Thread started 05 Feb 2012 (Sunday) 12:59
Images not as sharp as wanted
ern7702
Joined Jan 2012
Post edited over 4 years ago by ern7702.
Feb 05, 2012 12:59 |  #1
Here's to my first thread....
About a month ago I bought a T3i (first DSLR) with a 18-135 kit lens and a Tiffen UV filter. I love the camera but more times than not I'm dissatisfied with the overall results of the photo. They don't seem to POP like a lot of the pictures I've seen taken with my set-up. .
Lowner
"I'm the original idiot"
Feb 05, 2012 13:20 as a reply to  @ post 13830001 |  #2
I've only looked at your first image closely but it seems fine. As good as an image straight from camera is ever going to get I'd say. One might suffer due to subject movement and a faster shutter speed would help with that.
What software do you use to post-process? Or rather, what sharpening routines do you follow?
Richard
ern7702
Joined Jan 2012
Feb 05, 2012 13:23 |  #3
Lowner wrote in post #13830119 (external link)
I have LR 4 beta. I'm very new to LR. As of now the only thing I mainly use it for is to adjust the exposure. I haven't really played around with the program too much. The 2nd photo is obviously overexposed.
mckinleypics
Feb 05, 2012 13:29 |  #4
Here are a few things I learned when I started:
1. Kit lenses aren't going to give you the results you see on here.
2. UV filters degrade the final image.
3. Most of the pictures you see posted in here have been manipulated in post processing.
4. Shoot RAW and then adjust, rather than letting the camera make your decisions for you. If you try to play around with images shot in JPEG, the file size diminishes quickly as it keeps getting recompressed.
5. Focusing and recomposing takes a little practice, depending on the DOF you are using. I usually select the focus point in the camera that is on the subject, especially when using a wide aperture.
Dave
7D, 70-200mm 2.8 L IS, 24-70mm 2.8 L, 50mm 1.4, Tokina 11-16mm 2.8, 580EXII
My Flickr (external link)
snyderman
Feb 05, 2012 13:31 |  #5
#1 looks good. You are close to the dog and your aperture setting was good as well. Go back and look at the data on that shot. It's a tad underexposed, but the dog looks acceptably in focus and relatively sharp.
#2 looks like the camera missed focus. The stone work on the street low and left in frame appear to be the most in focus part of the image. Also, a really high f/n was selected so focus went nearly to infinity. Wider aperture, like f/4 would have made it easier to see where focus landed.
Focus on #3 looks ok. Lack of sharpness probably a result of slower shutter speed than you can steady enough for hand-holding. What was shutter speed?
You'll always have difficulty with a shot like #4 due to harsh sunlight and your camera looking for better contrast than your subject provided to achieve accurate focus.
What can you do? Do some testing on static (non-moving) targets to be sure that the AF on your camera and lens are in synch and achieving accurate focus is possible. Make sure you have good light and a high-contrast target.
Also, make sure that you shoot at a comfortable shutter speed. When I started it was 1/200 minimum to get good sharp results. This means you need to use the TV program on your camera or Manual Exposure option so you're assured of keeping shutter speed fast enough to produce sharp shots.
That should keep you busy until the Superbowl begins!
dave
Canon 5D2 > 35L-85L-135L
Lowner
Feb 05, 2012 14:14 |  #6
As Dave said, selecting a fast enough shutter speed to stop subject movement is vital. I always pick a shutter speed at least twice the focal length I'm using, so at 135mm I'd be using 1/320 as my minimum.
Always check that the AF point you are using has a highish contrast target. Without a reasonable contrast it can fail to focus, or pick something else entirely, not what you might have assumed at all!
The focus in photo 3 is slightly beyond the subject. f/5.6 has given you a rather tight depth of field. A larger DoF would have possibly solved the issue, but really its just a matter of contrast again, or rather a lack of it.
Richard
mckinleypics
Feb 05, 2012 14:16 |  #7
deeselcyde wrote in post #13830253 (external link)
Good to know. I don't think I've taken one JPEG photo, they've all been RAW. Thank you, I'll keep all of these in mind.
