Thread started 17 Feb 2012 (Friday) 18:32
Difference between Sigma and Tamron lens
tawcat
Feb 17, 2012 18:32 |  #1
Looking at the Tamron 28-75 or the Sigma 17-70.
Any thoughts? Thanks.
Yes, a picture really is worth a thousand words!
PowerShot ELPH 520 HS
watt100
Feb 17, 2012 18:45 |  #2
tawcat wrote in post #13917014 (external link)
here's a thought: one is primarily for full frame, the other is for crop models
see the reviews at www.photozone.de (external link)
Kiwikat
Feb 17, 2012 18:48 |  #3
Difference? They're different focal lengths, different apertures, and are compatible with different cameras.
The 28-75 is a pretty decent lens. It isn't a L, but it is capable of some really sharp shots. Used my friend's copy several times. Never used or seen a 17-70 before though...
"Would you really want to be the Canon rep responsible for dealing with POTN?" -FlyingPhotog
Nikon D500
BrickR
Joined Mar 2011
Feb 17, 2012 19:25 |  #4
My 28-75 is my workhorse. I got a great copy, sharp wide open and all lengths. Full frame compatible as well. For portraits and general use its a gem. If you were looking for more of a walk-around lens, I think the 17-70 might be better because 28mm isn't as wide as you might want on a crop body.
My junk
The grass isn't greener on the other side, it's green where you water it.
tawcat
Feb 17, 2012 20:38 |  #5
watt100 wrote in post #13917076 (external link)
Well thanks, but the link you sent did not include the Tamron 28-75. And if I knew the difference I would not have asked.
Seems to me, if I read the descriptions correctly, they both are APS-C lenses. So which of these two is not compatible with my Rebel XS?
Quiexo
Joined Jun 2011
Feb 17, 2012 20:44 |  #6
tawcat wrote in post #13917504 (external link)
Your Rebel XS has a APS-C sensor, so both will definitely work on your camera. The Tamron will also work on a FF body, not sure about the Sigma though.
I do love my Tamron, even though it can be annoying when the AF hunts; no issues with the IQ though...
1D MkIII, 5D3, Sigma 24mm f1.8 + 35mm f1.4, Canon 40mm f2.8 pancake + 85mm f/1.8 + 100mm f/2.8 macro, Ricoh GR
mattmorgan44
Joined Feb 2012
Feb 17, 2012 21:04 |  #7
I'm sure you already know this so please don't get offended but just in case you don't know:
Your Rebel XS has a crop sensor and has a crop factor of 1.6x. What this means is, on your camera, the Sigma has an effective focal length of 27-112mm (17-70 x 1.6). The Tamron will have an effective focal length of 45-120mm. Therefor, the Sigma is much better suited to your crop camera as the Tamron is not nearly wide enough for a general purpose lens (on your camera).
I don't know much about these two lenses but the Sigma is probably designed around a crop sensor such as the Rebel so it is likely to perform better on a crop camera even if it was compatible on Full Frame cameras (which I don't think it is)
5D Mark II | 7D
24L II | 50L | 100L Macro
Some other stuff
Can't find a Lee filter holder? - Cokin Modification for wide angle lenses
tawcat
Feb 17, 2012 21:27 as a reply to  @ mattmorgan44's post |  #8
I was leaning toward the Tamron, but that was my concern, if it was a better fit for a FF. my present lens is a Tamron 18-250, nice lens but really does limit everyday shooting.
I'm sure I'm not indifferent than most, have bought and sold many lenses looking for a good everyday lens. I got tired so I settled on the Tamron.
Thanks for the info and I will probably go with the Sigma.
paddler4
Feb 17, 2012 21:37 |  #9
It's not.
People sometimes say that a lens that is FF-compatible, like this lens or any EF lens, will work 'better' on a FF. This is not necessarily true, and it is simply wrong in this case. When you mount such alens on a crop sensor camera, you lose the outside of the image circle that a FF could capture. That has nothing to do with the quality of the image it does capture.
