Yeah I know, another one of those. Hey, at least it's not another "which 70-200 whould I get?"
I'm still weighing my options for an upgrade to my 50 f/1.8 on my 5D2. I know it's tack sharp when used properly, but I don't do that. Mostly I use it in very low-light situations (such as indoors at night), and occasionally when I just want to travel light. So while it's great stopped down, I really need something I can use at 1.8. Unfurtunately, on the 5D2 using the center focus point, when it gets dark enough it simply fails to focus. Even when it does achieve a lock, it turns out that it misses focus by quite a bit. I tried using FoCal on it to see if it needed microadjustment, and it couldn't even complete the tests due to inaccurate readings (whereas my two other lenses worked fine). I'm thinking the AF isn't that lens' strong suit.
So I was fairly set on the 85 f/1.8 but the 1.4s aren't all that much more expensive. Now I know what the reviews say, but I'd like to tap into the collective wisdom here. Assuming I get a good copy, which of the three is going to have the best low-light performance? Not just aperture, but IQ wide open an AF performance as well. I can work with either focal length so it's mostly a matter of cost and low-light AF capabilities.
Thanks!
