Off camera using this flash as "key", in an outdoor setting. Using umbrella or box and having a 430 EX on camera as trigger.
Has anyone tried this? What do you think?
Thanks, JOhn
john2 Hatchling 9 posts Joined Aug 2011 Location: Georgia More info | Feb 26, 2012 17:56 | #1 Off camera using this flash as "key", in an outdoor setting. Using umbrella or box and having a 430 EX on camera as trigger. Best Regards, John
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Feb 26, 2012 18:28 | #2 The first problem is that the 580ex can master the 4303x but not the other way around. lots of people here including myself use speedlites for fill and key lights.
Tiberius Goldmember 2,556 posts Likes: 11 Joined Apr 2008 More info | Feb 26, 2012 18:34 | #3 You'll need a 580 on the camera as a trigger. The 430 can't do it. My photography website!PHOCAL PHOTOGRAPHY
nes_matt Goldmember 1,022 posts Likes: 14 Joined Aug 2010 More info | Feb 26, 2012 18:43 | #4 do it the other way around, at dusk, and you'll do fine. Use the 580 on camera as fill and the 430 in the umbrella to add some accent. Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
aaxsherm Member 203 posts Joined Mar 2010 More info | Feb 26, 2012 19:39 | #5 You do not list what equipment you are using...so I will add that if you have a 7D, you can use that to trigger a slave (580, 430, etc) as well. Andy
Thanks for the feedback. By the way, one more question. Best Regards, John
mikeca42 Member 145 posts Joined May 2011 More info | As others have said you can use the 580EX on camera as a master to trigger the 430EX as a off camera slave.
oldvultureface Goldmember More info | Feb 27, 2012 19:51 | #8 john2 wrote in post #13975851 I still have a Canon 540 EZ. Can it be used in a similar arrangement? Looking at the 540EZ manual, the only way I see to use this flash is in manual mode with an optical slave, radio trigger, or PC sync with an adaptor. It won't integrate with your 580 or 430 in E-TTL.
Tiberius Goldmember 2,556 posts Likes: 11 Joined Apr 2008 More info | Feb 28, 2012 01:28 | #9 Yeah, the EZ series flashes don't work with the dSLRs... Not in automatic mode anyway. My photography website!PHOCAL PHOTOGRAPHY
msowsun "approx 8mm" More info | Feb 28, 2012 06:46 | #10 The 430EZ I had worked in Manual mode with the DSLR's that I have owned. (10D, 40D, 7D) Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member is vinceisvisual 889 guests, 180 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
