stephan902 wrote in post #13782520
Okay, you perfectly understand what i want: I zoom for all occasions when i don´t want to swap lenses constantly.
As i do not already own the 50mm 1.4 and 28mm 1.8, I am not sure if i´d still need a 2.8 zoom lens or 4.0 is enough.
So if I wanna stay with 2.8 I´d take the 17-55mm and if not i´d go with the 24-105mm?
The 15-85mm is not what i want since it is even darker than the 24-105 is!
With also having 3 primes between 20 and 100mm, what would you recommend?
I'm going to be blunt here, The 24-105 is not what you want on a cropper, The range starts at a 38mm equivalent and it makes a pretty "bleh" walkaround for when you want to slap one lens on and just work with it...
The 15-85 is every bit as capable, Yes its a stop darker at 85mm, but its the best walkaround "slap a lens on and go for it" lens i have used for APS-C, and I've used it plenty of times in low crappy light, The IS works very well, So if you're not shooting something moving the fact its f/5.6 really isnt that big of an issue (FWIW, I have used it down at 1/8 at 85mm and gotten good results out of it) and i personally think its one of the best focusing lenses Canon ever put out
I've owned both, And the 17-55, and the Tamron 28-75 And spent time playing with the 24-70 Brick before
The idea behind the way i have my system setup is that if its not moving/i just want one lens on the camera, I grab the 15-85 and just go for it, IF i might need the isolation, i can easily toss the 28mm or even the 50mm in my pocket and end up with a more versatile setup than I'd have with JUST an f/2.8 zoom..
Between the primes, For portraits grab the 50mm, the focal length is going to give a more pleasing perspective as well as more background compression, For more general usage, the 28mm is nice to have as well.... I find the 100mm too long as a "general" usage thing...
For me, No prime can replace my zooms, and no zooms can replace my primes, They're just different tools for different situations to me, Zooms are for versatility and my primes are my specific targeted weapons
