Thread started 22 Jan 2012 (Sunday) 15:19
Dropped my 24-105!!!
canonguy14
Joined May 2011
Jan 22, 2012 15:19 |  #1
I've read numerous posts about dropped gear and never thought it would happen to me.
Well...............it did!
I dropped my 5DII and 24-105 today onto ceramic tile. The lens too all of the impact and shattered the UV filter. It bent the filter in on one side so that there's no way for me to remove it.
The frone element has a few small scratches on it but that seems to be it.
The lens still zooms in like normal and the IS and focusing seem fine.
2 questions:
1. Do I need to send it to Canon to have them remove the old filter ring?
2. Should I send it to canon just incase the optics are screwed up. If so, how much does this typically run?
I have not taked any shots with the lens to see if the focus is off or not.
Canon 5D MkII x 2 | Canon 35mm f/1.4L | Sigma 85mm f/1.4 | Canon 100mm f/2.8L Macro | Canon 17-40mm f/4L | 600EX-RT x 2 | 580EXII | AB800
Alex J. Photography (external link)
Facebook (external link)
DreDaze
Gallery: 49 photos
Jan 22, 2012 15:28 |  #2
the guy in this thread removed the old filter with a sawzall...unfortunatel​y the video no longer works :) there are other tips in there that people gave:
https://photography-on-the.net …1088576&highlig​ht=sawzall
this guy just used some vice grips to twist it off
http://vimeo.com/26705​583 (external link)
good luck
Andre or Dre
gear list
Instagram (external link)
SMP_Homer
Gallery: 29 photos
Jan 22, 2012 15:34 |  #3
Wonder if the filter's sharp pieces damaged the front element?
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
ed ­ rader
"I am not the final word"
Jan 22, 2012 15:56 as a reply to  @ SMP_Homer's post |  #4
i'd send it to canon or sell it on ebay as-is. i recently had my 24-105L calibrated and cleaned. i paid the minimum charge of $269. shipping was another $24.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
canonguy14
Joined May 2011
Jan 22, 2012 16:45 |  #5
ed rader wrote in post #13749293 (external link)
ed rader
Yikes!!
I need an all purpose zoom. This one has been a workhorse for me for the past 18 months.
Only issue I have is getting the filter(what's left of it) off. I don't want to put any more pressure on it than needed but I also don't want to pay $300 to have it removed.
I took a few shots with it just now and it seems fime. IS works, lens zooms and it seems like it's focusing properly.
AbPho
Jan 22, 2012 16:49 |  #6
If everything still works then do not send it in. If it starts acting up then send it it.
You might have to get rough in order to get that filter housing off. Watch that you don't ruin the front lens element. Maybe put some masking tape on it just to be safe.
I'm in Canada. Isn't that weird!
Vixen89
Jan 22, 2012 16:50 |  #7
why no lens hood was on it D:<
I'm actively lazy!! :D | Gear List | photovxn.com (under construction)external link
canonguy14
Joined May 2011
Jan 22, 2012 17:07 |  #8
Vixen89 wrote in post #13749545 (external link)
Just took it out of my messenger bag. The lens hood was in my other hand....:cry:
John_T
Gallery: 127 photos
Joined Jun 2003
Jan 22, 2012 17:17 |  #9
More than likely the lens is just fine.
To remove the filter ring, maybe try the traditional methods first.
- put a wide rubber band around the ring to give you extra grip and try to twist it off
- if you have got steady hands and the guts, wrap a cloth over the front of the lens, exposing just a little piece of the filter ring. Take a pair of pointed pliers and with the tips of the pliers get a hard grip on the ring without pushing downward and twist the pliers in a circle, twisting an S form in the ring. The ring should now be loose and twist or lift out easily.
- take it to a local camera shop. They do this kind of thing all the time, and will probably use one of the foregoing methods for ten bucks, but taking no liability.
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
canonguy14
Joined May 2011
Jan 22, 2012 17:38 |  #10
John_T wrote in post #13749677 (external link)
I chose option 2!
Masking tape over the element, a pair of vice grips and a disturbed look on my wifes face. The filter ring is now off.
The threads on my lens are stripped. In the spot where the filter caved in. This means I'll need a fix on it to use another filter.
This Guy = Not Happy.
ed ­ rader
Jan 22, 2012 17:40 |  #11
canonguy14 wrote in post #13749520 (external link)
Yikes!!
you can buy the 24-105L used for around $800 and since your still works fine i'll bet you could get $6-700 for it on ebay. that's what i'd do.
ed rader
AbPho
Jan 22, 2012 17:44 |  #12
Cheaper to repair it.
John_T
Gallery: 127 photos
Joined Jun 2003
Jan 22, 2012 17:49 |  #13
Nah, be happy, you have added a hunk to your photographic experience. :D
Your lens is fine, you don't need any filter but a cirpol, as you have just found out, and I'll bet you can scrape out the place where the threads are stripped and a cirpol will go in just fine, when you need it that is.
rick_reno
Jan 22, 2012 18:20 |  #14
that filter will come out, tape up the glass and some needle nose pliers.
phreeky
Jan 22, 2012 18:31 |  #15
canonguy14 wrote in post #13749779 (external link)
I chose option 2!
Can you take a photo of the thread? Is it actually damaged badly? Simply turning another filter onto it may clean the threads up enough.
8,750 views & 0 likes for this thread, 23 members have posted to it and it is followed by 2 members.
705 guests, 129 members online
