Thread started 09 Feb 2012 (Thursday) 18:07
Sunset Help! =]
goaliejake22
Joined Dec 2011
Feb 09, 2012 18:07 |  #1
Hello,
I went out and took some photos of sunsets, and I seem to be having a bit of trouble. The objects below the horizon line are pretty dark, and when I try to lighten them, there is a lot of noise. If I lighten them without noise, it takes away from the sky color. Examples are #1 (dark foreground) and #2 (not noisy but pretty plain sky)..
Thanks in advance
Canon 5D3, Sigma 35 1.4, Sigma 85 1.4, Canon 50 1.8, Canon 430 exii, yn- 560 ii, triggers
Hikin ­ Mike
Walkin' Like a Penguin Now!
Gallery: 16 photos
Feb 09, 2012 18:11 |  #2
Either buy a GND (Graduated Neutral Density) filter or bracket your images (using a tripod) and blend them in Photoshop.
Images in the Backcountry (external link)
Canon 5D 17-40 Ճ/4L 300 Ճ/4L IS 70-200 Ճ/4L 50 Ճ/1.8 1.4x TC Օ Kenko Ext. Tubes
Frank_Hollahan
Feb 09, 2012 18:11 |  #3
To pull off a shot like #1, you need lots of filtration.
#2 needs a little selective contrast in the sky only.
stephen.shelley
Joined Feb 2012
Feb 09, 2012 18:59 as a reply to  @ Frank_Hollahan's post |  #4
The best option is to bracket your photos with different exposures taking into account your histogram. Usually +2,0,-2 will work. However, some scenes/conditions will need additional shots on either or both ends of the spectrum. The idea to make sure that you capture all the information necessary so that you can create a photo that does not contain any overexposed or underexposed areas. However, with sunsets, the sun itself is almost always blownout to some degree, thus resulting in spikes off the right side of the histogram. Check your blinkies if your camera is equipped to see what is causing the spikes off the histogram.
Once you have obtained the bracketed photos you will need to process them using HDR (high dynamic range) software such as photomatix or process them using Photoshop. Photoshop can do HDR or you can use masks or other methods to accomplish the same task of merging the photos into one picture. This method can be very time consuming but the results can be superior to straight HDR processing depending on the result you are looking for.
You will almost always need a tripod when bracketing photos to be used for HDR or combining photos in photoshop with a few exceptions.
Everglades, Big Cypress, Florida Keys Photography www.stephenshelleyphot​ography.com (external link)
Canon R5 | EF Canon 100-400 ii | EF Canon 16-35 f/2.8 | EF Canon 70-200 f/2.8L IS ii | Canon 1.4x III, 2x III Teleconverters | Lightning Trigger | Slik PRO 700DX | Lowepro Flipside 400| Pelican Case 1454 | Snake Boots| Canon 5D iii
poza
Joined Nov 2010
Feb 09, 2012 20:15 |  #5
get a 3 stop GND filter, it will help a lot
gnphoto.zenfolio.com
SteveJa
Feb 09, 2012 22:34 as a reply to  @ poza's post |  #6
Yes, GND's or PP with many shots. I like GND's because I dont like to PP.
I think I used about 8 stops of GND's on these shots but wanted a little more because I only had 3stop hard and the others were 3stop soft and 2 stop soft.... would have really like 3stop hard x2.... (thanks for post, I need to buy more filters before my next trip in March)
IMAGE: http://stevejavorsky.zenfolio.com/img/s11/v36/p207238357-5.jpg
IMAGE: http://stevejavorsky.zenfolio.com/img/s11/v30/p249956229-5.jpg
Zenfolio (external link)
FineArtAmerica (external link)
dscri001
Joined Dec 2011
Feb 09, 2012 22:46 |  #7
I actually just had the same problem the other day because I don't have any filters yet. If you don't have any gnds you could try what I did. What I ended up doing was exposing for the sky in one picture and then expose for the foreground in another. Then with the info from those shots, switch to M and try to expose somewhere in the middle where the sky is slightly over and foreground slightly under. This way when you pp, you're only dealing with slight changes in exposure. Took me a lot of tries, but was very happy with the results!
IMAGE: http://farm8.staticflickr.com/7059/6844232779_04f5e87ceb_z.jpg
This picture is also in another thread, but thought it was appropriate for this situation.
Oh and while you're at it, you can make sure your horizon is straight as I failed to do :roll:
-Tyler I II
EOS 6DII, EF 16-35mm f/4 ISL, EF 35 f/1.4L II, EF 85 f/1.8, EF 70-200mm f/2.8L
1,146 views & 0 likes for this thread, 7 members have posted to it.
Sunset Help! =]
2719 guests, 153 members online
