Thread started 25 Jan 2012 (Wednesday) 16:32
7D AF modes for wildlife
MCAsan
Joined Jun 2010
Jan 25, 2012 16:32 |  #1
If we enable all 5 AF modes we can select from
  • single spot AF
  • single point AF
  • single point with expansion
  • zone
  • 19 point AF
I was wondering which will be the best default for wildlife...single point with expansion or zone. Has anyone played enough with these AF modes to have opinions which make the best defaults for general wildlife (or sports) and which for fast action such as birds in flight?
sweetlu60
Jan 25, 2012 20:13 |  #2
Never thought of it that much, but I would think it depends on your shooting style and subject. For mammals and other critters that are a little slower, I typically use the spot or the point, and I am pretty quick with the dials to be able to select which point I want to use. This last weekend though, I was taking bird pictures and I was moving more to the zone system to give me a larger coverage area to catch birds in flight.
Steven Lewis
Western Skies Photography (external link)
Scott_online
Gallery: 136 photos
Best ofs: 7
Jan 26, 2012 02:59 |  #3
I find single point w/ expansion (in conjunction with AI Servo and back-button focus) works well in nearly all cases. I sometimes switch to spot if I'm having trouble locking on.
I've tried zone in certain circumstances (e.g. birds or planes against clean backgrounds) but the advantage of single point w/expansion is that you choose the target point, such as the eye, whereas with zone it just focusses on whatever is closest within the zone, which might be a wingtip.
(FWIW, the AF performance of my 7D using single point w/ expansion is significantly better than that of my 1D4 in the same mode. I think with the 7D you have to get a lock with the selected point before it will hand off to the assist points, whereas it seems that the 1D will use any of the enabled points to get an initial lock, making it no better than zone on the 7D).
asavani
Jan 26, 2012 03:03 |  #4
check out this thread:
https://photography-on-the.net …/showthread.php​?t=1138397
www.adnansavani.zenfol​io.com (external link)
Canon EOS 7D and Canon EOS Rebel XSi
15-85mm 3.5-5.6 IS, 100-400mm 4.5-5.6 L IS
Vanguard Alta pro 263 AT with SBH-100 ball head
http://adnansavani.pho​tography.com (external link)
2,225 views & 0 likes for this thread, 4 members have posted to it.
913 guests, 119 members online
