Thread started 01 Feb 2012 (Wednesday) 10:26
Aaargh Canon, Why ! - new 16-35L
Echo63
Feb 01, 2012 10:26 |  #1
Just received a new Canon 16-35 L (actually, work issued me a new one, to replace my old one)
They have changed the filter thread from 77mm (which matches the 24-70 and 70-200) to an 82mm thread.
Now rather than just having random 77mm caps in my bag, I have to have a 77mm and an 82
I also have to go and buy another polarizing filter , after just acquiring my second 77mm one (because taking it of the 70-200 and putting it on the 16-35 takes to long)
Thanks of listening to my rant
Any one else have an issue with the oddball filter size ? Or just frustrated with canon in general
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
MNUplander
Gallery: 10 photos
Feb 01, 2012 10:38 |  #2
Echo63 wrote in post #13806424 (external link)
Until recently, I had several different sized lenses in my bag - its kind of a pain, but you should check out a Lee 4x6 filter system, just have an adapter ring in each size. Makes life easier.
Lake Superior and North Shore Landscape Photography (external link)
Buy & Sell Feedback
R6, EF16-35 f4 IS, EF 50 1.2, EF 100 2.8 IS Macro, 150-600C
robertwsimpson
Joined Jun 2010
Feb 01, 2012 10:43 |  #3
get all 82mm filters and a step up ring.
filter size was actually a factor in my going with a 17-40 instead of a 16-35II... Eventually I think I will get the 16-35 anyway... f/4 just isn't cutting it.
Canon ­ Bob
Feb 01, 2012 10:48 |  #4
The TS-E24 MkII also has an 82mm cap but without the "Ultrasonic" titling for obvious reasons.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
amfoto1
Feb 01, 2012 10:49 |  #5
Just get an 82mm CPL and you're all set.
Canon actually replaced the 16-35 with the Mark II that uses the 82mm filter in 2007. It's definitely an improved lens, I'm sure they would have stuck with a 77mm filter if at all possible, and didn't make the change just to frustrate you. ;)
You could have gotten the 17-40/4 instead... it uses a 77mm filter.
Step rings are an option... but a problem if you use lens hoods. I'd never want to not use lens hoods, so I only use step rings in an emergency and to stack my lenses for storage.
ed ­ rader
"I am not the final word"
Feb 01, 2012 10:50 |  #6
i have a polarizer for my 16-35L II but i seldom use a CPL on UWA. i would not buy step up rings unless you use an 82mm CPL alot. my "landscape lenses" are all different sizes 67mm, 77mm, and 82mm. i have CPLs for all three, graduated neutral densities for the last two and Uvs for each lens.
when i'm doing landscapes that require CPL i think it's inefficient and a waste of time to be moving a CPL from lens to lens.
the filter is larger for a reason; the lens has been much improved. that's well worth it to me.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
SMP_Homer
Gallery: 29 photos
Feb 01, 2012 10:53 |  #7
let's see if I read this right...
work GIVES you a new lens... and you complain about the filter size???
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
Tommydigi
Gallery: 66 photos
Feb 01, 2012 10:56 |  #8
Yep annoying and the reason I went 17-40 + 24L but the 16-35 is a great one and I may still go to one someday.
For GND you could try a square Lee filter and just hold it over the lens.
Website (external link) | Flickr (external link) | Instagram (external link)
Fuji X100F • Canon EOS R6 Mark 2 • G7XII • RF 16 2.8 • RF 14-35 F4 L • RF 35 1.8 • RF 800 F11 • EF 24LII L • EF 50 L • EF 100 L • EF 135 L • EF 100-400 L II • 600EX II RT • 270 EX II
irishman
Feb 01, 2012 11:20 |  #9
Maybe its time you re-think the use of filters. I don't know why anyone would put a cheap piece of glass in front of a $1800 piece of glass. A polarizer on that wide of a lens looks like crap, and use the gradient tool if you need a GND filter.
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
Tommydigi
Gallery: 66 photos
Feb 01, 2012 11:53 |  #10
why is it bad to use a polarizer on a wide lens?
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Feb 01, 2012 12:02 |  #11
You get some really odd, uneven patterning due to the width of the frame vs the angle at which a CPL is effective.
argyle
Feb 01, 2012 12:04 |  #12
You get a free lens, and you're complaining about having to buy a new filter?
Tommydigi wrote in post #13806910 (external link)
Its not...it all depends on the situation.
Andrew_WOT
Feb 01, 2012 12:09 |  #13
Fitting hood on the top of step-up ring could be a challenge.
Tony_Stark
Shellhead
Feb 01, 2012 12:11 |  #14
The 82mm is the reason why Im hesitant to add the 16-35 II to my bag in the future. Everything I would own has either a 72mm (most L primes) or 77mm for the L zooms (24-105, 24-70, 70-200 II etc.). It gets really expensive if I want to use the 16-35 II for landscapes.
Nikon D810 | 24-70/2.8G | 58/1.4G
EOS M | 22 f/2 STM
Website (external link) | flickr (external link)
KoalaCowboy
Gallery: 14 photos
Feb 01, 2012 12:30 |  #15
Lee Filter system. Get the WAR-072, WAR-077 & WAR-082 adapter rings and you will be set. :)
Then you buy filters 1x (unless you destroy one accidently. [don't ask, it wasn't pretty seeing $190 CPL get destroyed]) and life is good! :D
Pete
Gripped 5D Mk III / 24-105 / 16-35 II / 70-200 II / 600EX-RT / LEE Filters / F-Stop backpacks / Gitzo GT3542LS / RRS BH-55
USKestrel Photography (external link)
3,231 views & 0 likes for this thread, 20 members have posted to it.
1010 guests, 110 members online
