Thread started 21 Jan 2012 (Saturday) 14:10
CS5 layers problem
hania
Jan 21, 2012 14:10 |  #1
Weird problem today - doing layers as usual, but have found, on putting a new sky in, I can see faint shadow of the layer below - even though I used a layer mask to remove old sky.
Both photos taken with a 5D & 16-35 lens.
Any ideas?
main photo: 1/125 f11 24mm iso 400
sky: 1/80 f22 33mm iso 200
Damo77
Jan 21, 2012 14:24 |  #2
Was your brush tool at 100% when masking?
Damien
Website (external link) | Facebook (external link)
hania
Jan 21, 2012 14:33 |  #3
Damo77 wrote in post #13743787 (external link)
yes - thats why I can't understand it.
I deleted all my layers and re-did from the beginning - still the same result - nothing to do with different iso???
I just wonder - if my black isn't true black will that make a difference (following on from that, it looks black to me, but is it?)
DunnoWhen
Jan 21, 2012 14:41 as a reply to  @ hania's post |  #4
Have you been bitten by a spider recently :-)
My wisdom is learned from the experience of others.
D ­ Thompson
Jan 21, 2012 14:47 |  #5
Blending mode? Also, were you painting on the mask with either total black or total white?
Dennis
Canon 5D 20D
I have not yet begun to procrastinate!
hania
Jan 21, 2012 14:51 |  #6
D Thompson wrote in post #13743884 (external link)
blending mode - normal, total black (100%)
I've done it lots of times before which is why its puzzling me.
hania
Jan 21, 2012 14:52 |  #7
DunnoWhen wrote in post #13743858 (external link)
Nice one..............but not too sure re the spider reference
tonylong
...winded
Gallery: 60 photos
Jan 21, 2012 14:53 |  #8
Blend mode Normal, Opacity 100%, Fill 100%?
Tony
hania
Jan 21, 2012 14:58 |  #9
tonylong wrote in post #13743908 (external link)
yep.
can do screenshot ?
ohata0
Jan 21, 2012 14:59 |  #10
what happens if you hide the layer below? Can you see the checkboard background?
how exactly do you have the layers set up? Is the Main photo above the sky layer or is it the other way around?
You can check if your black is pure black by clicking on the foreground color and making sure it's 0 0 0. If you're checking the color in the mask, use the info window and check the "K" value of the mask. 100% is black 0% is white. Make sure the mask is selected though.
tonylong
...winded
Gallery: 60 photos
Jan 21, 2012 15:04 |  #11
hania wrote in post #13743922 (external link)
yep.
can do screenshot ?
Sure, do a screen shot of your layers panel, and maybe a crop of your image showing the actual problem!
Tony
hania
Jan 21, 2012 15:10 as a reply to  @ hania's post |  #12
have done a screen shot - you can just see the shadows of the trees on right (trunks still visible on main photo)
hania
Jan 21, 2012 15:20 |  #13
ohata0 wrote in post #13743927 (external link)
can see chequerboard background.
sky layer below main photo
not sure what should be 000.
don't know how to find 'K' value of mask
D ­ Thompson
Jan 21, 2012 15:24 |  #14
hania wrote in post #13744011 (external link)
Make your Background copy 2 active and click on the mask. Select the Info tool. Make sure you can see the Info panel. Look at the values, RGB should all be 0. Move the eyedropper over different parts where the tree is bleeding thru.
Dennis
Canon 5D 20D
hania
Jan 21, 2012 15:33 |  #15
D Thompson wrote in post #13744027 (external link)
in mask :
For black have : c 0% Y 0% m 0% k 97%
white c 0% y 0% m 0% k 1%
can't find RGB
hang on : went into 'colour' F6 - and my black was only 97% black - will have a look at it once I have filled with 'proper' black
1,853 views & 0 likes for this thread
CS5 layers problem
Latest registered member is Mortspanx
850 guests, 347 members online
