-f/16 or so
- They require a lot of power
- Color temperature can vary
- Expensive if you want higher quality units
You can't go wrong with www.alienbees.com (external link)
Additional speedlites wouldn't hurt, either but if you find yourself shooting in a controlled environment, dedicated strobes will probably benefit you more.
Curtis ­ N
Master Flasher
Jan 18, 2012 15:22 |  #6
Go with strobes.
Thank me later.
drvnbysound
Jan 18, 2012 17:40 |  #7
Continuous lights and speedlights are easy to discern - however, I see the terms strobe and monolight used quite a bit as well... Can anyone explain the differences?
For example... the PCB website lists the AB400 as a "studio flash," yet it seems that Elinchrom's models are referred to as monolights.
What are the pros/cons of using either?
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
Player9
Jan 18, 2012 19:18 |  #8
Get strobes.
60D, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
mikeca42
Joined May 2011
Jan 18, 2012 19:48 |  #9
drvnbysound wrote in post #13728011 (external link)
The terms "speedlights", "speedlites" or "flashes" refers to a battery powered flash that can be attached to your camera hotshoe or used off camera. The most powerful of commonly used ones produce 60-80 w/sec output. There are a few expensive, higher powered ones.
The term "strobe" usually refers to a AC powered flash that cannot be attached to your camera. There are some battery powered strobes also, but they are big batteries. Strobes usually produce 100-1000+ w/sec output.
The term Monolight refers to a single unit strobe. It has the flash and all the control functions in a single enclosure. There are "pack and head" based lighting systems, like the Paul Buff Zeus lights, that have controls for several lights in a pack that sits on the floor connected to one or more flash heads by cables. These pack systems are not to be confused with battery packs, although some manufactures make pack and head based systems with a battery in the pack. (The Zeus packs are AC powered).
tefu
Jan 18, 2012 22:00 |  #10
what would be the good strobes to buy? and where?
Facebook >page< (external link), 'Like' it and share it.
http://syphoto.weebly.​com/ (external link)
http://www.flickr.com/​photos/sy_photography/ (external link)
Curtis ­ N
Master Flasher
Jan 18, 2012 22:20 |  #11
Search this forum (and maybe Google) for the following terms:
Alienbees
Elinchrom D-Lites
Calumet Genesis
Viva-photography
Jan 18, 2012 22:52 |  #12
strobies! I'm talking about speedlites, alienbees, rangers.
Definitely go for the quick flash ones. Your subjects will be WAY more comfortable. I've seen it when I switched over.
jaredholtphoto.com (external link)
Canon 5D Mark II// Canon 85mm f/1.8//Sigma 35mm f/1.4//Canon 70-200 f/4L
General_T
Joined Aug 2011
Jan 19, 2012 08:50 |  #13
Hi,
Thank you all for your replies thus far.
OK. I'm sold on the dedicated strobe/monolight. I guess I am leaning towards the Alien Bees 400 (as I have (or will have once I finish it) a small studio). Aside form cost does anyone know why I would use Elinchrom over Alien Bees?
Also, of course I cannot buy an AB400 locally. My store sells Bowens - anyone know anything about those? Mind you I am definately leaning towards the AB400 x 2 (call me crazy but I like the look of them in the yellow or green - apparently I am a marketers dream!!:lol::lol:)
Thanks again
mtimber
Jan 19, 2012 08:54 |  #14
Elinchroms (the bxri's) at least can be controlled remotely.
So you can control the power settings from your camera, or indeed anywhere in the studio if you have a second trigger in your pocket.
That is incredibly useful.
Look for a system that is compatible both up and down the product chain.
The thing to watch with Ellies though is that the branded modifiers are VERY expensive albeit very popular.
Although there are plenty of decent 3rd party modifies on the market for them.
"You have the right to remain silent. Anything you say will be misquoted, then used against you" (Belmondo)
PhotosGuy
Joined Feb 2004
Jan 19, 2012 10:08 |  #15
... as well as for photos of items (product shooting?).
Well, now you've made your choices a lot harder. What "products"?
Are you shooting a ton of them where a light box is a handy thing to have? Another DIY light box, with build and test pics
...or just one or two? And do they have highly reflective surfaces? You'll get more control if you look at the knife & Browning threads here: FAQ - Studio Lighting
Product Photography - What do I need to get started?
3,574 views & 0 likes for this thread
Latest registered member is hanhasgotqi
714 guests, 266 members online
