Thread started 19 Feb 2012 (Sunday) 23:18
Artifact in ACR when viewing RAW files
mrmarks
Feb 19, 2012 23:18 |  #1
Hi, I often see some kind of artifact in the shadow region of RAW images when viewed ACR. When I view the same file in DPP, this artifact does not show up. I would like to understand why this artifact is showing up and if there's a way to eliminate it in ACR? In the example below, the artifact can be seen in the left side of the neck. The first image is from ACR, while the second from DPP. Thanks for the inputs!
acr2 (external link) by marksmike (external link), on Flickr
dpp2 (external link) by marksmike (external link), on Flickr
jra
Feb 19, 2012 23:27 |  #2
Can you point it out a bit better? I'm not seeing it. What does seem quite apparent is that the ACR photo has more contrast.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 19, 2012 23:47 |  #3
What camera profile are you using for ACR? You should be using the ones designed for you camera and not "Adobe Standard" or "ACR x.x". The ones specific to your camera are "Camera Standard", "Camera Neutral", etc.
Bob
tzalman
Fatal attraction.
Feb 20, 2012 03:20 |  #4
Assuming this is ACR 6 (very different from Vs. 5 and earlier) it has a conversion engine that has been tuned to maximize detail extraction. Earlier ACR demosaicers and DPP are much smoother. But more detail can also mean more noise, which is particularly evident in the shadows. To get a smoother rendition reduce Detail in the sharpening or add a little Luminance NR.
Elie / אלי
armis
Joined Jan 2012
Feb 20, 2012 03:32 |  #5
Yup, looks like something's getting clipped off. There's probably a slider somewhere that's not where it should be (ya I know, not all that helpful, sorry :)).
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
mrmarks
Feb 20, 2012 06:51 |  #6
Bob_A wrote in post #13927626 (external link)
I tried camera standard and other profiles but the artifact is still there.
mrmarks
Feb 20, 2012 06:52 |  #7
tzalman wrote in post #13928106 (external link)
Hi Elie, I tried both the detail slider but no real improvement
armis
Joined Jan 2012
Feb 20, 2012 06:54 |  #8
Can you post the RAW somewhere so others can take a look at it?
mrmarks
Feb 20, 2012 07:22 |  #9
armis wrote in post #13928449 (external link)
armis, it seems like I can't post in on flickr. Anyway else to do it?
armis
Joined Jan 2012
Feb 20, 2012 07:30 |  #10
I think you need to find a regular file sharing service (not sure which though, I'm new around here :p. But I seem to recall some mentioned around these parts).
tzalman
Fatal attraction.
Feb 20, 2012 07:34 |  #11
I use this:
http://www.4shared.com​/ (external link)
Elie / אלי
mrmarks
Feb 20, 2012 07:57 |  #12
Thanks Elie! Try this http://www.4shared.com …MG_7857.html?re​furl=d1url (external link)
S.Horton
Feb 20, 2012 08:04 |  #13
Try limiting your view to 100%. I don't see it here (CS 5.5 / ACR)
Sam - TF Says Ishmael
:cool:
mrmarks
Feb 20, 2012 08:08 |  #14
S.Horton wrote in post #13928637 (external link)
At 100%, I can see the unusual tone is the shadow areas in the raw image
S.Horton
Feb 20, 2012 08:19 |  #15
Odd that I do not. Interesting.
:cool:
4,521 views & 0 likes for this thread, 9 members have posted to it.
1470 guests, 131 members online
