FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 25 Feb 2012 (Saturday) 11:25
S100 P Mode
JLai81
Feb 25, 2012 11:25 |  #1
Is there a way to control aperture while in P mode for the S100?
Jon
Joined Jun 2004
Feb 25, 2012 11:40 |  #2
No. That's what Av is for. There's no capability I can find like the EOS ability to vary aperture/shutterspeed combo together while maintaining the same exposure level by turning the Control Wheel in P mode.
Jon
Cocker Spaniels
JLai81
Feb 25, 2012 11:48 |  #3
Jon wrote in post #13964803 (external link)
That's what I figured. I use Av for my 7D, but I hate using Av with variable aperture...Thus why all the lenses I use have fixed aperture.
Thought P mode would be a simple solution as it would set aperture unless I chose to change it...unfortunately, not the situation.
Thanks for your help.
Jon
Joined Jun 2004
Feb 25, 2012 11:50 |  #4
If you set the aperture wide open, you'll always get the fastest available aperture. Alternatively,if you use f/5.6,that's available at all focal lengths. Other than that . . .
Jon
Cocker Spaniels
JLai81
Feb 25, 2012 12:04 as a reply to  @ Jon's post |  #5
True. I'll give it a shot...Still need more play time. Av may be the best solution.
They also really need a little joystick to control the AF point. Auto does a horrid job and it takes too long to use FlexiZone.
Keyan
Joined Mar 2011
Feb 25, 2012 20:53 |  #6
JLai81 wrote in post #13964919 (external link)
Have you tried the focus tracker?
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
JLai81
Feb 25, 2012 21:10 |  #7
Keyan wrote in post #13967271 (external link)
Yeah. Seems like a useful tool to use for action. Still rather have an AF point selector similar to the EOS for regular shots.
Sam
Feb 25, 2012 21:43 |  #8
JLai81 wrote in post #13967330 (external link)
You can focus with the tracker, then recompose as desired but the camera maintains a lock on your intended subject. It seems like a solution for what you were asking unless I'm hearing it wrong.
JLai81
Feb 26, 2012 00:29 |  #9
Sam wrote in post #13967460 (external link)
Yes and no. It tracks so I can recompose, yes...but I want the AF to stay in a certain position rather than recompose every time I don't want the subject in the center of the image. It seems to pretty much serve the same as using the AF lock and recomposing.
Thank you for the information though.
MOkoFOko
nut impotent and avoiding Geoff
Joined Jun 2010
Feb 26, 2012 01:07 |  #10
I have mine permanently parked on a/v. yep yep
My Gearlist
DaaamnGina
Feb 28, 2012 16:21 |  #11
I think I can relate to what you're saying. I used to have an LX5, and setting the focus point was much easier. I actually miss it. It handled and focus much better than the S100, but pocketability and JPG quality pushed me to the S100.
Have you tried this? Customize the Ring Func button the AF. In P mode, click Ring Func, move the selector to FlexiZone and click the Menu button. This will let you position the focus point so you don't have to recompose. To me, it's a bit clunky, but saves a few button clicks.
JLai81
Feb 28, 2012 19:40 |  #12
DaaamnGina wrote in post #13985451 (external link)
I might try that out. Thanks for the tip.
I've been shooting in Av the past few days and seem to like that mode best for the S100. Its silly that you can't control aperture in P mode.
4,469 views & 0 likes for this thread
S100 P Mode
Latest registered member is Mareseatoats
279 guests, 224 members online
