I was wondering, what you more experienced photogs would suggest for a filter to be used in daylight that allows for longer exposure time.
Basically that one that creates that dreamy or silky waterfall effect best.
JersFocus Senior Member 572 posts Joined Dec 2011 Location: Same pale blue dot as you. More info | Feb 14, 2012 11:24 | #1 I was wondering, what you more experienced photogs would suggest for a filter to be used in daylight that allows for longer exposure time. Gear & Feedback
gonzogolf dumb remark memorialized More info | Feb 14, 2012 11:27 | #2 What you want is a Neutral Density (ND) filter. The strength you need depends on when/how you are going to be using it. The silky effect can be achieved with exposures of just a few seconds, but on a bright day that may require as much as a 10 stop filter. What is your budget for this?
SpeedyGoo Member 242 posts Joined Aug 2011 More info | Feb 14, 2012 11:28 | #3 lee ND filters or welding glass depening on how far you wanted to go
MCAsan Goldmember 3,918 posts Likes: 88 Joined Jun 2010 Location: Atlanta More info | On my 5DII I first drop to ISO 50. If that is not enough speed reduction, I add my Fader variable neutral density (VND) filter and dial in as much light drop as I need. I believe Kenko just introduced their own VND filters.
Feb 14, 2012 11:40 | #5 Most of the time, Ive not had a problem creating that effect using nothing more than ISO 100 and my polarizer (2-3 stops)...but I dont typically shoot landscapes during the middle of the day. You really only need to slow your shutter down to about 1 second or maybe even a bit faster to get this effect depending on the speed of the water. Lake Superior and North Shore Landscape Photography
Feb 14, 2012 20:40 | #6 If I can add to the comment above: the CPL option does help get the effect where you would be stuck without it. The only issue I have found is that it is often necessary to stop the camera down to f22 or thereabouts to expose correctly at ISO 100. I have noticed a huge difference in image quality using a 10-stop ND as it has allowed me to run the camera at f16 or larger aperatures (i.e. much closer to the sweet spot). Mike
Feb 15, 2012 10:33 | #7 Borryking wrote in post #13899336 If I can add to the comment above: the CPL option does help get the effect where you would be stuck without it. The only issue I have found is that it is often necessary to stop the camera down to f22 or thereabouts to expose correctly at ISO 100. I have noticed a huge difference in image quality using a 10-stop ND as it has allowed me to run the camera at f16 or larger aperatures (i.e. much closer to the sweet spot). Probably true since it is probably brighter where you live in Australia. Here in Minnesota and shooting in the morning and evening, Im able to get shutter speeds of around 1 second or more at f11-f16, ISO 100 and my CPL. The OP will have to consider this since their environment is likely closer to mine since they are in Canada. Lake Superior and North Shore Landscape Photography
JersFocus THREAD STARTER Senior Member 572 posts Joined Dec 2011 Location: Same pale blue dot as you. More info | Feb 15, 2012 12:12 | #8 Under $100 is what im thinking, for budget. Gear & Feedback
gonzogolf dumb remark memorialized More info | Feb 15, 2012 13:20 | #9 JerInCanada wrote in post #13902618 Under $100 is what im thinking, for budget. And ill be shooting these water falls in the rockies so, it tends to be really sunny. If you are serious about doing good water motion shots, you might want to focus on doing them when the light is best. The middle of the day is the worst, not only because you need a much stronger filter, but also because your light is going to be hard and contrasty. Then ND filter reduces the light, but it doesnt improve it. Given your budget, you probably want to shoot them early and late and get a 3 or 4 stop ND filter.
ralff Senior Member 766 posts Joined May 2008 Location: Asheville NC More info | Live in the mountains of NC and waterfalls are one of my favorite subjects and only have a 2X ND and a polarizer, never needed more. If you want to really do it justice, follow the advice above......shoot when the light is right! Canon 6D - Canon 7D - gripped, Canon 50D - gripped, EFS10-22mm, 17-40 f4 L, nifty-fifty, EF 28-135mm IS, 100-400 f4.5-5.6 L IS USM, Tokina AT-X 100mm f/2.8 ProD Macro, Benbo Trekker, Feisol 3371 w/ Kirk BH-3 ball head - Epson Pic-Mate, Epson 2200, Epson 3880
Feb 18, 2012 20:12 | #11 A good CPL is a must. As well as getting rid of reflections it also reduces the light by about 2 stops. After that a couple ND filters in different stops
JersFocus THREAD STARTER Senior Member 572 posts Joined Dec 2011 Location: Same pale blue dot as you. More info | Feb 20, 2012 20:55 | #12 OK, so i did some readin on filters and have decided they are important to me. Gear & Feedback
Feb 21, 2012 05:16 | #13 JerInCanada wrote in post #13932666 OK, so i did some readin on filters and have decided they are important to me. I have changed my budget to $300. Do you guys think a CPL and a ND 3 stop will be good enough? What do you think about the adjustable ND.. (http://www.bhphotovideo.com …1_77mm_Fader_ND_Mark.html If I got a good budget CPL, and the adjustable, then some ring to step up my 52mm and 67mm to 77mm...do you think that would be a good start? I am kinda working blind, but I read Hoya was decent and cheaper. With any ND filter you have to be careful of color cast. Cheaper ND (like cokin) tend to have more of a cast then higher end ND's. So just keep that in mind while looking at ND's.
Feb 21, 2012 08:29 | #14 JerInCanada wrote in post #13932666 OK, so i did some readin on filters and have decided they are important to me. I have changed my budget to $300. Do you guys think a CPL and a ND 3 stop will be good enough? What do you think about the adjustable ND.. (http://www.bhphotovideo.com …1_77mm_Fader_ND_Mark.html If I got a good budget CPL, and the adjustable, then some ring to step up my 52mm and 67mm to 77mm...do you think that would be a good start? I am kinda working blind, but I read Hoya was decent and cheaper. Yes, an ND3 + CPL should be plenty, IMO. Im not a fan of the adjustable ND filters for the sole reason that they're usually thick enough to cause vignetting. I would also buy the filters in the size of your largest lens and by step rings to fit your smaller lenses to avoid vignetting. Lake Superior and North Shore Landscape Photography
JersFocus THREAD STARTER Senior Member 572 posts Joined Dec 2011 Location: Same pale blue dot as you. More info | I went with B+W 77mm (COATED) #110 (ND 3.0) FILTER - BW110C7 (125$), and Hoya 77mm FILTER INTRDCTN KIT (UV/CP/WARM) - HOFIK77 (55$). Gear & Feedback
| Latest registered member was a spammer, and banned as such! 2766 guests, 157 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
