Thread started 07 Feb 2012 (Tuesday) 15:23
Critique
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 07, 2012 15:23 |  #1
IMAGE: https://lh4.googleusercontent.com/-oUcf1JhmzAY/Tyno25onunI/AAAAAAAAk_c/ccLFTBZkVYU/s512/_MG_0137.jpg
maybe better ? IDK
be brutal
It makes me better
40D
2.8
1/250
1000 iso
ran through photoreflect software
it looks better on my computer
Canon 1DIV, Canon 1DII, 7D2 Canon gripped, 70-200 2.8 ISM II, Canon 50 1.8, Sigma 17-50 2.8, Canon 300 2.8, Canon 550 EX flash
C and C welcome, Brutality Encouraged, Help Always Welcome Editing OK
www.firstdownphotos.ph​otoreflect.com (external link)
Flicker Page http://www.flickr.com/​photos/72506283@N03/ (external link)
clarence
Feb 07, 2012 17:42 |  #2
Color and exposure look good, but trade off some ISO to get better shutter speed (too much blur at 1/250"). Try ISO 1600.
Get lower.
Use the vertical beams on the back wall as a plumb line to straighten your horizon.
Try to get both eyes of the subject.
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
ajaffe
Feb 08, 2012 00:35 |  #3
Personally that would be a delete or only used if that was the only image of her I got.
I want to see her facial expression, 40 is distracting, the horizon is off, exposure is about 2 stops under, and it could be cropped tighter.
www.jaffe.photo
dwarrenr
Feb 08, 2012 06:08 |  #4
Not sure what your 40D can shoot at ISO wise, but as Clarence stated you need to do what you can to limit motion blur. I'd rather have a grainy image then a blurry one.
I'm not sure I'd delete it. It all depends why your are shooting. I would not submit it to a publisher unless the girl was the MVP, or if that was the game winning shot, or if I didn't have any other shots of her..which I'm hoping I would. As far as parent sales goes, I'd keep it if the subject was in focus.
Also the image looks like it could use some more fill lighting in post. Not a lot. I think you could up it a tad without adding much noise.
Other issues that need to addressed is that you need to straighten the vertical lines, and crop tighter to remove some head room.
Keep at it. :D
Also: This should be posted in the image section, not the talk. You might get more response if it was posted there. ;-)a
D. Warren Robison
"All guys feel the need to compensate. Most compensate with sports cars. I compensate with a 400mm 2.8"
Flickr (external link) - Home Page (external link) - MaxPreps Gallery - (external link)Razzi (external link)
Equipment List
abruckse
Gallery: 58 photos
Feb 08, 2012 11:17 |  #5
From other thread:
burnet44 wrote in post #13848872 (external link)
wow thats great stuff DC fan
no way I can shoot that fast
I would love to learn how you do that
I cant balence the high iso fast shutter speed and low light
If I get 1/250 out of mine Im lucky
Clarence said "Just open the aperture to f/2.8 and crank the ISO to keep your shutter speeds up. ISO 3200 or even 6400. Try to maintain 1/640" or 1/800".
If I do that its basically a black cat in a closed closet
Im glad you guys have it figured out
Im trying
thanks again great shots
What do you mean exactly?
Crank up ISO (40d goes to 3200, right?) then find a shutter speed that gives you a good exposure. 1/500 is the minimum to mostly freeze action; if you can't reach 1/500 with all of your other settings maxed out (f/2.8, ISO3200), then the available light is below what your gear needs for proper sports photos. Your options then are either a faster lens, faster body, strobes or kicking that gym to the curb and finding a better (probably newer) one with proper lighting.:lol:
A good exposure for me is one that almost or just begins to blow out the home jerseys. This minimizes noise. Try not to rely on post-processing for exposure correction, unless you absolutely have to. With ISO3200, some noise reduction and sharpening will go a long way and should produce pleasing results... I do this with my lesser model 400d on a regular basis.
Andrew
www.andrewbruckse.com (external link) | Instagram (external link)
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 08, 2012 11:35 |  #6
might be true
it probably is
I may be fighting a losing battle?
Your 400D must be better than my 40D?
I know your a better camera guy than me
I do need a 85mm 1.8 or better I would seem
Thanks for the info
clarence
Feb 08, 2012 11:37 as a reply to  @ abruckse's post |  #7
burnet44 wrote in post #13843238 (external link)
A stop of exposure is a stop. Doesn't matter if it's a stop of ISO or a stop of shutter speed... it's up to you to choose where to use the available stops... aperture, ISO, shutter speed... take from one and use it in another.
Working with the exact same exposure (exact same gym, exact same camera, exact same lens, exact same photographer) you could trade a stop of ISO for twice the shutter speed.
In your picture above, if you double your ISO from 1000 to 2000 (that's a stop), you can then double your shutter speed (that's a stop) from 1/250 to 1/500".
If raising your ISO from 1000 to 2000 and increasing your shutter speed to 1/500" gives you "a black cat in a closed closet", then something definitely isn't right.
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 08, 2012 11:46 |  #8
thanks man
Its probably me
great stuff
I appreciate your time
I know its valuable
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 21:43 |  #9
Ok Ill post what I took tonight
way better light
I took peoples advise
3200 iso 1/500 2.8 and let er rip
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 22:09 as a reply to  @ burnet44's post |  #10
Your submission could not be processed because a security token was missing or mismatched.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
:mad:
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 22:15 |  #11
grrrrrrrrrrrrrrr
will flicker not upload raw
I was trying to post the origional
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 22:25 |  #12
Ok yes I know its crooked
I think this may be the original
3200 asa 2.8 1/500
again the lighting was a lot better
canon 40D 70-200 2.8
wb manual
HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 22:38 |  #13
it looks a lot better on my computer
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 22:49 |  #14
buddie of mine shoots for the Waco Trib
he has 2 Nikons of some kind
shooting with Im sure 2.8 lenses or better
shooting at 4000 iso
probably got 15 grand in all
he is shooting the same game Im shooting
blows my sorry snit out of the water
I cant afford 15 grand
and the newspaper buys some of it for him I think
jezzzzzzzzzzzzzzz louise
burnet44
Gallery: 13 photos
Joined Jan 2012
Feb 10, 2012 23:20 |  #15
IMAGE: https://lh4.googleusercontent.com/-iNWEr2ez9vw/TzX5t36TxNI/AAAAAAAAlA0/Hluw7zUaJ44/s512/_MG_0322.jpg
all I did was straighten
hit auto color
all in picassa
I was just trying to get this up
I got LR4 beta loaded
have no idea how to use it
I was just trying to get it up so you guys could see
prob needs noise reduction?
IDK if LR does that
havent got that far or found it yet
thanks to all
2,786 views & 0 likes for this thread, 6 members have posted to it.
Critique
2440 guests, 104 members online
