Thread started 09 Feb 2012 (Thursday) 16:07
Computer build
Erik_L
Feb 09, 2012 16:07 |  #1
Greetings. I've decided to ditch my laptop for photo editing and build a PC.
What I have is a 3.6 GHz 2600k i7, 16 GB DDR3 1333 RAM
OS installed to 128 GB SSD on SATA III
Data/photos on 3x 2 TB 7200 RPM drives (only operates at SATA II speeds due to controller... :( ) in a RAID5
GTX 550 TI, 750 watt power supply.
Thing is, I got the RAM for free because the person did not ring it up, and my board supports faster RAM... Would I see any benefit in photoshop/Lr in using 24-32 GBs of 1600 DDR3 as opposed to a mere 16 GBs of 1333 RAM?
I've also gone ahead and set my page file down to just 1 GB in size, to save writes to the SSD and get precious little space back.
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
tkbslc
Feb 09, 2012 16:20 |  #2
"mere" 16GB of RAM!? :)
That looks like a pretty badass build. I don't think you have anything to worry about.
SATA II speeds are 3Gb/s and there is no way you are going to get that kind of throughput from 7200RPM drives, so no worries. Running faster than 1333 RAM (which is the bus speed) is really only going to help for overclocking or for onboard video cards that feed off RAM.
Taylor
EOS Rp | iPhone 11 Pro Max
compudaze
Joined Nov 2011
Feb 09, 2012 16:25 |  #3
The amount of RAM I cannot comment on, but the speed won't make much of a difference at all. Chk out this article on Memory Speed Scaling for Sandy Bridge CPU's. (external link) You make me feel small with my 8GB of RAM. ;)
Canon EOS 60D Gripped, Sigma 17-50mm f/2.8, Canon 70-200mm f/4L IS, Canon 55-250mm IS II, Canon 28mm f/1.8, Canon 85mm f/1.8, 2x Canon Speedlite 430EX II
tim
Light Bringer
Feb 09, 2012 17:15 |  #4
RAM speed makes very little difference. 16GB is HEAPS of RAM, no you won't see any increase in performance if you add more RAM.
Erik_L
Feb 09, 2012 17:46 |  #5
I was kind of making that comment tongue-in-cheek, but I have not paid much attention to computer hardware/benchmarks for YEARS so I guess I'm just not too sure about to what extent the hardware is utilized in modern applications.
I may just save my money and stick with the RAM I have - it was free afterall :D
Canon EOS 1D III
tim
Light Bringer
Feb 09, 2012 17:50 |  #6
Over about 8GB of RAM it's just used as a disk cache. Batch processing 500 images with Bridge I barely hit the disk at all, other than creating output files, they're all in my ram cache.
Erik_L
Feb 09, 2012 17:55 |  #7
Update:
WOW! I finally got done doing the overnight transfer of ~2 TB of photos to my RAID and it's UNREAL. Every time I open a catalog in Lr, it's INSTANT. This is unreal! Makes me wanna take more pictures just so I can blow through them on my computer super-fast :)
Canon EOS 1D III
tim
Light Bringer
Feb 09, 2012 18:01 |  #8
Is your catalog on the SSD or on the RAID array? I'd put the catalog on the SSD for fast low latency access to the cache, and the images on RAID. Well, I wouldn't bother with RAID, one disk is fine for me.
Erik_L
Feb 09, 2012 19:07 |  #9
The catalog is on the RAID. It's fast enough :) I like to keep it all together just to keep things simpler.
Canon EOS 1D III
rpaul
Joined Jul 2011
Feb 10, 2012 09:00 |  #10
This is very similar to the new build I am considering (external link), sans RAID. Might have to consider that ... but spinny drives are so expensive these days. :\
Rob | rmpaul.com (external link)
Gear 'n Stuff (external link)
C&C always welcome
sapearl
Gallery: 152 photos
Feb 10, 2012 09:59 |  #11
One of the machine configurations I'm considering has USB 3.0 on the motherboard, and the case has enough extra 5.25" drive bays that I'm considering an internal card reader. Trouble is I have not seen too many available on the market other than this one:
http://www.amazon.com …B003OC9LZG/ref=​pd_vtp_e_2 (external link)
Anybody have recommendations? Thanks.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
tkbslc
Feb 10, 2012 10:14 |  #12
Newegg has a few. I don't think there are many 5.25" ones, but there are cheap 3.5 -> 5.25 conversion kits. I was going to say make sure it is USB 3, but USB 2 goes up to 60 MB/s which is up there with the fastest cards on the market. So that is up to you. I'd probably just go usb 3 while I was buying.
5.25" adapter: http://www.newegg.com …aspx?Item=N82E1​6817994080 (external link)
Taylor
sapearl
Gallery: 152 photos
Feb 10, 2012 11:09 |  #13
tkbslc wrote in post #13862124 (external link)
Thanks for the link Taylor - much appreciated :D.
I can see how my existing drive would just sort of "hang in" the slot, but then I'd have to add duct tape or customize a bezel of of plastic which I could do. I'll just have to keep looking around.;)
TeleFragger
Feb 10, 2012 11:12 |  #14
tim wrote in post #13857968 (external link)
but does wonders on vmware hypervisor 5!!!!
OP - nice build..
GearBag - Feedback****Flickr - my playhouse (external link)****RF-603 Discussion
Canon 7Dm2 Gripped | 32GB Transcend CF | 64GB Toshiba FlashAir | YN-468 Flash | YN-468 II Flash | RF-603 | EF-S 18-55 IS|EF 24-105L|EF 50 MKII 1.8|EF-S 55-250 IS |EF 85 1.8| Tamron SP 70-200mm f/2.8 Di VC |Primo's Trigger Stick Monopod | Manfrotto Carbon Fiber Tripod
if I post a pic.. it is there to be picked on... (I have thick skin.. im in IT)
tkbslc
Feb 10, 2012 11:16 |  #15
sapearl wrote in post #13862489 (external link)
No, the adapter has risers to support the 3.5" drive centered in the drive opening. They work well. We used to use them to add zip drives to computers back when those were popular.
Taylor
3,230 views & 0 likes for this thread
Computer build
937 guests, 283 members online
