Thread started 10 Feb 2012 (Friday) 15:03
USB cords, card readers, and which to use?
barn9
Feb 10, 2012 15:03 |  #1
I currently have 4 Canon cameras, an A560, A2000is, S 5 IS, and S95, therefore 4 usb cords to sort through depending on which camera I happen to be using. My question is, are these cords interchangable?
They look the same basically, but I tend to err on the side of safety, so have them marked and always use the proper cord. I was just untangling them while ago and decided I would ask the experts. ;)
I have never used a card reader, nor do I own one, so is there any advantage to downloading to either method, or is just personal preference?
Canon EOS Rebel T3i 600D
Canon EOS M
Canon S95, Canon SX30is
Canon S5is, Canon A2000is
Jon
Joined Jun 2004
Feb 10, 2012 16:34 |  #2
Yes, they're the same. You can use any USB A to 5-pin Mini-B cable, not just Canon's, which is handy if you need a longer, or shorter, cable than they come with. But a card reader's a better idea. They're faster, they don't need the camera to be turned on (thereby helping drain the battery), you aren't going to have to worry about snagging the USB cable and sending the camera crashing to the floor, and in the event that you get a corrupted card, recovery programs won't work with just the camera.
Jon
Cocker Spaniels
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 10, 2012 16:39 |  #3
Jon wrote in post #13864396 (external link)
This. A card reader is such a simple solution. Less components to fail or complicate things.
imjason
Joined Nov 2010
Feb 10, 2012 19:26 as a reply to  @ gonzogolf's post |  #4
card reader
why?
faster
wont break usb connector
wont use camera battery
better compatibility with computers
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
pbelarge
Joined Jun 2010
Feb 10, 2012 20:07 as a reply to  @ imjason's post |  #5
I also vote for a card reader...
just a few of my thoughts...
Pierre
CactusJuice
Feb 10, 2012 20:41 |  #6
I seldom use my card reader. It's faster to use the cable at my desk and the EOS Utility. The card reader is handy when I want to delete a bazillion files or do some other batch operation.
iazybandit
Joined Apr 2011
Feb 10, 2012 22:15 |  #7
I use a card reader. I leave all USB cables for my devices in the box.
Canon :: R5 | R6 | RP
Glass :: RF 15-35 f2.8L IS | RF 24-70 f/2.8L IS | RF 70-200 f/2.8L IS | RF 35mm f/1.8
FEEDBACK
FS: 3D Printed RF 35mm Lens Hood | PakPod Tripod
peterbj7
Location: A Caribbean island in Belize and occasionally UK
Feb 10, 2012 22:19 |  #8
I only ever use a card reader. I've had a few, and the Transcend one is head-and-shoulders above the rest.
5D & 7D (both gripped), 24-105L, 100-400L, 15-85, 50 f1.8, Tamron 28-75, Sigma 12-24, G10, EX-Z55 & U/W housing, A1+10 lenses, tripods, lighting gear, etc. etc.
"I prefer radio to television. The pictures are better"
Jim ­ K
Feb 14, 2012 15:47 |  #9
CactusJuice wrote in post #13865569 (external link)
Cactus Juice, why do you delete files from a card? When I'm ready to clear the card I just put it back in the camera and Format it.
Canon: 7D (2, 1 gripped), 50D gripped, 500 f/4L IS, 100-400 L IS, 70-200 f/4L IS, 28-135 IS, 10-22, 15-85 IS, 1.4x II, 580EX
5D3, 24-105 f/4L IS, 17-40 f/4L IS, TS-E 24 f/3.5L II. S100 p&s
Gitzo GT3530LS, Wimberley ver. II. Manfrottto: tripod 055XPROB legs, 448RC2 head; monopod 679B, 234RC tilt head
tkbslc
Feb 14, 2012 16:00 |  #10
barn9 wrote in post #13863908 (external link)
Yes. You can just pick your favorite length and use one cable.
Reading this thread, you'd think a card reader is essential. It is certainly not. It is just a matter of what you prefer. Taking the card out is just as much hassle as plugging in a cable.
Taylor
EOS Rp | iPhone 11 Pro Max
Ianfp
Feb 14, 2012 16:08 |  #11
This is what I do. I have never read a post on USB connector problems, but have read many about bent or broken memory card pins in the camera.
Ian
Nikon D850, 85mm f/1.4G
5D2
EF17-40 f/4.0 L, EF135 f/2.0L EF200 f/2.8L
EF24-105L, EF100 f/2.8L Macro. EOS-M, 22mm f/2
Hasselblad 500C/M, Planar 80mm f/2.8
exwintech
Gone, but not forgotten . . .
Feb 14, 2012 21:02 as a reply to  @ Ianfp's post |  #12
Barn9 - Sometimes folk who have higher-end cameras that use Compact-Flash cards are very wary about using card-readers, as these high-tech cards seem to be quite fragile if not handled very carefully - can bend or break the pins, so on.
I think all of the cameras you list use SD-type cards, which with reasonable care, survive handling quite well. I have 3 cameras which use SD/SDHC cards, and over several years, and quite a collection of 2GB, 4GB, and now 8GB, cards - have never had a bent or broken pins problem with one.
For years I used the USB-cable connected multi-card type reader, which eventually failed (without harming the card then in it) - and as a cheap 'temporary' replacement I bought a very small SD-type only card reader. This is a Chinese generic, about the size of a USB-drive, and works similarly.
The camera card plugs into the side of it, and the reader itself into a USB port. This opens instantly on Desktop - in Linux - in Windows I assume it would open as a Drive Letter in My Computer, or in Windows Explorer like a USB-drive. It does that in friends' XP PCs - what happens in Windows after XP, I'm not familiar with.
Back when I was connecting cameras to the computer, I soon found that using a card-reader was several times faster.
At present I'm still using this "temporary" little device I bought for $4.95 over a year ago - works very well indeed. Downloads include JPEGs, RAWs, and HD 264/MOV video - and it's quick with all.
Regards, Dave.
DStanic
Feb 16, 2012 06:43 |  #13
I used the USB on my cameras for years but recently bought a GOOD card reader (Lexar USB3) it's way faster and I can do both SD cards and CF cards at the same time! Old/cheap card readers may not be any faster than transferring from the camera so just make sure it's a good one.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
gonzogolf
Gallery: 561 photos
Feb 16, 2012 09:30 |  #14
Ianfp wrote in post #13897851 (external link)
You've missed a few then.
2,353 views & 0 likes for this thread, 13 members have posted to it.
1006 guests, 185 members online
