Thread started 16 Feb 2012 (Thursday) 07:20
Canon Pixma ip100 magenta tone
TeleFragger
Feb 16, 2012 07:20 |  #1
Ok so not sure where to go with this..
i finally bought a printer... a Canon Pixma ip100. Nice and small... prints fast.. did a 8x10 photo on high quality in 3-4 minutes..
now my issue though... maybe paper related.. so
anyone use a Canon printer and get a magenta tone? what settings seem to fix this?
I didnt scan a photo to show it as I should have...
the paper is junk.. flat out.. going to go look at getting paper today..
what paper is recommended for these printers?
the paper i have is Royal Brites 30154
as seen at this link others rate the paper poor... and with the same issue.. one person said they contacted the print media company and they got the settings from them and now it is good..
well i have an email into them and will call them at lunch...
http://www.samsclub.co​m …uctId=163744#BV​RRWidgetID (external link)
GearBag - Feedback****Flickr - my playhouse (external link)****RF-603 Discussion
Canon 7Dm2 Gripped | 32GB Transcend CF | 64GB Toshiba FlashAir | YN-468 Flash | YN-468 II Flash | RF-603 | EF-S 18-55 IS|EF 24-105L|EF 50 MKII 1.8|EF-S 55-250 IS |EF 85 1.8| Tamron SP 70-200mm f/2.8 Di VC |Primo's Trigger Stick Monopod | Manfrotto Carbon Fiber Tripod
if I post a pic.. it is there to be picked on... (I have thick skin.. im in IT)
paddler4
Feb 16, 2012 07:56 |  #2
I have two Canon printers, but not that one.
Unless you want to do a lot of fussing, print with the paper that is recommended in the printer manual. It will be one (or perhaps several) of Canon's own papers. To print with other papers will require both appropriate ICC profiles and learning how to control color from software. In general, paper manufacturers don't provide ICC profiles for printers that inexpensive, so using papers other than the recommended ones is likely to be a real pain in the rear.
There is one other relatively inexpensive paper vendor, inkpress, that claims that their papers will work with Canon printers without additional ICCs. I had quite good luck using their inexpensive luster paper (http://www.inkpresspap​er.com/profiles.asp?Pa​perID=40 (external link)) on a Canon MP970, which is also inexpensive enough that most vendors don't provide profiles.
Check out my photos at http://dkoretz.smugmug​.com (external link)
TeleFragger
Feb 16, 2012 09:02 |  #3
^^^ Thank you..
yes there tech support wasnt helpful at all either...
they gave me an xls sheet that shows nothing really.. but photo paper.. to use photo paper and high quality...DUHHHHH
i guess ill go through the manual and see what paper is recommended and also the paper you have in the link..
my goal of why i bought this printer.. is if I want to do printing in an area where there is no electric.. and no cars are allowed.. so i didnt buy the battery for this printer yet...
also the ink was very inexpensive (let alone a nice refill kit can be had)...
TeleFragger
Feb 16, 2012 09:31 |  #4
ok so 200 sheets of that paper for $42 doesnt seem bad...
i have to search the differences now on what the different papers are...
anyone have a link to a quick cheat sheet???
here is what the printer recommends...
Canon Specialty Papers
High Resolution Paper (8.5" x 11"/100 sheets) 1033A011
Matte Photo Paper (4" x 6"/120 sheets) 7981A014
Matte Photo Paper (8.5" x 11"/50 sheets) 7981A004
Photo Paper Glossy (4" x 6"/50 sheets) 0775B021
Photo Paper Glossy (4" x 6"/100 sheets) 0775B022
Photo Paper Glossy (8.5" x 11"/50 sheets) 0775B023
Photo Paper Glossy (8.5" x 11"/100 sheets) 0775B024
Photo Paper Plus Double Sided (5" x 7"/10 sheets) 9981A006
Photo Paper Plus Double Sided (8.5" x 11"/10 sheets) 9981A005
Photo Paper Plus Double Sided Album Kit 0041B005
(5" x 7"/10 sheets)
Photo Paper Plus Double Sided Album Kit 0041B006
Photo Paper Plus Glossy II (4” x 6”/50 sheets) 2311B022
Photo Paper Plus Glossy II (4” x 6”/100 sheets) 2311B023
Photo Paper Plus Glossy II (4” x 6”/400 sheets) 2311B031
Photo Paper Plus Glossy II (5” x 7”/20 sheets) 2311B024
Photo Paper Plus Glossy II (8” x 10”/20 sheets) 2311B025
Photo Paper Plus Glossy II (8.5” x 11”/20 sheets) 2311B001
Photo Paper Plus Semi-Gloss (4" x 6"/50 sheets) 1686B014
Photo Paper Plus Semi-Gloss (8" x 10"/20 sheets) 1686B017
Photo Paper Plus Semi-Gloss (8.5" x 11"/20 sheets) 1686B020
Photo Paper Pro (4" x 6"/20 sheets) 1029A014
Photo Paper Pro (4" x 6"/75 sheets) 1029A027
Photo Paper Pro (8" x 10"/20 sheets) 1029A059
Photo Paper Pro (8.5" x 11"/15 sheets) 1029A004
Photo Paper Pro (8.5" x 11"/30 sheets) 1029A028
TeleFragger
Feb 16, 2012 11:31 as a reply to  @ TeleFragger's post |  #5
in case someone else searches for it some day.. thought i would share some info..
attached is a breakdown of prices i found for the pack then divided for a per sheet price...
now i see why my wife prefers to get photos printed online with a coupon!!!!
2,173 views & 0 likes for this thread, 2 members have posted to it.
1040 guests, 114 members online
