Thread started 06 Feb 2012 (Monday) 12:58
i need a compact camera
moltengold
Joined Jul 2011
Feb 06, 2012 12:58 |  #1
hi
is there any compact camera shoot macro photos like the same way of the canon lens macro like EF-S 60mm f/2.8 Macro USM on the DSLR body
and the same camera gives me a nice zoom for reach to shoot birds ?
| Canon EOS | and some canon lenses
eyalg
Feb 06, 2012 14:54 |  #2
No. There's no such camera.
Most large zoom cameras, like the Canon PowerShot SX40,
are able to focus as close as 1 cm from the object,
but only when zoomed out - the result is a magnification
nowhere near the 1:1 magnification you're seeking
when referring to DSLR dedicated macro lenses.
Point and shoots are good for macro photography
due to their small sensors and much larger depth of field,
but you would probably need to attach a Raynox lens
in order to obtain true macro shots.
-eyalg
My Digital Camera Guide - www.eyalg.com (external link)
moltengold
Joined Jul 2011
Feb 06, 2012 18:45 |  #3
Thanks a lot
tmwag
Brown Noser has crush on Suzyview
Feb 06, 2012 19:14 as a reply to  @ moltengold's post |  #4
If you can find a good copy take a look at the G9. It has very good macro capability and a zoom range of 35-210 (35 equivalent)
Jon
Joined Jun 2004
Feb 06, 2012 19:18 |  #5
If you want 1:1, no, you won't. But 1:1 on any camera the EF-S 60 lens will cover is about 15x22.5 mm; you could probably cover that area with the SX40 in macro mode.
Jon
Cocker Spaniels
moltengold
Joined Jul 2011
Feb 07, 2012 04:44 |  #6
tmwag wrote in post #13837595 (external link)
WOW thanks a lot
i bought the PowerShot G9 from a long time and its new
i didnt use it many time only a few shot since i bought it
its in the box
i will try to use it and test the macro shooting
thank you again
moltengold
Joined Jul 2011
Feb 07, 2012 04:45 |  #7
Jon wrote in post #13837617 (external link)
Thanks a lot
moltengold
Joined Jul 2011
Feb 07, 2012 05:46 as a reply to  @ moltengold's post |  #8
i made a test with my PowerShot G9
but its not like the DSLR but its good
100% croped
eyalg
Feb 08, 2012 00:02 |  #9
Seems like you didn't take the G9 as far as it can go in terms of macro.
Try to zoom out and get as close as you can in macro mode.
-eyalg
spear
Feb 08, 2012 03:13 as a reply to  @ eyalg's post |  #10
Yes, to use the manual capability of the G9 to its maximum potential. Set the camera in macro mode while fully zoomed out and move really close to the subject, then set focus to manual and spin the wheel to get optimal focus. This is sort of a Liveview setup that allows you to get absolutely perfect focus for macros because you get a magnified square to manually tune in the focus. If you want more abilities on the G9, I think you can add a close up macro filter lens to the front ... but to be honest I have never felt I needed that so have not tried a front lens. The two most underrated capabilities of the G9 are its built in ND filter, and its manual focus for perfect focus on macro pictures.
Canon 40D, 5DII, 5DIII, G9,G11,S100,G1X, Canon lenses 600mmL f/4 ,24mm-105L f/4, 16-35L II f/2.8, 70-200L II f/2.8, EF 100mm f/2.8, EF 50 f/1.4,17-85 EFS, 10-22 EFS, 580 EX, 2x 580 EXII, 270EX,STE2, 1. 4x Converter, 2.0x Converter. Nikon 800E w/Nikkor 24-70
spear
Feb 08, 2012 03:17 as a reply to  @ eyalg's post |  #11
Yes, to use the manual capability of the G9 to its maximum potential. Set the camera in macro mode while fully zoomed out and move really close to the subject, then set focus to manual and spin the wheel to get optimal focus. This is sort of a Liveview setup that allows you to get absolutely perfect focus for macros. If you want more abilities on the G9, I think you can add a close up macro filter lens to the front ... but to be honest I have never felt I needed that so have not tried a front lens.
Here is a macro add on for the G9
http://www.amazon.com …TF8&qid=1328692​242&sr=8-4 (external link)
2,133 views & 0 likes for this thread, 5 members have posted to it.
1468 guests, 130 members online
