bobbyz wrote in post #13826288
...Call me paranoid, I am just worried with all those exposed wires and aluminium hand truck.....
Those "exposed" wires are all 12v wires, they're not going to hurt you.
Of course, what could be an issue is the zillion amps in the battery all jumping out at once.
That would make lots of big sparks, which could cause other bad things to happen.
IMHO, The OP should have a fuse / circuit breaker as close to the battery terminal as possible, but apart from that, it's a great setup.
The lethal voltages (110v / 240v) are safely contained in the mains power leads just as they are in any other situation, be it PCB inverters or directly into a wall-plug in the studio.
While I've no doubt you can run your Einsteins just fine from a PCM Mini, and it works fine for your needs, the OP won't be needing to worry about recycle times of keeping one eye on the battery charge !!
My $AUD 0.02 !!
Austen.