Okay - good but if you shoot RAW, you really need to sharpen in post.
Dave
Lowner
Feb 05, 2012 14:29 |  #8
I've sharpened it a touch to try and demonstrate the importance of proper post processing. Does it have more zip?
Richard
argyle
Feb 05, 2012 15:25 as a reply to  @ post 13830616 |  #9
You need to be careful when focusing and recomposing...there's a chance that part of the subject can fall out of the plane of focus when you reposition the camera. Also, proper exposure will help in making the pictures have a bit more pop...some of those posted seem to be a bit underexposed. With proper technique, exposure, composition, and lighting, and the right amount of processing, the kit lens should more than meet your needs.
Furthermore, the pictures that you see posted in the forums have all had some degree of post processing applied, and all by posters with with varying degrees of skill (not to mention many years of photographic experience). So don't lose too much sleep when comparing your shots to theirs.
Titus213
Feb 05, 2012 23:35 |  #10
Your kit lens should be able to give you crisp, clean shots.
Your first image looks fine focus wise. Focus and recompose can cause problems so if you can select a focus point close to the subject to minimize recompose.
DOF can be a big help. Get to know a bit about it for your lens - at least make sure you know how it works. Check DOF master here - http://www.dofmaster.c​om/dofjs.html (external link)
If you are new to LR check out the free presets available at http://www.ononesoftwa​re.com …erfect-presets-lightroom/ (external link)
There are several I find quite useful and there is a group of sharpening and noise reduction presets that work great and are simple push buttons.
Dave
Perspiring photographer.
Lowner
Feb 06, 2012 03:25 |  #11
deeselcyde wrote in post #13831073 (external link)
How would you have achieved spot on focus for this shot? Is there something that I should have done different? What if the subject is in shade? Flash?.
Fill-in flash can help by providing help to the AF system, but I think I'd naturally choose an aperture in the f/11 or f/16 area, which would increase the depth of field and then any slight focusing errors would be hidden.
Another way would be to AF on a contrasty point the same distance away and recompose. Both these come with their own problems and its a matter of judgement on the spot as the the preferred solution for any particular scenario.
But just remembering that the AF system needs a reasonable contrast will help you in future.
Richard
lets ­ learn
Feb 06, 2012 19:03 as a reply to  @ post 13836623 |  #12
The first picture i would say is the best, the other are not to bad but they have nothing that pops like you said in your first post. With the Light Room program i would look into some "presets" i would google it and you can purchase some and then mess with the image from there or there are a few sits that have some good "presets" for free you can download.
AE_Photography
Joined Nov 2011
Feb 06, 2012 21:01 |  #13
Here is a quick edit with a high pass filter to sharpen the image, as well as a clone out of the person behind the dog....
Andrew Johnson / Owner
https://www.facebook.c​om …w-Johnson/33615570653492​9 (external link)
Camera Bodies:Canon MKIII 1D / Canon 6D
Lenses: 50mm 1.8 / 24-105mm F4 / 70-200mm 2.8 IS L
argyle
Feb 07, 2012 14:46 |  #14
lets learn wrote in post #13837512 (external link)
My advice for the OP would be to get the exposure and composition correct first (read, study, practice)...then worry about actions, presets, and other software last. Don't simply press the shutter button and rely on software gimmicks to "get it right"...very bad habit to get into for a beginner.
Titus213
Feb 07, 2012 16:15 |  #15
argyle wrote in post #13843533 (external link)
I could not agree more....
But I think all raw images benefit from some post processing work. I use LR3 presets to figure out HOW to adjust things. Hit the Light Sharpen preset and look at what it does to the sharpen settings, hit the Warmer preset and look at what it does to the split tone settings. And hit the Medium Noise Reduction preset and look at what it does to the detail settings.
Great learning tool.
Dave
2,438 views & 0 likes for this thread, 9 members have posted to it.
1358 guests, 174 members online
