Thread started 20 Feb 2012 (Monday) 17:14
Going Compact/Portable
nicksan
Man I Like to Fart
Feb 20, 2012 17:14 |  #1
Is there anything better out there than the Manfrotto Nano stand as far as striking a good balance between stability and portability? I've got 2 of these already and am just curious to see what else is out there.
What about the Westcott Collapsible umbrellas? Any alternatives?
These would obviously be used with speedlights.
tetrode
I am a walking repository of thoroughly useless information
Feb 20, 2012 17:20 |  #2
nicksan wrote in post #13931291 (external link)
The Matthews Reverse Stand kicks sand in the Nano's face:
http://www.bhphotovide​o.com …7486_Reverse_St​and_7.html (external link)
DHPHOTO66
Joined Jan 2012
Feb 20, 2012 18:07 as a reply to  @ tetrode's post |  #3
http://www.calumetphot​o.com …ltra_compact_st​and/mf6027 (external link)
Uncle Donn | http://www.flickr.com/​photos/dhphoto66/ (external link)
tetrode
Feb 20, 2012 20:05 |  #4
That Calumet stand is the same as the Nano. Same 3.5 pound maximum load. The Matthews Reverse carries an 11 pound max load rating and is only about 2 inches longer than the Nano when folded.
nicksan
Man I Like to Fart
Feb 20, 2012 21:12 |  #5
tetrode wrote in post #13931320 (external link)
OK, compared to the Nano, the Matthews is 3" longer and max height is 83.5".
Other than that, how does the Matthews stand "kick sand in the Nano's face? Would like to know, b/c if this is that better, then I'll buy them.
jdotuk
Feb 20, 2012 21:26 |  #6
Would the matthew's stand be capable of holding a monolight? Obviously you wouldn't put a large modifier on it, maybe a medium softbox.
I've been looking for something portable to use on location indoors and see seem like they'd be perfect.
Thanks in advance.
Jeremiah (J.) Mullins
5D & 7D | 35L, 50 1.4, 85 1.8, 135L | X100s
nicksan
Man I Like to Fart
Feb 20, 2012 21:44 |  #7
jdotuk wrote in post #13932913 (external link)
Thanks in advance.
Says it supports up to 11 lbs. I am looking for a stand to use with speedlights and collapsible umbrellas. For the other stuff, I've got heavy duty stands already.
jdotuk
Feb 20, 2012 22:44 |  #8
nicksan wrote in post #13933019 (external link)
Right. I guess my question is, are the specs padded? I didn't see any indication that they were in the reviews at B&H - but most people were using them with speedlights. My largest modifier is the Apollo Orb, and it will probably stay the largest I've got for a while.
As for the heavy duty equipment - I've only got a speedlight kit, but I would like to add some power to it. If I can use the same stands for both most of the time then its win-win.
tetrode
Feb 21, 2012 08:44 |  #9
jdotuk wrote in post #13933528 (external link)
I use my reverse stand with monolights all the time. At the moment, it has an Elinchrom 600RX with Maxilite reflector mounted on it. No problem with a 24" x 32" softbox or 36" octa either. The column sways a bit due to the inverted installation of the base. But the stand has a very wide footprint that provides excellent stability.
Dave F.
Dave ­ Jr
Feb 21, 2012 09:10 |  #10
Thanks, Dave. I'll be buying a Matthews reverse stand for the upcoming season.
Dave Jr - MN
5 (external link)px | Gear
jdotuk
Feb 21, 2012 12:23 |  #11
tetrode wrote in post #13935197 (external link)
Dave F.
Outstanding. Thanks Dave.
nicksan
Man I Like to Fart
Feb 21, 2012 14:03 |  #12
Dave F.
Thanks. Very useful, and it looks like I'll be ordering these stands. :)
nicksan
Man I Like to Fart
Feb 21, 2012 20:45 as a reply to  @ nicksan's post |  #13
How is Matthews MERF?
http://www.bhphotovide​o.com …ERF&N=0&Initial​Search=yes (external link)
Extends to 7'5" and collapses down to 20". So that's taller than the Nano or the other Matthews that was linked in an earlier post, and almost as shot as the Nano. Also has the rubber feet unlike the other Matthews one.
So
http://www.msegrip.com …tthews-reverse-stand.html (external link)
vs.
http://www.msegrip.com …-1/kit/matthews-merf.html (external link)
Looks like the Nano has a max load of 3.3lbs vs. 9-11lbs for the Matthews.
Thoughts?
nicksan
Man I Like to Fart
Feb 22, 2012 11:26 as a reply to  @ nicksan's post |  #14
Ended up ordering 2 Matthews MERFs. Almost the same size as the Nano, but much sturdier. (load of 9lbs vs 3lbs)
I also ordered 2 Westcott Collapsible reflective umbrellas and 1 Westcott Collapsible shoot-through umbrella. I heard the one with the removable cover was a little quirky.
Can anyone recommend a bag that can carry these, some clothing, and still be considered a "personal" item for carry-on luggage?
I have a Think Tank Airport Antidote. I'm guessing that'll count as one carry-on luggage. I don't want to check anything in, so trying to figure it all out.
jdotuk
Apr 04, 2012 18:36 |  #15
Awesome recommendation. Thanks Dave.
4,348 views & 0 likes for this thread, 6 members have posted to it.
1611 guests, 140 members online
