Thread started 24 Jan 2012 (Tuesday) 17:53
Focus comparison between 1d3 and 5d2, question
lawdog2k
Joined May 2011
Jan 24, 2012 17:53 |  #1
Bear with me, I'm on my phone while cooking supper. I was shooting stationary subjects with both the 5d2 and 1d3 with a flash, ISO 100, same aperture and shutter speed. The 5d2 was sharp whereas the 1d3 was not. Am I expecting too much from the 1d3. I always heard how bad the 5d2 was at AF where the 1d cameras were smoking. What gives? I'll get pics up after I eat.
A guy with a couple cameras, some lenses, and accoutrements
Freelance for Magazines
Gear&Feedback | Flickr (external link) | Website (external link)
Virto
Joined Nov 2010
Jan 24, 2012 17:56 |  #2
If you're using center-point, single-shot, they will have identical focus. The issue with 5D focus stems from the outer points and the fairly slow AF lock speed, not the center point in good light.
Are you sure it's a focus issue? Different cameras require different post processing. When I got a 40D, I thought it was horribly soft, but it just needs a good kick in the tail in the sharpening department.
There is the chance that your focus is off slightly with the 1D3 and that you might need to do a little microadjusting.
The 1D3 should be far more capable overall at focus than the 5D, but it can be a bit of a challenge to get used to. You should also verify that it falls in a serial number range after the focus fix.
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
Killjoy
Jan 24, 2012 18:41 |  #3
^ What he said. The different cameras need different post processing.
I may just be technique.
Some people hunt with a gun. I use a Canon.
My Smugmug (external link) page
All I ask is a chance to prove that money can't make me happy.
lawdog2k
Joined May 2011
Jan 24, 2012 18:48 |  #4
It is in the affected serials, but I have the paper from canon where the repair was done. I'll get comparative photos up in a minute.
lawdog2k
Joined May 2011
Jan 24, 2012 19:36 |  #5
Here's a couple quick shots. Kids got me busy tonight.
first with mkiii
Exposure 0.005 sec (1/200)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 100
Exposure Bias 0 EV
Flash On, Fired
1dmkiii-1 (external link) by ronnieyeates2 (external link), on Flickr
Then with 5dmkii
Aperture f/1.4
Focal Length 50 mm
ISO Speed 100
Exposure Bias 0 EV
Flash On, Fired
5dmkii-2 (external link) by ronnieyeates2 (external link), on Flickr
You can click and go to my flickr to see full-size…. I don't wanna get in trouble for humongous pictures. So, with these quick shots, is the 1diii going to be that much softer than the 5dmkii? am i just expecting more than I should… I'm going to shoot more pictures when I have better light and don't have to depend on a flash. But, I was thinking these things were beast when it came to focus.
Am I needing to customize the functions a bit to get what I am expecting? I shot those with center point, one shot, with ETTL, focusing just on the left edge of the badge.
danjama
Joined Oct 2011
Jan 24, 2012 19:47 |  #6
Both look good to me.
http://www.flickr.com/​photos/danjamafotos/ (external link)
Canon T3i Gripped/100-300 4.5-5.6 USM/28-80 3.5-5.6/35-105 4.5-5.6 USM/18-55 3.5-5.6 IS/Helios 44-2 Manual/Miranda 28mm 2.8
lawdog2k
Joined May 2011
Jan 24, 2012 20:12 |  #7
Here's some SOOC. Just sharpened standard by LR and by Export for Screen sharpening. Ideas? Thoughts? thanks!