If you read reviews of that lens, you will find that the only criticism of its IQ is that it can be a tad soft in the corners. On a crop, you don't see those corners. So IMHO, it is actually a better lens for a crop.
I own one and use it a lot on my crop sensor camera. It is my standard lens for indoor candids of people.
Check out my photos at http://dkoretz.smugmug​.com (external link)
gremlin75
Feb 17, 2012 21:44 |  #10
Both are good lenses and both will work on your XS. The difference is one may not be wide enough for your needs on a crop camera.
Personally 28mm is not wide enough for me. I do own the sigma 17-70 and it's on my most used lens
tawcat
Feb 17, 2012 22:16 as a reply to  @ gremlin75's post |  #11
All that said, the Tam has an F2.8 and the Sig has an F2.8 - 4. For some reason I thought the 2.8 is better. Am I wrong? Thanks.
StructuredAmazing
Feb 17, 2012 22:57 |  #12
HTTP response: NOT FOUND | MIME changed to 'text/html' | Content warning: script
difference is....
tamron's better.
:P
But id get the sigma because of its more wide side
"Yea, though I walk through the valley of the shadow of death, I will fear no evil"
StructuredAmazing forever.
My website: Pending...
gremlin75
Feb 17, 2012 23:46 |  #13
tawcat wrote in post #13917923 (external link)
The tamron has a constant f2.8
The sigma has more focal range, is wider, has an HSM focusing motor, and has optical stabilization.
Like i said both lenses are good lenses bit this is one of those things that if you don't know why you want a lens then you're probably better off just not getting one until you know what you are looking for out of it.
maleaco
Joined Feb 2012
Feb 18, 2012 00:10 |  #14
StructuredAmazing wrote in post #13918084 (external link)
difference is....
tamron's better.
tamron's is quite wide, i thought, compared to the sigma
mattmorgan44
Joined Feb 2012
Feb 18, 2012 00:31 |  #15
It seems you may not know some the basics like Aperture and sensore sizes etc so again this is all just in case you don't know. Please don't get offended if you do, it still may help someone who doesn't.
f/xx is used to show the maximum Aperture of a given lens. Aperture is basically how wide the lens will open to allow light to come in. The lower the f/xx number, the wider the lens can open and the more light will be able to enter for a given shutter time. A lens with a wide Aperture is also called a 'fast' lens - reason being you can use a faster shutter speed than a lens with a lower Aperture for the same amount of light entering.
For example, let's say you need to take a picture handholding your camera and your max Aperture is f/4.0, like the Sigma at it's longer focal lengths, and the ideal shutter speed (for the correct exposure) is 1/20th of a second - this will probably lead to a blurry shot (at least a little bit). To get the same amount of light onto your sensor with the Tamron at f/2.8 you will be able to use 1/40th of a second shutter speed because your lens is opening wider and letting more light in which is likely to give you a sharp picture as long as your hands aren't too shaky :)
So to answer your question, yes a maximum of f/2.8 at all focal lengths is better than one that ranges from f/2.8 to f/4.0. A lens with a variable max Aperture like the Sigma will be able to use its maximum Aperture (2.8 in this case) at its wider focal length (17mm) and it will adjust to a maximum or f/4.0 somewhere along the way to it's longest focal length (70mm). You can usually find out the exact focal lengths at which the max Aperture changes at thedigitalpicture.com.
Of course, whether a constant 2.8 is better than Sigma's widest focal length of 17mm depends on what you are shooting. Sigma also has 2.8 at it's wider focal lengths and even 4.0 isn't HEAPS wider anyway. Also for a general purpose lens 28mm on a 1.6x crop body is not wide enough. Therefor I would choose the Sigma hands down, as long as the IQ is comparable.
Hope this helps
5D Mark II | 7D
Some other stuff
3,622 views & 0 likes for this thread, 12 members have posted to it.
1333 guests, 109 members online
