FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 20 Feb 2012 (Monday) 09:57
SNS-HDR circular banding?
michaelnel
Feb 20, 2012 09:57 |  #1
I have been pretty happy with Photomatix Pro 4.1 lately, but decided to check out SNS-HDR this morning.
I immediately noticed that when three .TIFs were merged, all of the presets show a strange circular banding in the merged image. It is there in all of the presets, but the "night" mode shows it the most (I would not normally choose this mode for an image like this, but did only for illustration here).
What causes this circular banding, and how can it be avoided?
I keep my photos on SmugMug: (http://michaelnel.smug​mug.com (external link))
Pebal
Joined Jun 2010
Feb 20, 2012 11:25 |  #2
I've never seen such circular banding in SNS-HDR. You can share the source exposures?
michaelnel
Feb 20, 2012 11:47 |  #3
Pebal wrote in post #13929474 (external link)
Yes, but how do I get them to you? They are pretty large (3 images at about 100 Mb each). Do you have an FTP site I can send them to?
The TIFs are the output of DxO Optics Pro 7.1 having processed Canon EOS 60D CR2 files for lens corrections. I save them out of DxO as TIFs to combine in HDR programs. The same images worked fine in Photomatix Pro 4.1 and Machinery HDR without the strange circular banding.
Pebal
Joined Jun 2010
Feb 20, 2012 12:40 |  #4
michaelnel wrote in post #13929557 (external link)
I do not have an ftp server. Please, share or send me these images in JPEG format.
michaelnel
Feb 20, 2012 15:52 |  #5
Pebal wrote in post #13929831 (external link)
OK, I put them in my junkbox on my smugmug site. They are still max quality full-size jpegs, but down to about 8MB each. Put "http://" in front of them to grab them. I trimmed it off for posting here so people that click on the message won't inadvertently start a download.
michaelnel.smugmug.com​/Other/Michaels-Junkbox/i-xWQDR78/0/O/IMG4358DxO​.jpg
michaelnel.smugmug.com​/Other/Michaels-Junkbox/i-mSBBFsJ/0/O/IMG4360DxO​.jpg
michaelnel.smugmug.com​/Other/Michaels-Junkbox/i-T7GMvsF/0/O/IMG4359DxO​.jpg
Pebal
Joined Jun 2010
Feb 20, 2012 16:29 |  #6
michaelnel wrote in post #13930857 (external link)
Thanks for your images.
The circular banding can be found in the source image. You look at image IMG4358DxO.jpg
IMAGE: http://www.sns-hdr.home.pl/images/IMG4358DxO_CL.jpg
You used TIFF-16 or TIFF-8 format?
michaelnel
Feb 20, 2012 17:15 |  #7
Very strange. Must be something DxO is doing. But, as I said, Photomatix Pro doesn't have a problem with those DxO-processed files.
Pebal
Joined Jun 2010
Feb 20, 2012 17:24 |  #8
michaelnel wrote in post #13931295 (external link)
You can see the misty rocks in the image from Photomatix?
In SNS-HDR must be reduced "Lights Microdetails" parameter.
IMAGE: http://www.sns-hdr.home.pl/images/IMG4360DxO-HDR.jpg
michaelnel
Feb 20, 2012 17:41 |  #9
Pebal wrote in post #13931337 (external link)
Sorry, but I don't understand what you are saying here. :confused:
I understand there is a Lights -> Microdetails slider in SNSHDR and that it must be reduced. But what are you saying about Photomatix Pro?
Pebal
Joined Jun 2010
Feb 21, 2012 02:30 |  #10
michaelnel wrote in post #13931438 (external link)
Cannot see the rocks in the image from Photomatix.
IMAGE: http://www.sns-hdr.home.pl/images/sns-rocks.jpg
Therefore the image from Photomatix looks better.
kirkt
Feb 21, 2012 08:11 |  #11
Yes - when you increase the contrast in the region of the histogram that is in the peak containing the gray sky and far away landmass (so that you can see that landmass through the fog) you reveal the concentric banding that appears to be centered around the geometric center of the image. Try reprocessing your images in DXO with no corrections (apply the no corrections preset). Then run this images through the various HDR applications.
kirk
Kirk
michaelnel
Feb 21, 2012 09:08 |  #12
Thanks. I don't *want* to see through the fog. I couldn't see through it when I was there. It does seem DxO is the culprit here. I really only used it for lens corrections prior to the HDR processing, and if it does that banding I won't use it. I processed the same RAW files with ACR's lens corrections and didn't get that banding, and I think ACR corrected the lens problems just fine.
I'm becoming less happy with DxO Optics Pro 7 every time I use it.
kirkt
Feb 21, 2012 09:42 |  #13
If you can upload one of the raw files to an FTP site, I will take a look at it in DXO. I use DXO pretty frequently and have not had this issue. I have also done testing with DXO7 and would like to get the problem rectified in a future release, so if there is an issue I would be happy to try to identify it and make it known to DXO.
Otherwise PM me and we can do the file transfer outside of this thread.
kirk
Kirk
kirkt
Feb 21, 2012 11:34 |  #14
See attached screenshot for the curve I used in DXO - I also tweaked the screenshot in PS to make the bands more apparent.
kirk
michaelnel wrote:
kirkt wrote:
What version, platform are you currently using for DXO? This info will be helpful for DXO.
I am running 7.2.0 Rev 25011 Build 94 on Windows 7 64bit version.
The files are now available, what's your email address so I can share them with you?
Please try this on your machine:
1) open the middle exposure raw file in DXO (IMG_4358)
2) set the "Apply preset..." menu choice to "No Correction."
3) Enable the "Tone Curve" palette so you can apply a crazy tone curve to emphasize the area of the sky that is plagued with the artifact.
4) In the Tone Curve Master, make a curve that drags the center of the tone curve downward, so that the mid tone point is positioned halfway horizontally, but all the way on the baseline vertically (i.e., at 128 input = 0 output).
5) drag the 3/4 tone point so that it is 3/4 of the way on the horizontal axis, but pegged to the top on the vertical axis (that is input = 192, output = 255).
At this point the image should be blocked up where the land is and bluish and bright where the sky is. You should see some darker blues in the upper corners due to the lens vignetting.
Here is where I think the problem lies....
6) Enable the Vignetting correction palette.
You should see the banding appear in the sky areas. This is a problem. Try clicking on the little "+" symbol in the Vignetting palette to reveal the preserve highlight/shadow slider and see if adjusting this gives you any better results.
The concentric nature of the banding, centered around the midpoint of the image made me suspect this. Please send DXO tech support an email with your example image.
I will post a bug report in the beta test forum for Mac, but you should alert them to the problem on your Win machine as well.
kirk
Kirk
michaelnel
Feb 21, 2012 11:55 |  #15
It looks much different here on a Win7/64 machine. I don't have a MASTER curve, I have RGB, red, green, and blue. I chose RGB and followed your instructions (I think) and I sure don't see the pronounced banding you show in your screen shot.
5,045 views & 0 likes for this thread, 3 members have posted to it.
498 guests, 152 members online
