Thread started 22 Feb 2012 (Wednesday) 14:29
Vivitar 283 - worth rescuing?
joeblack2022
Joined Sep 2011
Feb 22, 2012 14:29 |  #1
I've come across a Vivitar 283 that won't trigger. The unit sounds like it is charging up but when the test button is pressed (which is lit up), nothing happens. I tried measuring the trigger voltage but it came back zero. I have also tried to trigger via the sync port with no success using a PT-04 wireless trigger.
Anyone have any ideas what the problem could be and if I should bother trying to get it to work?
Joel
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Feb 22, 2012 14:32 |  #2
It wouldnt hurt to try to play with it, as long as you know how to handle a capacitor safely ( I dont). But its not worth investing in any parts.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Feb 22, 2012 22:27 |  #3
I've had two of those for decades & they've never failed, so if the repair is cheap enough, I'd get it fixed.
There are also a lot of accessories for them: Simple "every-day-emergency" location lighting
joeblack2022
Joined Sep 2011
Feb 22, 2012 22:36 |  #4
I'm a bit hesitant to open it up since I can't discharge the capacitor (well, if it actually is charging up). Maybe I'll give it a go when I have a spare moment or two.
I did see your thread Frank, and it's one of the reasons why I think it may be worth salvaging! Also would very much like to obtain the varipower module or wire in a potentiometer to get more control of the flash output.
Joel
PhotosGuy
Joined Feb 2004
Feb 23, 2012 09:47 |  #5
joeblack2022 wrote in post #13948267 (external link)
That's very useful. I see accessories on ebay all the time.
Try cleaning the battery contacts inside the 283 & in the battery module. I did have a small problem with corrosion there once.
1,341 views & 0 likes for this thread, 3 members have posted to it.
1319 guests, 121 members online
