Thread started 23 Feb 2012 (Thursday) 12:58
Quantum 1 - battery LEDs question
joeblack2022
Joined Sep 2011
Feb 23, 2012 12:58 |  #1
I just re-celled an original Quantum 1 battery myself and it seems to work, hooked it up to a Vivitar 285HV and it fires.
However, none of the green battery LEDs (1/3, 2/3, 1) ever lit up. According to the manual, they are supposed to light up to show you current battery status after you fire the flash.
Is this just a case of the cells needing to be fully charged or is something wrong with the pack? The pack is currently charging and the voltage was sitting around 6.2V before I hooked it up.
Joel
Wilt
Feb 23, 2012 15:44 |  #2
The pack's circuit board for monitoring the battery status just might well be fried. The lights are supposed to light up even before you fire the flash.
joeblack2022
Joined Sep 2011
Feb 24, 2012 09:33 |  #3
That's what I'm suspecting... does the circuit board do anything other than monitor voltage? I would think for the price there would be intelligent charging but the manual doesn't seem to indicate that.
In any case, it still seems usable, though it will be annoying to have to check charge with a voltmeter instead of looking at LEDs.
Joel
CanonCameraFan
Joined Sep 2011
Feb 26, 2012 13:21 |  #4
Open it up and simply check all the Solder Joints. It may have a cold joint that just needs touched up. Did it work before, or is this an old unit you just got? They should always indicate charge level, as long as it is switched on.
I recently re-celled both of my units after they had been in storage for 10 years. I got the OEM brand USA Made for about $24 each pack. $50 gave me $500 worth of equipment!
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
joeblack2022
Joined Sep 2011
Feb 27, 2012 11:46 |  #5
CanonCameraFan wrote in post #13970142 (external link)
It's an old unit, I bought the cells individually at about $11 a piece. I saw a replacement pack on eBay for about $20 but shipping was the same cost! :(
I will open it up and have a look see when I get a moment.
Joel
joeblack2022
Joined Sep 2011
Feb 29, 2012 09:05 |  #6
Had a look inside and didn't see anything suspect, it's probably fried... oh well!
Joel
1,532 views & 0 likes for this thread, 3 members have posted to it.
1319 guests, 121 members online
