Thread started 19 Feb 2012 (Sunday) 01:25
Lens or Sensor?
Roush611
Joined Feb 2012
Feb 19, 2012 01:25 |  #1
Ok, so I recently purchased a 50d and I have been shooting the last few days quite a bit. I have been messing around with settings and getting a feel for things. I noticed something very annoying when I put the pictures on the computer last night and this evening. When I shoot at higher aperture i.e. 20 on up little dots appear in the photos. (see pic below) The more I edit some of the pictures the more the dots appear. But this is what confuses me, these dots only appear when I shoot on high aperture. Anything 8 and below there are no sign of the dots at all. Is this the lens that the person gave me with the camera or is it the sensor in the camera. The lens is a 18-55mm. I'm going to be very irritated if it is indeed the sensor and I have to pay to get it fixed. What do you guys think?
IMAGE: http://i7.photobucket.com/albums/y266/roush611/IMG_2566-1.jpg
FlyingPhotog
Cream of the "Prop"
Feb 19, 2012 01:29 |  #2
Simply "sensor snot" (dust) which is always more pronounced at smaller apertures...
Take it somewhere for a sensor cleaning (usually $25-35 USD) or else bone up on how to clean it yourself via Rocket Blower, Sensor Kleen Pen or else a wet system like Copper Hill.
Jay
W ­ Vee
Joined Feb 2012
Feb 19, 2012 01:30 |  #3
They could be dust on the sensor, which can sometimes be removed with a squeeze bulb. The procedure for raising the mirror for cleaning with the bulb is in the manual. If you do this, don't put the tip of the bulb any further into the front of the camera than the lens mount, in case the mirror returns to its normal resting position.
Lionel
Feb 19, 2012 01:31 |  #4
Your sensor needs cleaning, that's dust.
xarqi
Feb 19, 2012 02:01 |  #5
You could also examine your motives for using such small apertures. Diffraction softening starts to kick in at around f/11 to f/16 on APS-C, and for most purposes sufficient depth of field can be achieved without going smaller.
Lowner
"I'm the original idiot"
Feb 19, 2012 02:33 |  #6
W Vee wrote in post #13923027 (external link)
Have I missed something? How is this going to clean the sensor filter surface? The sensor is a long way from the lens mount.
Richard
FlyingPhotog
Cream of the "Prop"
Feb 19, 2012 02:39 |  #7
Lowner wrote in post #13923153 (external link)
You don't want the shutter closing on the tip of your rocket blower...
I've heard the same warning but only in conjunction with any worries that you don't have enough battery to ensure the shutter stays open and the mirror stays up.
Jay
Lowner
Feb 19, 2012 06:10 |  #8
FlyingPhotog wrote in post #13923163 (external link)
J,
Yes, Of course. But the cleaning setting in the camera menu should (provided theres enough oomph in the batteries) prevent that. I use canned air and get the nozzle as close as I dare to the filter surface while carefully avoiding touching anything.
After all, if it needs to be followed up with a brush or even a wet clean, then this HAS to be right in there.
Richard
number ­ six
fully entitled to be jealous
Feb 19, 2012 14:11 |  #9
Lowner wrote in post #13923461 (external link)
J,
Uh, oh! Duck! You're gonna get it now! The villagers are grabbing pitchforks and lighting torches!
(I use canned air too.)
:lol:
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
number ­ six
Feb 19, 2012 14:13 |  #10
Roush611 wrote in post #13923017 (external link)
Welcome to POTN!
As you've learned already, it's junk on your sensor.
Here's a good introduction to sensor cleaning: http://cleaningdigital​cameras.com/ (external link)
And here's a good tutorial: http://www.copperhilli​mages.com/index.php?pr​=tutorials (external link)
I use the Copperhill kit for wet cleaning, as do lots of other POTNers.
-js
"Be seeing you."
Roush611
Joined Feb 2012
Feb 19, 2012 23:20 |  #11
Canned air eh? From purists I know that's a no no but how does it work? Should be fine as long as you are not too close to the sensor and don't go all out right?
j-dogg
Joined Apr 2011
Feb 20, 2012 01:11 as a reply to  @ Roush611's post |  #12
I use sensor swabs if the rocket air won't get it.
Get some good glass for that thing, 17-55 if your pockets are deep or the 17-85 / 15-85 if you need some reach. 50d is a great camera.
5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
RB67 Pro-S / 50-90-180 Holy Trinity, 120/polaroid back
Graphic View I 4x5 / Schneider 180 / Meyer 135 / Ektar 127
Gregg.Siam
Joined Jun 2010
Feb 20, 2012 02:19 |  #13
Roush611 wrote in post #13927544 (external link)
Air + can + pressure :p
It's ok as long as you don't tilt the can and shoot out the liquid. It's also not good to have massive or long bursts of air because it can and will blow dust into places you will have a hard/impossible time of removing.
I personally never us it as I think it has too much pressure and too high a risk for what a simple blower can accomplish.
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
Lowner
Feb 20, 2012 02:34 |  #14
It needs care I admit, but really its not as difficult as its said to be.
I always carefully blow out moisture where the can may have been lying on its side in storage, then make very sure I stand it on a flat horizontal surface and gently press it down while I'm using it to make sure it stays there (tilting the can is the big no-no). Then use short bursts, not long ones. This is to prevent the air cooling and forming ice crystals as these definitely will not do the sensor cover any good at all!
Its highly effective. Simply because the air speed is far higher than any hand blower will achieve. I use one of those expensive spinning brush things, but a good quality (& clean!) artists sable brush static charged with the canned air would probably be as good, if not better and cheaper.
Number Six: Not the pitchforks and flaming torches yet?
Richard
number ­ six
Feb 20, 2012 13:52 |  #15
Lowner wrote in post #13928001 (external link)
They'll be here, don't worry.
One additional advantage of canned air: you can aim it accurately. Try aiming a bulb blower while squeezing it - it jumps all over the place.
If using a rocket blower, it's a good idea to put the camera on a tripod so you can use both hands on the blower.
-js
"Be seeing you."
2,650 views & 0 likes for this thread, 12 members have posted to it.
Lens or Sensor?
1398 guests, 120 members online
