Thread started 18 Feb 2012 (Saturday) 17:54
550ex won't set as master. Why?
StayLucky
Feb 18, 2012 17:54 |  #1
Hey all, quick question.
I'm trying to sync my dad's 550ex with my 430exii. The 550 is set to master via its switch. But when trying to set all my channels everything on the 550 keeps blinking as if it won't let me lock or finish the settings. Can't get the pilot to light up or anything. It's like it's unusable.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Feb 18, 2012 18:02 |  #2
Is the Wide Angle Panel out? That's what the flashing LCD means.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
StayLucky
Feb 18, 2012 18:04 |  #3
Nope it's in
Managed to solve part of the problem. The head wasn't locked. But now my RATIO setting are still blinking.
StayLucky
Feb 18, 2012 19:51 |  #4
Basically, the Ratio values A:B won't stop blinking and I can't even use the flash.
klr.b
Feb 18, 2012 20:22 |  #5
You say the pilot light won't light up...no red or green? Red means it's ready and green means it can do a Quick Flash (partial power).
No light would indicate that the capacitor isn't charging. Easiest thing to check would be the batteries. Get a fresh set and try again.
gordon
Gear and Feedback
StayLucky
Feb 18, 2012 20:44 |  #6
klr.b wrote in post #13922045 (external link)
Will try that, thank you.
StayLucky
Feb 18, 2012 21:06 |  #7
Looks like changing the batteries in the 550 helped...but now the 430 isn't firing, not sure if it ever did. HA. I'm just gonna go drink some more Dead Guy and relax. Thanks all.
klr.b
Feb 18, 2012 21:27 |  #8
Make sure the window on the front of the 430exII can see the light from the 550ex. For instance if you're hand holding the 430, make sure you're not covering it. What I usually do is hold the slave pointed at the wall and have the Master fire anywhere else. Indoors the signal will bounce and the slave should be able to see it. Watch the wall and make sure the slave flashes. If it doesn't make sure it's set to Slave and the correct channel.
gordon
Gear and Feedback
Titus213
Feb 19, 2012 22:52 |  #9
Perhaps before venturing into master/slave situations you should make sure both flash units work alone.
Dave
Perspiring photographer.
OneJZsupra
Feb 22, 2012 08:06 |  #10
So I just noticed that all you set was the 550ex to master.... Did you set the 430ex II to slave? (hold down the zoom button for a few seconds)
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
2,091 views & 0 likes for this thread, 5 members have posted to it.
936 guests, 182 members online
