Hi there,
Any recommendation on portable printer that will fit the needs for photobooth/photo station in events? Fast 4x6 printing is a requirement. Ink efficency is another. I guess.
Thanks for your help.
nonick Goldmember 1,588 posts Joined Jun 2009 Location: NYC More info | Feb 01, 2012 09:34 | #1 Hi there, Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
robn70 Member 55 posts Likes: 2 Joined Nov 2011 Location: Central, VA More info | Feb 01, 2012 12:15 | #2 We use a Hiti 510s Dye-Sub for events and a photobooth.
Feb 02, 2012 17:40 | #3 Thanks. I set my eyes on this one as well. But I just want to find out want my options are besides of that. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
robn70 Member 55 posts Likes: 2 Joined Nov 2011 Location: Central, VA More info | Feb 03, 2012 13:56 | #4 There is a lot of good info on the photobooth talk forum. www.photoboothtalk.com
JUNNEL20 Junior Member 23 posts Likes: 1 Joined Dec 2011 More info | Feb 13, 2012 07:46 | #5 I use a DNP RX1 printer.
TaggM Senior Member 250 posts Joined May 2010 Location: Phoenix, Arizona metro More info | Feb 19, 2012 11:39 | #6 nonick, for luggable non-ink printers, I've found:
These all take about 1 ppm, give or a take some seconds. I'd love to find battery a powered, PictBridge compatible, dye-sublimation, single-pass, compact printer closer to 450 dpi, faster than 2 ppm, closer to an e-reader in size, and under 3 pounds. It'd be really nice if its total start-up price was at most the same as the CP-800 and Charm. I'm curious to learn what you decide upon. I have Canon gear. SX1 IS, two 7D bodies and mostly f/2.8 lenses 10mm-200mm, doubler, and 17/4 TSE, some 580EX IIs. Additional portable lighting gear, and tripod with 360 pano mount. Want two 7D II bodies.
Feb 19, 2012 12:56 | #7 Great topic!! JUNNEL20 wrote in post #13877833 I use a DNP RX1 printer. Hows the ink/ribbon cost? Seems like a sweet setup!! No 8 x 10..? Proimages.com
orena Senior Member 544 posts Likes: 1 Joined Sep 2009 Location: eilat, israel/ chicago More info | Feb 19, 2012 13:10 | #8 is it bad to use a canon pixmapro 9000 for events? i just got one and plan to use it for everything Always do right, this will gratify some people and astonish the rest.
ChadAndreo Goldmember 1,879 posts Likes: 15 Joined Nov 2006 Location: WPB, FL More info | Dec 01, 2012 05:17 | #9 What printer are you guys using now? Photographer + Cinematographer
| Latest registered member is zachary24 1389 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