Exposure 0.003 sec (1/300)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 1000
Exposure Bias -1/3 EV
Flash On, Fired
Focus on Door handles
RY_20098 (external link) by ronnieyeates2 (external link), on Flickr
Exposure 0.013 sec (1/80)
Aperture f/2.0
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
Flash Off, Did not fire
focus on his right eye (camera left)
RY_20073 (external link) by ronnieyeates2 (external link), on Flickr
Exposure 0.017 sec (1/60)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
focus to right of badge
RY_20082 (external link) by ronnieyeates2 (external link), on Flickr
Exposure 0.01 sec (1/100)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
focus on left eye (camera right)
RY_20072 (external link) by ronnieyeates2 (external link), on Flickr
Exposure 0.003 sec (1/320)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 3200
Exposure Bias 0 EV
focus on her face
RY_20087 (external link) by ronnieyeates2 (external link), on Flickr
Killjoy
Jan 24, 2012 20:41 |  #8
lawdog2k wrote in post #13762843 (external link)
first with mkiii
Aperture f/1.4
Focal Length 50 mm
ISO Speed 100
Exposure Bias 0 EV
Flash On, Fired
Then with 5dmkii
Aperture f/1.4
Focal Length 50 mm
ISO Speed 100
Exposure Bias 0 EV
Flash On, Fired
Not the same photo. You were closer with the 1DMkIII, so your depth of field is going to be narrower. I see that it's tack sharp at points. Can you show us a screen capture of where the focus point is striking?
Killjoy
Jan 24, 2012 20:42 |  #9
lawdog2k wrote in post #13763077 (external link)
Aperture f/1.4
Focal Length 50 mm
ISO Speed 1000
Flash On, Fired
Aperture f/2.0
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
Aperture f/1.4
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
Aperture f/1.4
Focal Length 50 mm
ISO Speed 2000
Exposure Bias 0 EV
Aperture f/1.4
Focal Length 50 mm
ISO Speed 3200
Exposure Bias 0 EV
focus on her face
I didn't re-post the images to save bandwidth, but they all look great to me.
Killjoy
Jan 24, 2012 21:04 |  #10
One more question.....
Have you done a micro focus adjust with that same lens on both cameras?
When you try that shot with the hat again, mount your camera on a tripod, and make sure your subject doesn't move.
Take your shot, then change cameras on the tripod and re-shoot. Let's compare those two images.
ejenner
Gallery: 98 photos
Joined Nov 2011
Jan 24, 2012 21:31 as a reply to  @ Killjoy's post |  #11
Also take both shots with manual focusing in Live View (on a tripod) using x10 magnification to make sure it is the AF and not the camera/sensor.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
jase1125
Jan 24, 2012 21:38 |  #12
For the record the 50 1.4 wide open isn't known for being exceedingly sharp. Pick a different lens or stop down to F2 for a better comparison.
Jason
lawdog2k
Joined May 2011
Jan 24, 2012 21:48 |  #13
Killjoy wrote in post #13763259 (external link)
The cameras were right about the same distance from the hat. Hat didnt move, cameras at darn near same spot on desk. There is a difference in frame between the two.
I'll have to figure out a way to mount the 1d3 because all I have are ball heads with rrs clamps. I didn't want to buy a 180 l plate before I decided to keep he camera.
I've done no microadjustments on either camera.
I'll take 1d to car show this weekend and shoot with 24-70 or 24-105 and see what I get.
Thanks for the input. I'll do some more tinkering.
TooManyShots
Jan 24, 2012 22:00 |  #14
If there is a problem, it is probably user error. My 1dmarkIII is my main body for shooting fast moving cycling races. The speed and accuracy the body can pickup the subjects while moving fast and at close range will scare the crap out of you. This is one thing I will not subject my 5dmarkII to. It is just inhuman...:)
One Imaging Photography (external link) and my Flickr (external link)
Facebook (external link)
jhayesvw
Gallery: 167 photos
Jan 24, 2012 22:03 as a reply to  @ TooManyShots's post |  #15
it could very well be a lens/body combination "issue". I use quotes because it does focus well.
a little microadjust could be all you need.
My Flickr (external link)
1,909 views & 0 likes for this thread, 10 members have posted to it.
Latest registered member is ShelbyJefferson
1334 guests, 174 members online
