argyle wrote in post #13854446
I'd recommend saving a few bucks and getting yourself a beautiful 67mm B&W polarizer and skip the step rings altogether...can be a real PITA when it comes to separating a rotating filter from a step ring. Separate filters makes things easier...
Yea, OP said the thread was dead, but since it's been revived, I second this.
I got the step-up ring and it welds itself to the polarizer. Once I even took it into a shop and they got it off then tested it with a little lubricant and then got it stuck and couldn't remove it. Eventually a day later it just came off easily.
Sometimes it is OK, but basically the ring, although metal, has some flex, so when it gets a little stuck you cannot grab it hard. Finally I figured out a method (two rubber bands and gentile working loose), but in the end I just got another polarizer. I convinced myself that because it was for the 70-200 I didn't need as much flare resistance and got a cheaper B&W and am happy with it.
