Thread started 01 Feb 2012 (Wednesday) 18:25
Polarizing filter for 77 mm lenses
ReDDoG
Feb 01, 2012 18:25 |  #1
Hello,Im back on the filter bandwagon having tried a few on my 70-200 II 2.8 lense.Mostly sky shots in the background an other situations outdoors that arise from time to time.Im almost sure a polarizing filter is what i need.I read the good bad an ugly on different brands.Anyone recommend a particular brand for this lense.These are the 3 ive narrowed it down to.90% of the time i just use the hood for protection.But every now an then a PR filter adds some pop.Thanks for any an all responses.
http://www.adorama.com​/HY77CPLHD.html (external link)
http://www.adorama.com​/BW77CPLW.html (external link)
http://www.adorama.com​/HY77CPL.html (external link)
There are alot of PR filter out on the market,but these 3 seem to fit the bill atleast for now.
Peace
Rebel XSI -7D- 18-55mm - 10-20 mm Sigma - 55-250 mm - 580 II flash - Cactus V5 -Sigma 17-50 2.8 OS - 50 mm 1.8 -70-200 2.8 IS II :rolleyes:
windpig
Chopped liver
Feb 01, 2012 18:32 |  #2
You don't need a slim filter.
This is what I use
http://www.bhphotovide​o.com …_Circular_Polar​izing.html (external link)
Go ahead, spin the wheel.
Dillan_K
Gallery: 111 photos
Feb 01, 2012 18:40 |  #3
You may want a Kaesmann type filter if you live in a humid place. They're better sealed to resist fungus. If you're home town isn't so humid, go for a regular polarizer.
I couldn't offer a valid opinion because I have never been to the Carolinas!
ReDDoG
Feb 01, 2012 18:42 as a reply to  @ windpig's post |  #4
Thanks for you advice windpig.That looks like a great filter for my setup.Main concern at this point,does the filter come off easy.Ive read the horror stories about getting a filter off.I personally have had this problem.Finally using needle nose pliers that removed a stuck filter.thanks once again.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Feb 01, 2012 18:51 |  #5
I'd go with B&W. I've never had an issue with my B&W getting stuck (can't say that about my Singh Rays). If you can spring for it I agree about the Kaeseman filters, of course, that would double the cost (or more if you go for the new nano coated ones), but it's worth it IMO.
500px (external link)
1x (external link)
instagram (external link)
windpig
Chopped liver
Feb 01, 2012 18:57 |  #6
I've never had a removal issue. This is what I do; I put the filter on and I do not tighten it much. When I turn the ring to dial in the polarizing, I turn it ONLY in the direction that goes the way when you are putting the filter on. The eliminates the possibility of unscrewing it. I have a number of ND and polarizing filters that fit different size lenses. I bought a filter removal tool to have on hand in case of an issue, I've yet to use it. Cost about $5.
ReDDoG
Feb 01, 2012 19:04 as a reply to  @ windpig's post |  #7
Thanks all,windpig can you direct me to your removeal tool.Just covering my bases.I think im OCD but my wife says its only on the weekends.LOLpeace
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Feb 01, 2012 19:04 |  #8
Another vote for the B+W Kaesseman; I've never had any removal problems and I share it between, nearly, all of my lenses.
windpig
Chopped liver
Feb 01, 2012 19:55 |  #9
ReDDoG wrote in post #13809239 (external link)
http://www.bhphotovide​o.com …A=RetrieveSku&I​C=GBFW6277 (external link)
:lol::lol:
Snydremark
Gallery: 66 photos
Feb 01, 2012 20:01 |  #10
What I really love is that the actual item description even has doubt...:D
"They may be helpful in removing a "stuck" filter ..." [EMphasis mine]
BigBadWolfie
Joined Jul 2011
Feb 01, 2012 20:03 as a reply to  @ windpig's post |  #11
Note that the B+Ws the OP linked are not MRC coated. I would go with the B+W MRC filters. Between the regular and Kaesemann, I would go for the Kaesemann if you can spring for it.
amfoto1
Feb 01, 2012 20:11 |  #12
Stuck filter removal tool...
They used to be free, back in the days when we had newspapers delivered to our homes. Now you might have to ask the produce guy at the supermarket to sell you a few.
Grand_gator
Joined Mar 2011
Feb 01, 2012 20:40 |  #13
windpig wrote in post #13809094 (external link)
This is what I use
Plus one on that filter, very good quality.
5Diii / 70-200 L IS II / 100-400 L IS II / 24-105 L IS / 100mm 2.8 L Macro IS / Σ 35mm 1.4 Art / Σ 85mm 1.4 Art / EF-S 10-22mm / EF-S 17-55mm IS / EF 70-300mm IS / 50mm 1.8 II / 600 EX RT + 430 EX II
amfoto1
Feb 02, 2012 11:17 |  #14
Grand_gator wrote in post #13809915 (external link)
Yes, the B+W Kaesemann are among the best. Their MRC Pro are all quite good, too.
Plus, since it's a concern of the OP, many B+W filters (plus some from other manufacturers) are made with brass rings to help keep them from getting stuck on lenses. Aluminum is more likely to gall and get stuck.
However, if you look closely at your lens, I bet the filter threads are plastic. Those are less likely to see filters get stuck, too. Most Canon lenses now have plastic filter threads. Aluminum filters are much more likely to gall and get stuck on a metal thread, particularly if also made of aluminum.
Also, you can wipe the filter threads with a candle to lubricate them lightly. Not a lot, just a little paraffin on there will help prevent them getting stuck. It also isn't sticky, so doesn't tend to catch dust the way most other types of lubrication might.
The lens wrenches linked earlier work fine, but are size specific. You'd need a pair of them that are made to fit 77mm.
If you want something that's usable on a wide variety of different size filters, and my low tech rubber band solution isn't good enough (hey, it works... I have a couple rubber bands on my filter stack, ready to use if needed)...
One of those rubber "grippers" used to open jars also will work. You can find them at kitchen stores (if you can't get them free... I got mine from a real estate broker friend).
Or get one of these: http://www.northerntoo​l.com …oduct_200306401​_200306401 (external link) This is smaller than the usual strap wrench you'll find at Sears, tool stores and auto parts stores. It's just the right size to use on filters.
2,678 views & 0 likes for this thread, 8 members have posted to it.
1171 guests, 181 members online
