Thread started 31 Jan 2012 (Tuesday) 04:42
OCF HSS, what triggering options do I have?
Xcelx
Joined Sep 2009
Jan 31, 2012 04:42 |  #1
Hello!
I'm interested in trying out HSS when shooting outdoor portrait . I'd just use a simple setup with speedlite/s and shoot through white umbrellas for fill. What kind of triggering options are there, how is the ST-e2/yongnuo eqvivalent outdoors? What's the most reliable solution?
I mainly use a 5D and 85 1.8, 200 2.8 for outdoor portraits.
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jan 31, 2012 04:51 |  #2
The best is currently the Phottix Odin, but it will only work with Canon and Nissin speed lights, not the Yongnuo's.
There is Pocket Wizards which are also reliable, but not as functional.
Both are great options if you want something reliable and well built.
Radio Poppers work well, but require a master flash or the ST-E2 on camera.
Then you get a range of a low quality products from China, some are ok, some not.
Ok for limited use if your on a budget.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
DHPHOTO66
Joined Jan 2012
Jan 31, 2012 10:53 as a reply to  @ Moppie's post |  #3
How about Pixel king? Cant forget these little gems....:D
Uncle Donn | http://www.flickr.com/​photos/dhphoto66/ (external link)
OneJZsupra
Jan 31, 2012 11:30 |  #4
Why not get a ND filter to get to sync speeds? That way you won't loose tons of power from HSS.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Jan 31, 2012 11:36 |  #5
seoul4korea wrote in post #13800528 (external link)
This along with the realization that you dont absolutely need to shoot wide open to make good images.
dmward
Gallery: 29 photos
Jan 31, 2012 16:04 |  #6
gonzogolf wrote in post #13800550 (external link)
The "loads of power" is two stops.
Its likely stopping down or applying an ND filter will absorb that much light or more.
The key is getting the Speedlite close to the subject.
Xcelx
Joined Sep 2009
Feb 02, 2012 02:51 |  #7
Thanks for the suggestions, I have to look more into the Odin alternative :)
Could be an option but I'm worried about camera shake using the 200mm for portraits. I don't want to darken the viewfinder too much either.
Point taken, but on some occasions I really wish I could shoot wide open and I want to keep the possibility of doing so if I want to.
OneJZsupra
Feb 02, 2012 08:39 |  #8
So at F2.8 1/250th of a second and you're worried about camera shake? Do you have problems holding cameras or anything for a long time? This is an actual question because you could try using a monopod if you need the support.
DHPHOTO66
Joined Jan 2012
Feb 02, 2012 10:06 |  #9
Xcelx wrote in post #13799070 (external link)
Hello!
www.youtube.com/watch?​v=dHQp2OP_xv4 (external link)
1,125 views & 0 likes for this thread, 6 members have posted to it.
1398 guests, 108 members online
