I think I saw this once but haven't seen it since - was I imagining it or is there a setting I've yet to understand that shows these points?
MikeK Goldmember 1,637 posts Joined Apr 2001 Location: San Francisco area More info | Feb 07, 2012 14:34 | #2 You mean the 6 assist points mentioned here: Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Feb 07, 2012 15:18 | #3 I'm assuming you are talking about 5D series cameras.... In which case Mike is correct. You can't see those assist points at all in the viewfinder... They aren't indicated on the focus screen, are simply clustered close around the center point only and are only functional in AI Servo and when you have manually selected the center point. They are only used when a moving subject is "passed off" to them from the visible center point. According to Canon, this is most useful when tracking an erratically moving subject that's difficult to keep the center AF on. In other words, it's sort of like increasing the size of the center point a lot. Alan Myers
Feb 07, 2012 15:23 | #4 On the 1D3 they will light up when the camera uses them. If you select a dingle point and the camera uses an assist point near it, the selected point will light up and also assist point will light when focus is confirmed. You can test this to see what I mean by selecting a point and aiming at a line with the selected point just off the line. The neareset assist point to the line will be used and light up. 5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
Feb 08, 2012 06:29 | #5 Sorry I wasn't clear - yep it was on the 1DIII
Feb 08, 2012 10:09 | #6 You can also turn a function on to display the AF points on the playback screen too. I forget where it is, but it's not in the custom functions menu. 5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
nonick Goldmember 1,588 posts Joined Jun 2009 Location: NYC More info | Feb 08, 2012 10:11 | #7 Not those in 5D or 5DII Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
Feb 08, 2012 10:45 | #8 kawi_200 wrote in post #13848717 You can also turn a function on to display the AF points on the playback screen too. I forget where it is, but it's not in the custom functions menu. That sounds handy
| Latest registered member is semonsters 1460 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
