Thread started 12 Feb 2012 (Sunday) 02:07
Upgrade from a 60D to a 5dmkII
mike3767
Feb 12, 2012 02:07 |  #1
I shoot mostly real estate photography and wondered if this is something I should start looking at. The lens that I use when I shoot real estate photos is the Tamron 10-24. Will that lens work on the 5D? I use a lot of HDR so this is why I'm thinking about trading. Let me know your thoughts!
Canon 5D MKII, TS-E 17Lmm, 100Lmm Macro,24-70Lmm, 70-200LIImm
troutfisher
Gallery: 23 photos
Feb 12, 2012 02:25 |  #2
Dont know if the Tamron will work or not the info I have seen says designed for AP-C so I suspect it will vigniette on FF . When I used to shoot real estate I would have loved a TS-E.
If I was doing it now I would buy a 17mm TS-E or failing that a used 24mm Mk1 TS-E and keep the 60D.
If you want FF sell the Tamron and buy a 17/40 or if you can find one a Tamron 17/35 ( as good and a lot cheaper)
Chris
" Age and treachery will always defeat youth and enthusiasm"
MGiddings ­ Photography
Feb 12, 2012 09:10 |  #3
I do not think you will gain anything but you will have more space in your pockets.
https://mgiddings.com (external link)
gjl711
Feb 12, 2012 09:14 |  #4
Need more info. When shooting now, do you use any lights/flash or are you relying on available light only. How much of your shooting is ISO 3200 or higher? If you answered, yes/none, then the upgrade will do little. If you answered no/lots, then the upgrade will help reduce image noise.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
wayne.robbins
Joined Nov 2010
Feb 12, 2012 15:49 |  #5
Sounds like a good way to blow some money.. Not sure you will benefit from it though. How do you figure that the 5D II will help you ?
EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
Fond memories: Rebel T1i, Canon 18-55 IS, Canon 55-250 IS, 18-135 IS (Given to a good home)...
augenblick
Feb 12, 2012 18:22 |  #6
YOur tamron 10-24 is f/3.5-4.5 variable aperture.
The full frame sensor will give you more light sensitivity and if you get a Canon 17-40 f/4 your images may come out cleaner than 60D. Also if you downsample your 5D2 images to 60D maximum resolution you will also gain more sharpness (less noise) for sure IMHO. Yes it will be costly 'upgrade' though.
michgirl
Gallery: 13 photos
Feb 12, 2012 18:31 |  #7
Costly but satisfying..... I am just a amateur that loves taking pictures and loves the satisfaction of having beautiful pictures of landscapes and grand-kids and wildlife and family living - went from the G7 to the Rebel T1i to the 5D Mk2. And worth every cent.
Robin
Canon 6d / EF Lens: 24mm-105mm / 40mm f/2.8 / 28mm f/1.8 / 50mm f/1.8 / 85mm 1.8 / EF 70-300mm II USM
Canon T6i / EFs Lens: 24mm Pancake / 18-55mm STM / 18-135mm STM / 55-250mm STM
robonrome
Feb 12, 2012 20:24 |  #8
I have both the 60D and the 5D2. I'm not sure I understand why you think the 5D2 is better for you because you do a lot of HDR? Is it just noise control? For real estate photog and HDR I excpect you're using a tripod so you can probably afford to use lower ISO's so not much to gain from the 5D2. You'd need a new lens as the Tamron isn't suitable. Actually you may get more benefit from dropping the Tamron which is probably the lwoest quality of the ultra-wide zooms and picking up a Tokina 11-16 for the 60D. You may find you miss your flip out screen as well going to the 5D2.
rob - check my galleries at http://hardlightimages​.zenfolio.com/ (external link)
Zenfolio coupon discount when signing up - 93R-NCK-DUT
Canon 5D Mkiii; Sony RX100; Lumix G5; 17-40L; 24L TS-E F3.5 Mk2; 24-105L IS; 40 F2.8; 135L; 70-200L F2.8 IS MkII; Ext II 1.4x; 580 exII; 270 ex... other filtery stuff:)
1,538 views & 0 likes for this thread, 8 members have posted to it.
492 guests, 139 members online
