Thread started 22 Feb 2012 (Wednesday) 11:06
5D II and Einstein ?
sf1
Feb 22, 2012 11:06 |  #1
Ok, the search button above does not work my iPhone.
Can the Einstein do high speed sync via the pocket wizard mini tt1 (or 5) and the power MC2 with the canon 5D II. If so what kind of sync speeds are you getting?
Canon 5DII, Canon 1D Mark II N
Canon 24-70 mm f/2.8 L, Canon 85 mm f/1.8, Canon 70 -200 mm f/2.8 IS L, Canon 400 mm f/5.6 L, Canon 50 mm f/1.4, Manfrotto 055XPROB & 488 RC2
Canon Speedlites 580 EX, 430 EX II & 3 PW II, iMac I7, MacBook Pro, Aperture 3, CS5
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Feb 22, 2012 11:09 |  #2
None of the studio strobes can do HSS. What some of them can do is hypersync. It still gets you higher sync speeds by using the tail burn of the flash. The short duration of the Einstein and the 1/200 native sync speed of the 5DII work against this combo.
sigma ­ pi
Feb 22, 2012 11:26 |  #3
gonzogolf wrote in post #13943655 (external link)
I cant get a clean one at 1/200 I have to drop to 1/160 :(
Don't try to confuse me with the facts, my mind is already made up.
http://www.flickr.com …6850267535/in/p​hotostream (external link)
gonzogolf
Gallery: 559 photos
Feb 22, 2012 11:32 |  #4
sigma pi wrote in post #13943746 (external link)
What triggers are you using? I can get 1/200 with cybersync's no problem.
silvrbullet
Feb 22, 2012 11:45 |  #5
Ouch, I can hit 1/200 with my Cactus V5's.. curious to know what you are using?
Sony A7RII | Zeiss Batis 2.8/18 | Fuji X-T1 | 23 F/1.4
sigma ­ pi
Feb 22, 2012 12:06 |  #6
Skyports. I see a little clip on teh side. Its perfect at 160. I am not putting them in Speed mode though.
JackSw1ss
Feb 22, 2012 12:30 |  #7
for me never works 1/200 with skyports...neither in normal or speed mode.
with cactus I sometimes (say 70-80%) get clean 1/200
darktiger
Feb 22, 2012 14:03 |  #8
I was wondering the same thing.. I read this thread yesterday and got some info.. I just now need to try this with my Einstein.
https://photography-on-the.net …/showthread.php​?t=1151125
My Flickr (external link)
My Zenfolio (external link)
sigma ­ pi
Feb 22, 2012 14:38 |  #9
JackSw1ss wrote in post #13944182 (external link)
I can get 1/200-250 with my 7D and skyports.
KinoC
Feb 22, 2012 18:59 |  #10
Using the 5DMII in combination with the MC2 I get 1/1000s on the Einstein but when I use my 7D with MC2 I get 1/2000s.
KC
1Dx |5D MII | 7D|16-35 MII|24-70 MII|70-200 MII
delsol9400
Feb 23, 2012 08:06 as a reply to  @ KinoC's post |  #11
On my 5dmkii with pocketwizard mini and mc2 I can get up to a clean 1/250s and a usable 320/s
joecapasso.com (external link)
http://www.facebook.co​m/joecapassophotograph​y (external link)
TWITTER: @JoeCapassoPhoto
http://twitter.com/Joe​CapassoPhoto (external link)
bobbyz
Feb 23, 2012 08:13 |  #12
KinoC wrote in post #13946741 (external link)
Shots please.:D First time I am hearing someone with that high ss.
Fuji XT-1, 18-55mm
JackSw1ss
Feb 23, 2012 08:15 |  #13
sigma pi wrote in post #13945039 (external link)
mee too with the 7d ;)
Curtis ­ N
Master Flasher
Feb 23, 2012 08:33 |  #14
Can you get better sync speeds if you drop the power on the Einsteins (they have a shorter flash duration at lower power settings)?
My testing of the Skyports seemed to indicate they induce a slightly longer delay than PocketWizards or Cybersyncs, but it shouldn't require shutter speeds slower than X-sync unless you're dealing with a particularly long flash duration.
kenyee
Feb 23, 2012 09:42 |  #15
sigma pi wrote in post #13944042 (external link)
It's because of the big slow FF curtain on the 5D. It's fairly common....Zach Arias mentioned it in his first creativelive workshop. Kacey's 5D also has this problem. Same problem happens w/ different triggers (Arias uses the original PW, not the TT, some people have the issue w/ Cybersyncs which are faster than the PW). If you found out when you bought the 5D, you should have exchanged it because not all are that slow...
We're not talking about the PW TT's Hypersync, of course. If you're using the Hypersync hack (and you need the PW TT to do it), you want the longest pulse you can get, so fire the Einstein at full power.
p.s., oddly enough, Nikon's FF D700 doesn't have that sync problem...
Pentax K20D, 77Ltd, 43Ltd, Sigma 17-70, 60-250/4, crapload of Strobist gear (SB28's, RP JrX Studios, Einsteins, WL, Speedo BD, softboxes, grids, etc.)
4,906 views & 0 likes for this thread, 11 members have posted to it.
642 guests, 120 members online
