I have read that using a D30 with some studio flash units can damage the cameras hotshoe. Is this correct and if so what are the ways round this problem?
www.wedding-photography.org![]()
Stemmy Hatchling 7 posts Joined Oct 2002 Location: Manchester More info | May 27, 2003 15:59 | #1 I have read that using a D30 with some studio flash units can damage the cameras hotshoe. Is this correct and if so what are the ways round this problem?
justme_dc Senior Member 327 posts Joined Mar 2003 More info | May 27, 2003 17:10 | #2 there are a number of wireless solutions available that don't have dangerous voltage levels.
mpross Hatchling 8 posts Joined Jul 2002 More info | May 27, 2003 17:33 | #3 I use Alien Bees with my D60 without any problems. But don't know if the D30 is different.
daveh Senior Member 318 posts Joined Apr 2003 More info | May 27, 2003 18:28 | #4 Alien Bees have a 6 volt trigger so there's no issue with them. There are some flashes (mostly very old designs I think) with trigger voltages in the hundreds of volts.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | May 27, 2003 21:10 | #5 Basically, it is not that hot shoe itself that might be damaged, but the electronics that drives the hot shoe connection. It is intended to be used with Canon flash units, which have a trigger voltage around five volts. If you use something close, like five or six or seven volts, I doubt that there will be any problem. If you use a strobe with a 170-volt trigger, then you may be causing the camera to fail.
DAMphyne "the more I post, the less accurate..." More info | May 28, 2003 08:46 | #6 I believe this is what happened to my D30, the PC input won't set off any flash, even a hot-shoe adapter wont produce any flash. David
daveh Senior Member 318 posts Joined Apr 2003 More info | May 28, 2003 10:18 | #7 damphyne wrote: Is there a way to find out what voltage is produced by my Novotrons? If it's not listed in the manual or web site, and the manufacturer won't tell you, then you can use a volt meter to measure it yourself.
soumya63 Member 214 posts Joined Dec 2001 More info | May 28, 2003 13:30 | #8 Check my website for a trigger voltage conditioner circuit.
| Latest registered member is AlainPre 1777 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
