Thread started 05 Feb 2012 (Sunday) 03:53
Odd exp con on 1DIII
John_N
Joined Sep 2009
Feb 05, 2012 03:53 |  #1
Morning,
I was playing around and thought I'd give a more details look at using exposure compensation but found something odd.
1) Take pic at +3 looks the same as 0
2) Take pic at -3 and darker than 0
Now I expected 2 but I though 1 would look brighter - the subject was a naturally lit corridor so plenty of scope to wash it out if I wanted.
I'll upload the pics later if that helps, I just have to nip out now.
Any suggestions?
flickr (external link) (magsnorton)
: Google+ (external link) : My Site (external link) : 5oopx (external link)
John_N
Joined Sep 2009
Feb 05, 2012 05:39 |  #2
Back again - heres the image if that helps.
Oh, it was handheld hence it not being aligned, but as an example I don't think it matters.
IMAGE: http://farm8.staticflickr.com/7166/6822263327_ffac9c4de1_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/magsnorton/6822​263327/  (external link)
EV Oddness (external link) by magsnorton (external link), on Flickr
modchild
Joined Jul 2011
Feb 05, 2012 07:04 |  #3
Were you shooting in manual for all the shots (I assume you would) and if so that's very strange. When I alter my EV on either the my 7D or 5D2 there's a big difference, especially indoors. The 0 and -3 shots look right, just the +3 hasn't done anything.
I've just shot 3 photos in M and 3 in AV using the same EV and the +3 is way off the scale compared to the 0 both times while the -3 gives a similar pic to yours. Might be an idea to try shooting again just to make sure of your settings.
EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
jase1125
Feb 05, 2012 07:08 |  #4
Hi. If you were not in manual then the safety shift option in the custom functions can "over ride" your settings to get what it thinks is a proper exposure. Do this test in manual mode only and disable safety shift.
Jason
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 05, 2012 07:15 as a reply to  @ jase1125's post |  #5
Looks like the camera was set to compensate by aperture adjustment, and you were already using full opening at +/- 0. Thus it could close for -3, but not open for +3.
Forget about Safety Shift, it doesn't remove exposure compensation. Automatic lighting optimizer does to some extent, though, but then it wouldn't work with -3 either. So it's probably not that.
Anders
John_N
Joined Sep 2009
Feb 05, 2012 07:18 |  #6
Unless I'm loosing it there is no exposure compensation in manual - I think I was shooting in TV mode for those shots.
However I tried again, this time using live view and really watching what the status was doing and saw it moving round, adjusting aperture and ISO and to really bug me I get a light, mid and dark shots.
Hmn, so I figure maybe I was in AV, so I try the same and get correct results again - this is all very strange!
John_N
Joined Sep 2009
Feb 05, 2012 07:27 |  #7
apersson850 wrote in post #13828513 (external link)
That would make sense, although the tests I repeated were with the same shot with the same lighting - thanks though its probably right.
I did have a similar things yesterday when out though and it was a bright(ish) day but the images came out really dark - again though probably user error - I've only just got this camera and its much less forgiving than my previous bodies it seems.
John_N
Joined Sep 2009
Feb 05, 2012 07:54 |  #8
Here is the retest result - I still don;t really get it but Andre's idea could well be right, I was just playing and saw the oddness, which I repeated at the time but like a numpty deleted the images before I sync'd up a load of stuff from the day before to by server!
IMAGE: http://farm8.staticflickr.com/7029/6822853081_35a8b44c46_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/magsnorton/6822​853081/  (external link)
EV Retest (external link) by magsnorton (external link), on Flickr
John_N
Joined Sep 2009
Feb 05, 2012 08:02 |  #9
Okay time to crawl away in shame - I had another go to try and repeat the test, this time to my eye as I had originally and got the same original results!!
What I had done was this - I took the original EC 0 shot fine, half held the shutter, released the shutter, turned the dial then took the shot - I then did this again but for some reason kept the shutter half held and amazingly it worked - to further confuse myself I'd set the minimum shutter speed to 60 to ensure I always get a steady shut without introducing camera shake - this also had the same effect a reflects perfectly what Anders suggested.
So between those two I got the same lack of result via two methods!
What an idiot - I have a funny idea that on the 60D it would still do compensation a little while after the half shutter press was released, but used it so infrequently that I could be wrong - either way I'd a bad habit to break!
jase1125
Feb 08, 2012 11:53 |  #10
Safety shift certainly impacted my exposure compensation on the 7D. Not sure about the 1D3 though.
Jason
1,819 views & 0 likes for this thread, 4 members have posted to it.
1455 guests, 129 members online
