Thread started 18 Feb 2012 (Saturday) 20:10
Shooting past 30 seconds in which mode?
mlech
Feb 18, 2012 20:10 |  #1
Sorry if this is the wrong section but had a quick question.
I bought a timer so I can take a series of pictures and make time lapse videos... or either long exposure pictures past 30 seconds.
I seems like when I use M(manual) mode, and select the exposure option "BULB" then I can take a long exposure for as long as I'd like, then I can stop it when I'd like.
Is manual the best mode and BULB exposure setting for long exposure pictures?
thanks in advance.
FACEBOOK PAGE (external link)
FLICKR (external link)
Saint728
Feb 18, 2012 20:49 |  #2
Yes that is correct. I just set mine to BULB and use my intervalometer.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
John ­ from ­ PA
Joined May 2003
Feb 18, 2012 22:03 |  #3
As others have pointed out, it is likely the card. Also, be aware there are some limitations on how much you can record, even with the best of memory cards. More than 12 minutes can be recorded but there are some limitations. When the file size reaches 4 GB, recording will automatically stop. That means that at 1920x1080 dpi and 1280x720 dpi the maximum recording time of a single movie clip is about 12 minutes. At 640x480 dpi it is about 24 minutes. I think there is also an auto-restart function in the 60D so it will start again and you loose only a few seconds of video.
The capacity of the card differs in recorded time; at 1920x1080 dpi or 1280x720 dpi you can stuff 44 minutes total of video onto a 16 gig card. At 640x480 dpi or crop 640x480 dpi this goes up to 1 hour 32 minutes. However, the 60D English manual movie section states "The maximum recording time of one movie clip is 29 min. 59 sec. Depending on the subject and the increase in the camera's internal temperature, the movie shooting might stop sooner than 29 min. 59 sec.' [60D manual, page 181]
This is not just the Canon line, Pentax for instance states "Like competing DSLRs, the Pentax K-5 also monitors sensor temperature during recording, and will halt capture if the temperature rises beyond a certain threshold." A reputable source also states "This limitation is due to the different (European) import duty rates for still and video cameras." There is no reference made to differing duty rates of product entering the United States however. So there may really be two limitations, one the 29 min 59 seconds limitation imposed legally, and a sensor temperature issue that might also be reached in some rare circumstance.
525 views & 0 likes for this thread, 3 members have posted to it.
1075 guests, 170 members online
