I am looking for a bag to carry 2 to 3 external 3.5" hard drives at the same time. Some kind of protection (like padding) is highly appreciated. Anybody any ideas? Thanks
Daan37 Senior Member 414 posts Joined Apr 2008 Location: Netherlands More info | Jan 22, 2012 11:52 | #1 I am looking for a bag to carry 2 to 3 external 3.5" hard drives at the same time. Some kind of protection (like padding) is highly appreciated. Anybody any ideas? Thanks Canon + Elinchrom | www.daanbarnhoorn.nl
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Jan 22, 2012 12:09 | #2 I use a pelican case to carry my hard drives that I use for backup. Works a charm. Doc Klepper in the USA
Jan 22, 2012 12:29 | #3 rklepper wrote in post #13748254 I use a pelican case to carry my hard drives that I use for backup. Works a charm. Thanks for the tip. Haven't thought about those. Which type are you using? Canon + Elinchrom | www.daanbarnhoorn.nl
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jan 22, 2012 15:20 | #4 I would second a small pelican case. Don has a pic I believe I have seen him post of his setup, let me see if I can find it before he posts it here.... Thats by far the best option IMO. [Gear List | Flickr
Jan 23, 2012 12:46 | #5 ben_r_ wrote in post #13749159 I would second a small pelican case. Don has a pic I believe I have seen him post of his setup, let me see if I can find it before he posts it here.... Thats by far the best option IMO. Edit: Here is it: LINK Looks good. It would still be helpful to know the type. There are A LOT of different Peli cases to choose from Canon + Elinchrom | www.daanbarnhoorn.nl
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jan 23, 2012 13:17 | #6 PM rklepper and ask him! [Gear List | Flickr
Unregistered.Coward Senior Member 884 posts Joined Oct 2010 Location: Looking thru the viewfinder More info | Jan 23, 2012 13:49 | #7 What kind of transport are we envisioning? ....the best camera is the one you have on you at the time.
Jan 25, 2012 09:45 | #8 In case somebody else wants to know... Doc's Peli case (in the linked pic) is the 1450 type. I got one myself and it is perfect for storing / carrying 5 to 6 x 3.5" HDD's. Case closed Canon + Elinchrom | www.daanbarnhoorn.nl
flash69 Senior Member 320 posts Joined Dec 2006 Location: Austin, TX More info | Jan 25, 2012 13:17 | #9 Daan37 wrote in post #13765744 In case somebody else wants to know... Doc's Peli case (in the linked pic) is the 1450 type. I got one myself and it is perfect for storing / carrying 5 to 6 x 3.5" HDD's. Case closed ![]() Thank you for this information. I was in need of something for my G-Drives. What type of drives are you using? Canon R5
SYS Cream of the Crop More info | Jan 25, 2012 13:34 | #10 Daan37 wrote in post #13765744 In case somebody else wants to know... Doc's Peli case (in the linked pic) is the 1450 type. I got one myself and it is perfect for storing / carrying 5 to 6 x 3.5" HDD's. Case closed ![]() I have several 6.2 x 4.9 HDD's, and I'm wondering approximately how many of these that I can fit in that 1450 type Peli with of course the foam dividers...
Jan 25, 2012 15:48 | #11 flash69 wrote in post #13766829 Thank you for this information. I was in need of something for my G-Drives. What type of drives are you using? WD / Lacie 3.5" external drives. Mixed bunch. But sizes are roughly similar around 7.5" x 4.5" x 1.5". Canon + Elinchrom | www.daanbarnhoorn.nl
Jan 25, 2012 15:54 | #12 SYS wrote in post #13766926 I have several 6.2 x 4.9 HDD's, and I'm wondering approximately how many of these that I can fit in that 1450 type Peli with of course the foam dividers... I place the HDD on their sides (like in Doc's pic). The 4.5" is a tight fit. I am not certain if you'll be able to close the 1450 with 4.9". But if you are able, you can fit at least 5 HDD's, possibly even 6 (depending on how you place them). Hope this helps. Canon + Elinchrom | www.daanbarnhoorn.nl
Jan 25, 2012 15:57 | #13 BTW The 1450 comes with 'pick and pluck' foam. You can tailor the entire lay-out of the foam to your liking. There aren't any dividers that you can move around like you have in photo bags. Once you have plucked the foam, it is final (unless you want to glue parts together again). There are spare P&P foam sets available though. Canon + Elinchrom | www.daanbarnhoorn.nl
SYS Cream of the Crop More info | Jan 26, 2012 07:42 | #14 Daan37 wrote in post #13767647 I place the HDD on their sides (like in Doc's pic). The 4.5" is a tight fit. I am not certain if you'll be able to close the 1450 with 4.9". But if you are able, you can fit at least 5 HDD's, possibly even 6 (depending on how you place them). Hope this helps. Thanks. I'm assuming you now have the Peli 1450...
Jan 26, 2012 12:24 | #15 SYS wrote in post #13771231 Thanks. I'm assuming you now have the Peli 1450... Yep. Canon + Elinchrom | www.daanbarnhoorn.nl
| Latest registered member is zachary24 1370 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
