as i was watching the video on the cinch, i saw this plate and looks very interesting as you can hook up the cinch to it and also mount on the tripod.
i'm hoping to find whatever this plate is at a local shop to try it on my dolica ballhead.
EOSmE Goldmember 2,491 posts Likes: 1 Joined May 2006 Location: San Jose, CA More info | Feb 23, 2012 01:25 | #1 as i was watching the video on the cinch, i saw this plate and looks very interesting as you can hook up the cinch to it and also mount on the tripod. 5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthread.php?t=416554
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | Feb 23, 2012 02:08 | #2 It's an Arca Swiss compatible plate. They use a Really Right Stuff BH-55 ball head, so I assume it's a RRS plate. You might be able to swap the clamp on your head over to an Arca type. A lot of us use and prefer the Arca system over all the others. You can look at RRS gordon
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | It certainly looks like an RRS plate of some kind. I cannot read the number stamped into the plate as the res breaks down into artifacts, but you should be able to find what you want on RRS's site. Richard
elicious Member 130 posts Joined Jan 2012 Location: San Diego, CA More info | Feb 23, 2012 11:44 | #4 Actually, it looks more like a Kirk plate. RRS plates tend to have that "zero/center" icon on the photographer/LCD side of the plate as well as a slightly slimmer profile. 5D3 | 24-105L
Feb 23, 2012 11:57 | #5 i thought i was a kirk.. but didn't see it on their site. but then again, i need to work with my bat grip. 5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthread.php?t=416554
gakoenig Senior Member 427 posts Joined Feb 2010 Location: Portland, OR More info | Feb 23, 2012 13:26 | #6 That is my D7000 with this RRS plate... http://lu.ma
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Feb 24, 2012 00:05 | #7 Looks like an RRS or Kirk plate to me. You probably aren't going to find either of those in any local shop though. [Gear List | Flickr
maked Hatchling 6 posts Joined Feb 2012 More info | Feb 24, 2012 00:30 | #8 you should be able to find what you want on RRS's site.
Feb 24, 2012 01:02 | #9 ben_r_ wrote in post #13956454 Looks like an RRS or Kirk plate to me. You probably aren't going to find either of those in any local shop though. doh! i'm hoping to find one that would work on my 5D2+grip. 5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthread.php?t=416554
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Feb 24, 2012 02:13 | #10 I use an RRS plate with the number BGE-2 stamped into the metal. Its the plate I used on my gripped 30D and it fits perfectly. RRS kit is beautifully made. Richard
RandyS Goldmember 1,046 posts Likes: 2 Joined Dec 2009 Location: Minnesota More info | Feb 24, 2012 05:54 | #11 EOS mE wrote in post #13956775 doh! i'm hoping to find one that would work on my 5D2+grip. It looks like in the case of Kirk & RRS, both the camera plate and L plate for the 5D2 have the mount point where you could attach the Cinch, but neither of the plates for the 5D2 + bg have it.
Feb 24, 2012 10:12 | #12 ^^ yea i noticed that too on both kirk and RRS site. i guess i could see how it might strain it. but that's why i have a hand strap, so in case if it the battery grip comes undone from insde the camera or from the screw that holds the bat grip to the cam.. at least my gear won't drop to the floor. 5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthread.php?t=416554
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Feb 24, 2012 11:51 | #13 EOS mE wrote in post #13956775 doh! i'm hoping to find one that would work on my 5D2+grip. EOS mE wrote in post #13958447 ^^ yea i noticed that too on both kirk and RRS site. i guess i could see how it might strain it. but that's why i have a hand strap, so in case if it the battery grip comes undone from insde the camera or from the screw that holds the bat grip to the cam.. at least my gear won't drop to the floor. Im a little confused here.. Whats wrong with just getting a tried and true RRS one? I have both the B5D2-L and BGE6-L RRS plates for my 5D2 and they work wonderfully as has all of my RRS gear. If the problem is attaching your hand strap, well none of the RRS plate block the built in hand strap mount on the Canon grips as Ive shown in my attached image. [Gear List | Flickr
Feb 24, 2012 15:49 | #14 hi ben.. this is what i'm looking for..
this way, with my handstrap onto the plate and the other cinch strap to the camera, not matter what, my gear won't fall off, unless if the cinch strap breaks. u know what i mean? 5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthread.php?t=416554
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Feb 24, 2012 16:09 | #15 Okay, not sure why you dont want to use the hand strap slot Canon provided, but that being the case, how about this then: [Gear List | Flickr
| Latest registered member is zachary24 1381 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
