Thread started 21 Feb 2012 (Tuesday) 07:55
fool question about long exposure and 30 sec limit
mantra
Feb 21, 2012 07:55 |  #1
Hi
I am ashamed
but yesterday i was shooting long exposure in the dark
and i did notice the shutter speed did blink 30"
well I realized that 30 seconds is the max, i knew it after there is bulb in manual
i was set to aperture and iso 100
well i could lower the aperture and/or raise the iso
but the question is
i'm talking about long exposure and darkness
in the darkness how could i calculate the exposure ?
i mean i want to keep aperture 9 and iso 100
the camera is limited to 30" , and for example a right speed is 45"
i can go in manual , but again how can i know the shutter speed to obtain a correct exposure?
ps i was shooting with a 5d mark 2 , burst mode AEB +2 ,0 ,-2 but my camera did not perform 3 shots in raw , but i had to press the shutter every time(3 times) , weird because i pointed the camera at a strong light and it was enough press the shutter once to have 3 shots
thanks
cheers
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
gjl711
Feb 21, 2012 08:11 |  #2
With exposure that long I have found that the best way is trial and error. With exposures that long individual point sources of light may start to overexpose a lot even though the entire frame is very dark.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
mantra
Feb 21, 2012 08:15 |  #3
gjl711 wrote in post #13935070 (external link)
thanks gjl711
and what about an external exposure meter ?
tzalman
Fatal attraction.
Feb 21, 2012 08:31 |  #4
Set ISO to 1600, take meter reading, set ISO to 100, multiply time by 16.
Elie / אלי
John ­ from ­ PA
Joined May 2003
Feb 21, 2012 08:33 |  #5
Not sure what you might be shooting but you might give this handy make it yourself night calcualtor a go. It is based on The Jiffy Calculator by S. P. Martin and first published in Popular Photography in April 1968. The calculator has a range of 20+ scenes such as burning buildings, neon signs, display windows, landscapes under moonlight, fireworks, etc. You cut it out in two pieces, one which slides within the other to align scene number with ISO in a window; the other window gives f/stop and speed combinations. A "new" Jiffy Calculator is available at http://photocamel.com …-calculator-can-help.html (external link).
Seriously, it work well for getting a great starting point for exposure but bracket, bracket, bracket...
mantra
Feb 21, 2012 08:33 |  #6
tzalman wrote in post #13935147 (external link)
good tip
but i need a calculator :D
thanks tzalman
Ripple
Feb 21, 2012 08:48 |  #7
16? Shouldn't it be 4?
john5189
Feb 21, 2012 09:07 |  #8
No it is 16, it is 2 to power of 4[Stops] .
Wedding Photography in Herefordshire.  (external link)
Mike
ugly when I'm sober
Gallery: 51 photos
Feb 21, 2012 09:29 |  #9
Trial and error and a good stopwatch are the way to go I think.
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
Maverique
Feb 21, 2012 09:45 |  #10
Best way is to put your ISO as high as possible and calculate the exposure in relation to ISO 100. 1s at 3200 ISO is 32s at 100 ISO. Use your cell phone to calculate, if you need.
My website (external link) | My facebook (external link) | My flickr (external link)
mafoo
Joined Dec 2011
Feb 21, 2012 10:04 |  #11
This is not directly related to your question, however you might find it of interest.
You can get past the 30 second max exposure, with Magic Lantern.
http://magiclantern.wi​kia.com/wiki/Unified/U​serGuide (external link)
-Jeremy
5D Mk II | SL1 | 24-105 f4.0L IS | 70-200 f2.8L IS | S35 1.4 | 40 2.8 Pancake | Samyang 14 2.8 | 430EX II
mantra
Feb 21, 2012 11:23 |  #12
John from PA wrote in post #13935157 (external link)
thanks John , nice found , i printed the pdf
mafoo wrote in post #13935841 (external link)
do you use it? is safe?
thanks mafoo
mantra
Feb 21, 2012 11:27 as a reply to  @ mantra's post |  #13
but about the feature AEB of the 5d mark2
i wanted to take 3 shots for an hdr
i set up the camera in burst mode , and AEB to -2 0 +2
so the camera should take 3 shots automatically
but i found out that in the darkness , night , it does not
i had to press the shutter 3 times to take 3 shots -2 , 0 and +2
and the shutter speed was about 5 seconds , max 15 seconds
is normal?
i have the last official firmware
thanks a lot to everyone
cheers
gjl711
Feb 21, 2012 11:33 |  #14
mantra wrote in post #13936328 (external link)
is normal?
cheers
I'm assuming you had burst set and held the shutter button down for 1 minute 30 seconds.
::Gear::
mafoo
Joined Dec 2011
Feb 21, 2012 13:34 |  #15
mantra wrote in post #13936294 (external link)
thanks mafoo
I have not used it, but only because I have no current need for it. There has never been a reported case of this software damaging a camera in any way.
It sits on your memory card, and only loads if you have the app on that card. It does not replace your firmware.
-Jeremy
2,613 views & 0 likes for this thread, 13 members have posted to it.
1053 guests, 103 members online
