Does any one know the dimensions of the case that comes with the Sigma 30mm?
match14 Senior Member 362 posts Likes: 2 Joined Dec 2009 Location: United Kingdom More info | Jan 18, 2012 13:46 | #1 |
Raylon Goldmember 1,078 posts Joined Sep 2010 Location: Plainfield, IL More info | Jan 18, 2012 13:54 | #2 match14 wrote in post #13726508 Does any one know the dimensions of the case that comes with the Sigma 30mm? Thanks It's pretty big. I had one. If someone can get you the box dimensions, the case basically fills the entire box. 7D l Canon 70-200 f/4L IS l Canon 85mm f/1.8 l ∑ 17-50 f/2.8 l Canon 50mm f/1.8 II l S95
NobodyWeirdLikeMe Senior Member 374 posts Likes: 33 Joined Feb 2009 Location: Norway More info | Mine seems to be roughly 13,2 cm x 11 cm x 11 cm. Christine
Jan 19, 2012 03:05 | #4 |
Unregistered.Coward Senior Member 884 posts Joined Oct 2010 Location: Looking thru the viewfinder More info | Jan 19, 2012 04:41 | #5 The 30mm shares the same case as the 50mm, Also the 24 macro. 4.25" x 4.24" x 5.25. ....the best camera is the one you have on you at the time.
| Latest registered member is semonsters 915 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
